reviving an old topic :action-smiley-069:
decided to give the plastidip thingy a go today, did my front grille and rear diffuser. The grille turned out okay..got a few small run spots if you look close but from far it looks good imo. I did 4 layers on each with 1 can which was almost empty when i finished. The diffuser didn't turn out as good as i wanted it to be but being first time i think it was okay...will learn from my mistakes i guess. Anyway pictures say more than words, here's a few pics i took along the process (only took a few as i was racing against daylight to get it finished.
Grille (was a bitch to take off lol..)
after
Diffuser
i was bit paranoid about overspray...hence the ridiculous amount of paper lol
after....i ran out of sunlight :down:
dd94bc92-8da8-4ac4-98e1-c0a8075156dd-1.j
took me about 2 hours ish, that was including washing the car and prep work :happy:
after
Diffuser
Looks good.. :) Why do you think diffuser didnt come out good? I was thinking of doing the same so any tips would be handy.
Cheers
When you peel off the masking around the edges the dip tends to stick and wants to come off with it. I was being pretty careful but still left a few tiny spots on the edges. After some reading I found out you can either spray the coats on fairly quickly, don't allow it to dry and peel off the masking while its still wet, that way you get a smooth clean edge. Or, you can use a razor blade and cut alone the edges where it bonds to the tape and take it off that way, hope this helps. =)
Thanks mate, I ll see how I go.. :)
Chucked all that stuff on and removed the bottom resonater from the air box too.
Surprised at how much induction noise for a stock setup now :)
How do you take out the bottom resonater from the air box? Does it just come out or did you have to cut it off?
By the way are you referring to the part in this photo or is it at the bottom of the air box?
Thanks Locky.
Cleaned the throttle bodies of my 370GT this weekend, as I was experiencing idling issues (sometimes the car would stall...)
Bit of a pain to do if you can't remove your strutbar, but it makes a world of difference.
Mine was covered in black grime, and now its nice and golden..
mods i have done from then to now
Coilovers
19x11+15 varrstoen 1.1.2 (please don't hate on wheel caps came with the wheels :P)
JDM Double din stereo kit
Custom Y Pipe back exhuast system
Roof Spoiler
Hey Sarl,
Where did you get the varrstoen from? and what coilovers do you have? Did you have to roll your guards/ fenders with the setup?
Thanks
Hey Sarl,
Thanks
i traded my old wheels for them on gumtree, but ebay has a varrstoen seller which seems legit.
had some basic coilover i found on this page but might upgraded later on to bc's
all i needed to do was rolled the guards and had to shave a bit or my rear bumper lip inside and also camber
hope that helped rawzz
Bought a Greddy emanage ultimate with boost sensor, loom and laptop with software for the VQ25DET swap in my sedan.
Also bought a rare-ish woodgrain MOMO optioned steering wheel.
Did UpRev tune yesterday. Not too bad I think :)
Nice, workshop and details?
Pity the run rate is different on the runs. The curves aren't really comparable. How does it drive?
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
