Hi guys I have a problem with my rear sunroof.
It wont open. I have pulled the roof out and checked the motor, and I am getting positive power at the plug. I can work the sunroof perfectly if I supply it will power and earth.
So basically I am missing the earth switch.
Can anyone tell me if there is a module or control box somewhere???
Any info will be much appreciated.
https://www.sau.com.au/forums/topic/415406-stagea-sunroof-problems/
  • 1 month later...
Hi,
Checking the obvious first - have you checked the slide switch that is on the front roof control for both sunroofs. It locks out the rear sunroof from being operated.
Thanks for that, couldn't work out why the rear sunroof wasn't opening... checked for the slide switch up front and hey presto the sunroof was locked. Unlocked and the sunroof operates flawlessly.
This forum is great, thanks Jezboosted
Hey you're welcome ! Glad it helped someone out.
    • I much prefer that to an actual oil pressure issue, never would of thought it would of been a volt drop issue but SAU brains win again. Guess ill be turning down the oil pressure limit for the track and hunting some grounds. Ill hopefully update this thread with some high oil pressure and solid ecu voltage logs.
    • You've just discovered a really good reason to tell yourself, yes, I do need to buy an aftermarket ECU. Put the MAF in the bin. Slap in the new ECU and have a think about what turbo sounds you prefer.  Do you want a 90's style BOV wooosh? Do you want a hektik tsututututu?  Mate, can't go wrong. Just gotta get that ECU and the world is your oyster.
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!! EDIT: So i read about this topic some more and i if i understand that correctly: That Greddy can function either like BoV or 100% Bypass valve? And that Turbosmart is what they called hybrid so you can adjust what and how many air can be vented out or back in? Is this right? THX!
    • That dirty voltage drop is the culprit I suspect
    • i cant get them all in 1 screenshot unfortunately as i just dont know how to move things around tbh, but they are all from the same log and the line crosses at the same point for all of them
