Feelin the love in here.
Bought some new nuts (since my missus keeps my current set in her hand bag) to match my soon to be teal brake calipers.
Nice man, my missus is f*cking crazy for teal coloured stuff.
Nice nuts Mat.
Sean, we give to strife because we can.
I get the car on ramps, take off cover, move tray under sump, remove plug, try to catch plug, remove filter and go have a smoke. That usually does it. :)
That's what i did for the oil, but when i went to do the filter i didn't have enough energy to take the sump cover off and get the clamps around the oil filter because it's very tight then i couldn't find the friggin things then i just gave up and wanted to go to sleep.
That's not too bad since it would be much much easier to get the sump cover off. The stock one is such a bitch. You'd think it'd be noisy though wouldn't you? with rocks and shit flying up and hitting it.
On dirt roads maybe - i don't think you'd notice to be honest. mount it with rubber grommets in between to insulate it from the k-frame and you shouldn't get any vibrations or anything.
Sorry they don't make them for boats.
Couple of things:
1- Your car is the same only with less doors, so how many knots does yours so and do you have it tied up at the jetty or marina?
2- ill happily meet you in the bends then say that.
3- the underbody protection plates rareJDM make one that fits sedan and coupe.
I replaced my engine oil last night, so difficult when my car is low as f*ck had to drive the car up on bits of wood to fit the jack in..
Still need to change the filter, i didn't end up finishing the change until about 7:30 last night and i was tired as f*ck so i thought i'd do it next oil change.
Is it normal for my car to use 1L of engine oil in about 7,000km?
Low is when you carry timber in your boot to get into places, cant fit a broom stick under the exhaust box or spark on a daily occurance.
Couple of things:
umadbro?
My car is the same as yours except it's easier to get jiggy in the back
Couple of things:
Burn!!
there are a few manufacturers. Zspeed also makes them.
Haven't done any research but I have read about one of the versions actually hanging lower than the plastic OEM tray - so that's something i'd be wary of. I'd be keen on one though. I hate taking those trays off - on my mazda the bolts rusted on and I had to literally bend it out of the way, to get the oil filter out - which was a cartridge style meaning i was guaranteed to get oil everywhere.
Trays are a piece of piss. Off in 1 minute.
How?
Get your electric drill, and a bit set with a 10mm socket. Put it in your cordless drill, and remove all the bolts. Job done.
Burn!!
Hey you can get jiggy in the back of mine too, if you're 4 foot tall and feel like breaking your back
After 5 months of going back on forth on the idea i finally debadged my V today and couldn't be happier with the results, will try get sum pics up of the car next week when my holidays start =)
yeah but with ours you open a door and make sweet tender love. with yours you have to wait what feels like century for the seat to come forward then be lego man size and made of rubber to get into the back. 4 doors for more whores!!!
    • Hi, i’m making Vag coil loom for rb25det, can anyone confirm the wire guage i’m using for power supply in diagram is enough for supply not too small for loom? For earth do i need to follow the same procedure or i can use only 16awg wire for all coil and their connecting wire following to the plug?
    • Did you panel beat the dents or have you tried to repair this only using filler?  Is your sanding block soft/flexible and is following the shape of the panel rather then just knocking down the high points?
    • I haven't knocked them down yet. I think I made the repair more complex than it should have been. I had rock chips combined with waviness and dents and I tackled it all in one because it was near each other and just end up wasting a bunch of bog lol. I'll knock down those areas and see how I go. And yep what you are saying at the end is correct. I think I might be sanding the top of a steep hill then my sanding block falls into the dent and gets rid of the guidecoat if that makes sense. Though shouldnt unless I'm covering too big of an area with not a long enough block. I'll try something new and provide some updates. Getting there though! Thanks as always.
    • Yeah makes sense, hard to comment on your situation without seeing what your doing. I was talking generally before, I would not be looking to randomly create low spots with a hammer to then have to fill them.  It's hard without seeing what your doing, it sounds like you are using the guide coat to identify low spots, as you're saying the panel is still wavy. I don't see how you're not ending up with patches of guide coat remaining in a wavy panel? Once the high spots are knocked down to the correct level, surely to have a wavy panel you need low spots. And those low spots would have guide coat still in them?
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
