Hi guys,
I bought a Project Mu CF vented Z tune style bonnet for my R34, drove it the other day on a 35deg day and when i pulled up the bonnet had a weird smell to it (like the smell of body filler) and was really soft, like i could distort its shape with one finger and when i popped the bonnet the hole thing flexed.
Is this normal for a CF and Fibreglass bonnet?
Im just worried about it cooling down and hardening in a deformed shape.
Cheer's!
https://www.sau.com.au/forums/topic/415416-cf-bonnet-going-soft-when-hot/
Hi guys,
Cheer's!
Sounds like the epoxy mix was wrong or its a knock off
Carbon epoxy should be able to handle damn near direct flame !!!
It should never go flimsy or its defective bond
There is epoxy on the market used to make it super shiny but fails and goes soft above 80-90c
Maybe thats it
Fiberglass doesnt go flimsy either unless its near flame( different epoxy used )
Japan doesnt get hot as hell like oz so dont expect it to have UV stable epoxy , japan isnt cutting edge in compostes but the fit is normally way better from QC
Project Mu as in... the brake company? AFAIK they don't do bonnets so it's probably a fiberglass copy with a layer of carbon for cosmetics.
What do people expect for $700? Project Mu would not be Epoxy
At best Vinylester but I'd be guessing Polyester, Considering the low Tg of polyester this would be normal.
A carbon bonnet in direct sunlight can get to around 135 degrees C so even a poorly made vinylester bonnet would soften.
Project Mu bonnets are Gelcoat finish also, 1 layer of carbon and backed with general chop strand mat.
When you think about it vacuum infused 200gm 3k carbon is around 4 layers per millimetre, so even 3mm carbon laminates have flex and a bonnet is around 2sq metres. Do the maths 12 layers of carbon x 2sqm = 24sqm of just carbon alone @ $40/sq/m - $960 just in carbon for a 3mm thickness. Just for a bonnet skin!
So back to Neil, I see your car is black so either way if you had it carbon or painted you will end up with the same outcome.
I think you just need to get use to it or go back to your metal bonnet if your worried.
Noy
It's not vinyl ester !!!
they would have used pre preg carbon sheet and vacuum autoclaved it , with that in mind autoclaving is 150c or more
Most run of the mill pre preg. Is good for 300c !!
and carbon itself is unaffected by that little bit of heat , epoxy failures yes but not carbon
now chopper strand mat is weaker but stil not affected by 150c , corvette is made that way since 53 !! and they don't go floppy ??
I have a large hunk of 3k tow 2 layers thickcarbon with west systems epoxy and you can beat the hell out of it hot or cold with a ball peen hammer not a mark ( this sits in the sun for the past 3 years now!! )
but the same epoxy with a sandwich of Kevlar and carbon baked , failed at 250c ( delaminated )
during some epoxy trials for a strut bar of pure composites no metal
it's a bad mix ( cured wrong ) IMO
Thanks for the replys guys.
It was Mu's Secret sorry: http://www.musecret.com.au/category37_1.htm
I have emailed them but as of yet no reply, i took it for another spin the other day, when its hot u can indent the underside with your finger nails...
  • 1 month later...
How did you go with this Neil?
Did Project Mu come back with a response?
Prepreg :no: fkn LOL, you are well out of touch with the market if you think these are made with dry carbon.
+ factor in the cost of running an Autoclave.. unless someone in the world has learnt how to run an autoclave from a hamster wheel.
Also the statement about 300c prepregs is way off..
300c you would be looking into Phenolic's or BMI's and these make the $80-$100/sm prepregs look cheap.
Noy
Noy
I use it all the time mate
Worked in aerospace at lockheed on shuttle/rocket parts as well , I do know a bit
Even exotics like zylon !! Used on the deep space probes
This begs the question; has there been a general decline in people rocking CF bonnets as I see many people actually wanting to go back to the stock metal one. Is this true and why?
Defectable in carbon ?
funny pretty soon all cars will have carbon parts , more every year and not just exotics
Slam some kevlar in the mix the thing would be stonger then hell and not crack on impact
my body kit is layered in it , its abrasion resitant as well for parking blocks and spoon drain rubs
Yeah vinyl ester and carbon gives a weak bonnet, epoxy is the win....but as mentioned it depends on the type of epoxy formulation; to be honest you're not going to see too many aromatic amine-cured, BMI-Novolac hybrid bonnets getting around in consumer circles.
On an unrelated note, I've got a part I made at work which is silicon carbide bound by a BMI-Novolac hybrid . It got the nickname "the indestructable disc" after many attempts by the lab guys to do it harm. Fantastic paper-weight!
666DAN, aren't you the guy famous on here for selling LED dash lights? I bought a set off you almost 3 years ago and it's still running strong.
So you're a CF pro now are you? Why not start making your own bonnets?
    • Out here E90s are the cheapest way into a sporty-ish car because everyone knows just how expensive the repairs can get. 8-10k USD for an automatic 335i.
    • Noted. Have noticed BMW are more 'high maintenance' for sure. They've attracted my attention as I think the used car prices seem reasonable vs other options, and the extra quality overall vs a commodore / camry / corolla or similar of the same vintage is appealing, especially the interior, and they are more on the sporty side whereas the others mentioned can be more cruising or economical A-to-B only.
    • Haha yeah I know, this is SAU after all, why are we talking about BMW's of all things!? I hear you on the 'don't have to worry about it' side of things. Having been fortunate enough to be have been able to buy a brand new motorbike or two...never really enjoyed them as much as I'd have liked as you worry so much about where you park it, will it get scratched, stolen, attempted theft, knocked over, etc...and yes dirty. Older less valuable bikes you can just go where you want and park it wherever and not really worry that much in comparison. And who cares if it gets dirty! Never owned a V8, and have had my eyes on VE / VF commodores for years but with their prices climbing so high, the M3 has come into focus more as prices are much closer than I've ever seen...is it a potential contender now?...of course need to factor in the S65 'maintenance' especially and like you said general M car 'tax'. One can dream anyway. But more on the reality front - did read the whole 330i thread as well and was a great read too, both threads enlightening as I've never even driven one of these cars! I do recall 330i didn't seem to have the same amount of issues for almost the same car (turbos and related differences notwithstanding)...perhaps down to getting it earlier in it's life so looked after better than the 335i? Perhaps so as your 130i has been good and quite similar, so finding a car that's been looked after well is the especially-crucial-BMW-first-step.
    • Nice. Dont worry about the time of not running. My current skyline hasn't run since I bought it. About 8 years ago.
    • It's also worth noting that I am heavily and unconditionally biased. I've had a lot of cars including some GTRs a fair while ago. I love my BMW's now a lot. They make no sense a lot of the time and the guys on here remind me regularly that I could get something else that does what I want better and cheaper. If you're going to take on an older BMW it's definitely a commitment. If you bail on it early you'll lose money and also the ability for it to put a smile on your face. Stick with it and it just gets better.  f**k I should get into advertising.
