my daily might not be so daily now....
twin 40DCOE webers
290/295 cams with .453 lift
spool rods
20" over bore pistons
11.63 compression
dual valve springs
roll master timing chain and sprockets
GTRsean special modded sump.....yet to be proven.
the original flywheel has gone from 7.25kg to 5.5kg.
exedy heavy duty clutch.
electronic optical ignition conversion, using 7M coil.
https://www.sau.com.au/forums/topic/415505-toyota-ke55-4kbecause-race-engine/
Check that sexy guy out!! :P
Oh and these engines are single cam, pushrod, non crossflow alloy head.
Cam will be on from 3500 to 7500RPM from memory. Can't go over 8000 for long periods of time as the blocks tend to crack haha....
Considering that the standard 5K that was in it put out 47 RWKW with the carbs slapped on and the existing 4 into 1 headers....I'm scared.
Still no brake or suspension upgrades yet......how not to do up a car, but makes you feel more alive :woot:
  • 4 weeks later...
When you said heavy duty clutch I imagined 2 bits of brown bread rubbing together!
Can't wait to see/hear the new motor up and running. Will need moar handling for sure!
close, it's slipping already. acts like a turbo but with none of the power. I am trying to organise it to be freighted from Sydney to Brisbane.
  • 3 weeks later...
