Given the current media surrounding it (and the news stations trolling SAU at the moment looking for anything to add to their news reports)
First post that goes south here, thread locked and user sent on a long holiday.
so now theres two threads?
point?
if its such a worry why not close this thread in its uselessness. theres a thread in the wasteland which "guests" cant see anyway..
Think that things are getting a little out of hand there. There are far too many profanities and illiterate comments that are doing more harm than good. Think I might watch ACA or TT just to see how they report it....
point?
Point? Pretty clear what the point is.
Plus wasteland is already just a off topic dribble thread (as is customary).
"First post that goes south" & "the news stations trolling SAU at the moment looking for anything to add to their news reports"
whats the point in having the thread? if you wanted to avoid getting SAU involved in the shit fight, delete the thread.
think a moderator, posting the direct link, in a import forum is going to help our side? or do you think the "trolling news stations" are gonna put their own spin on it? as usual.
jeeeeezz..
common sense is not so common anymore..
jeeeeezz..
gotta back aaron on this. remove it. will only bring us guys under the hammer.
jeeeeezz..
We can have a reasonable discussion on the topic. It's not very hard for most people that can hold a level headed conversation.
If you can't - feel free to remove yourself from posting in the discussion thread.
Will be curious as to why and what law was broken
Guessing a message from the police saying there are threats/defamation on the page etc..
or could fall under the cyber bullying that facebook is always being hit for..
im sure there hundreds maybe thousands of vic TMU officers.....theres two sides of looking at it.....A) he is an exceptional officer and the rest are not doing there jobs properly or B) he is harassing motorists.......Id say B
Edited by ylwgtr2
Yep, I had a status on my facebook timeline which linked to it.... That is also removed.
Someone pretty high up must have tugged on facebook's danglies to have a mass deletion like that.
Edit: Actually my status was a Share... so that explains why its gone also.
Someone posted something of some substance:
The Police Conduct Unit (Complaints and Compliments) of the Ethical Standards Department can be contacted at Level 2 Tower 4, 637 Flinders Street Docklands 3008, or by telephoning 1300 363 101, or facsimile 9247 3498 or by email at - [email protected]
im sure there hundreds maybe thousands of vic TMU officers.....theres two sides of looking at it.....A) he is an exceptional officer and the rest are not doing there jobs properly of B) he is harassing motorists.......Id say B
This. Where there's smoke there's fire. You don't get this kind of reputation (1800 dislikes) by excelling at your work...like seniors at VicPol and the journalists (and I use the term loosely) would have people believe.
The key question is why this guy...and the answer is either A. because he's he only cop in Victoria doing his job properly, or B. maybe, just maybe...the cop is a human...and has a large chip on his shoulder.
So yeah, put it all on B...I'm feeling lucky.
When non-violent mediums of protest are stamped out, how can bureaucrats expect anything but violent guerilla tactics to follow?
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
