Did a bit tinkering.
Cut down the studs on the V35 that were a few threads too long so now all the center caps are on.
Also sprayed the tow point cover. I think the Jap ones usually have a big number plate holder that covers this (hense the 4 little holes that ive covered with trim clips) but this is for the US market where some dont have to run front plates. Was only like $20 and will get rid of that gaping hole under the plate.
Sprayed it and for once using clear it didnt turn it into a orange peeled mess.
For those playing at home, scuffed it up, 3 coats plastic primer. 3 coats normal primer, light sand with 1200, 4 coats colour and the 3 really light coats of clear.
Not a perfect colout match but ok for home job and lot better than a gaping hole
All the holes bar the bottom 2 are covered by the plate and I sprayed 2 more at the same time as the tow point cover so should hopefully stick a bitbetter than the ones flaking in the photo
Thats about it for the V35 for the near future so back to the 14 for a while
Got my interior trim pieces back from paint. Put LED lights in the cup holder. Also colour coded the GT badge to match my calipers (it's the little things, right?) and fitted the Vertex roof and boot lips. No pics though. post-22161-1366687364671_thumb.jpgpost-22161-13666874021846_thumb.jpgpost-22161-13666874295571_thumb.jpg
Do you actually use your cup holder Mat? I find it very impractical given where it is.. same with the console bit with the sliding cover - again impractical because soon as you put a bottle or whatever in it you can't change gears properly.. i use that bit for my ipod/phone
got any pics of vertex roof and boot wing? cant find anything on there site?
or is it the vanquish gear off YJP?
im umming and arring about getting a uras one for mine
Look up 'Vertex Digna v35' on google images. Same as the black one.
I'm 5AT with paddle shift - I just select 'D' and I'm done! Plenty of room for cups/bottles/etc
oh haha, if i have a normal sized bottle you can forget using 2nd or 4th gear. Can is fine though..
<br /><br /><br />Look up 'Vertex Digna v35' on google images. Same as the black one.Ah thats why. done buy the USA branch and not T&E in japan so wasnt on the jap website
<br />My stuff is from Japan. Bought it off the ex-Vertex importer in QLD. It has all the jap documentation/instructions/metal plaque/stickers etc - so it is very much available from Jap given i can't understand a single word on the paperwork! He had an entire lip kit which I was trying to buy - we agreed on a price and postage but when he went to courier it the postage price quadrupled, so I had to pull out and take just the lips. If you're in QLD I can give you his details, he had two complete kits left, all brand new. He was asking $1300. Rrp for the lip kit is USD 2600 - the lip spoilers are nearly 500 each. Such good quality, finished in gel coat, hi filled and sanded - my panel beater didn't even have to prep them.
That's the guy, Lee. His name is Masato - I spoke to him on the phone a few times and verified him before transferring my cash. He was good to deal with. Took some quick pics just in the garage. post-22161-13667200946444_thumb.jpgpost-22161-13667201091408_thumb.jpg
Installed my new brakes - 370Z Akebonos front & rear. Second pic shows stock size front rotors vs new 350mm x 32mm front rotors. My stock premium coupe 18" rims won't fit over the front brakes - need to either get different rims or try a small spacer. I've got a set of 350Z rims that fit, so have them on for the moment.
    • Mate you saved be from dying in the Perth summer. AC wasn't changing direction and just going into diagnostics mode fixed it. You're a legend and I would shout you a beer if I could!
    • Unfortunately effort gone to waste, you will have substantial issues with how the manifold and wastegate have been integrated. You would be so much better off with a modified stock manifold like this: https://hypergearturbos.com/product/rb25detexgatedmanifold/   OR literally just getting a off the shelf Sinco or 6Boost manifold as myself and others have mentioned.
    • Yuck. But it's kinda the same principle, moving timing around to make car run bad but sound good.... I went for a more spirited tuning drive to iron out a few things. Car no longer stalls, and it loved to dip RPM low when you clutch in. After tuning this (and the 4-5 tables that HPTuners/LS1 OEM ECU wants for idle air correction) it's now behaving somewhat normal. All expected because there's a new TB, new Intake manifold and that new TB which is 102mm vs 78... has an entirely different IAC passage which is smaller because ????? Unfortunately at this point I went to make further fine tuning changes to avoid it flaring up, you know... _tuning_ the HPTuners dongle died. Well to be more accurate - The USB cable died in a fashion that anyone who has ever charged a phone will recognize. After the app demanding I resync it 50 or so times (which all 'succeeded' but all failed) the device does not want to sync and I've logged a ticket with support to see if it's fixable. US Support said it was a 'storage issue' but after removing the SD card inside it and formatting it/fixing it the issue does persist. Unfortunately usually the fix is "Turn in your old dongle and pay $700 for the upgraded one" it's cheaper because I get some free licence credits I unfortunately don't need. However I'm 10 minutes down the road from HP Tuners AUS/VCM so at least I won't need to post it, and logged a new ticket for support over here. Definitely drives different. My SOTP dyno believes it's probably making 310-320kw instead of the 280 before.  It scrambles for traction a little now whereas it previously different. It drives like a bigger cam car up top even though the cam is smaller, likely due to the cam not being advanced 6 degrees. The timing is deliberately low and the fuel is very rich so who knows if this will improve on the dyno. It may, imperceptably. Also funny is removing the pineapples definitely makes the car squat more and axle tramp less. So this behavior of having more top end, squatting more, and scrabbling for traction more makes me think = more power. But I could have just been sitting on the threshold of that kind of behavior before. Time will tell if my butt dyno is calibrated right. I need the exhaust leaks fixed before dyno tune for obvious AFR related reasons - I repositioned the pipes but I'm not confident it's fully sealed even if it is better. At least the car does drive around while I cannot tweak/tune it for now. And I have aircon again. medium success!
    • Don't use that manifold. Please don't use that manifold. Sunk cost fallacy is not worth the later pain. None of these will be relevant to the change that will come from the different turbo and manifold. As in, the effect of the exhaust will be nil, regardless of what else is changed. And all the cam and fuel system stuff is not changing either way, so has no effect. The turbo and manifold (and to a small extent the wastegate)....big change.
