  • Replies 136
Thanks mate :rofl: If the weather holds up I'll get to try out the Nittos tommorrow.
Yes, very true. Stock and modified GT-Rs are very different beasts to tame, naturally stock being the easier of the two.
Emre- they're very impressive times there, 124mph!!!! I guess if I get my 60' times in the low 1.73, I might gain a tenth of a second or two.....
Calder was fantastic last night, had a total of about 7 runs, not that many cars, and perfect weather.....
  • 3 weeks later...
Penfold- yes bolt straight up, providing u get the kit which suits the rb26.... From what I've heard they are an awesome turbo, very responsive and make good power.....
Anyone here wanna share their experiences with these turbos?? *looks at vspecv*
A good friend of mine is running a single AX53B60 on a Pulsar GTi-R - this thing is a rocket! Lag? What lag!? Full boost by 3000rpm! He also confirmed they are about the same as the HKS 2530 - perhaps a touch better.
Just wondering who you have had good tuning experiences with in WA as I may be looking for someone soon.
The best in the west certainly does not use dynapack and his dyno dynamics dyno is extremely accurate - if anyone can reduce a chart I will attach my latest chart (not the one below)
i have only fitted them to 1 car a customer running a motec, but they were awesome. better than 2530s, peak power pretty much the same, just more responsive.
Hmm.. that's very interesting: less lag is always good :P Anyone got actual figures, or better yet, a comparison between the two?
LW.
  • 3 months later...
hi got the t78 which spooled up round 1bar on 5500, what type of power figures are the t517zs you have rated at in total as a pair 600hp 650hp 700? and at what boost? might be worth swapping to keep it all undercover thats all.
:cooldance
Hi Emre,
Its not that I want more power (not yet!!), I was just stating that how the JMS drag car can get 381 rwkws on 1.3 bar boost?!?!?!?
they usually run a mixture of toulene, acetone and avgas, you could say its rocket fuel... it makes ALOT of difference to the output of the car, much more boost and timing can be fed into the engine without detonation coming on, and thats how they make there power
they do it with most of there dyno runs, marketing i would assume, as not many people know what fuel they run and all they see is there power figure
they made 293rwkw on an sr20det silvia with a single T517Z, fuel ratio was as below:
avgas:toulene:acetone -----> 6:3:2
:cooldance
The T517Z's are rated at 600 hp, got my engine rebuilt last month and got dynoed a 335rwkws at 21psi...... full boost by 5000rpm
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
    • I don't think it's a good buy, the trend looks bad     lol.
