Hi guys,
Just had an intake manifold gasket replaced on my 33 GTR.
Now it it is running way too rich and needs retune.
I haven't had it long and suppose that it was last tuned compensating for the air leak.
Now it is running way too rich and after 10km or so the plugs become so fouled up it is almost undriveable.
It has a PFC of which I know little.
My question is does anyone know if there is a quick way of changing a setting or 2 on the hand controller,
or is a complete remap required.
Just so I can get it to the tuners reliably (and prior to that to the exhaust shop)
Otherwise its plugs out before each trip and then at the tuners.
Any help would be much appreciated
Cheers
https://www.sau.com.au/forums/topic/415530-pfc-question/
Settings
Ign/inj
Turn fuel down a couple but not too far.
Drive it gently to the tuners
When ignition is turned off it will ignore those changes and go back to how it was
Thanks for the reply
But what exactly does "turn fuel down a couple" mean
My battery is flat at the moment so can't check hand controller,
and I know Ign/Inj settings section, but can't picture the screen
So how specifically would I make the adjustment
Keeping in mind it as a temp fix until proper tune
https://www.sau.com.au/forums/topic/415530-pfc-question/#findComment-6667806
You can adjust fuel or ignition across the entire map. You will see how far you have adjusted it and the new figure it is currently running at.
Its pretty straight forward. Prob turn fuel down a couple (from 100 to 97-98) for example and see how it is.adjust more if necessary. Just be sure to take it easy driving there
https://www.sau.com.au/forums/topic/415530-pfc-question/#findComment-6667952
thanks man
will give it a go
https://www.sau.com.au/forums/topic/415530-pfc-question/#findComment-6671117
    • Yeah, the advent of canbus was supposed to cut down on wiring weight, then some bright marketing wonk says "oh, look at all these wonderful tech gadgets we can cram in here now that we have this wonderous technology" and some arsehole safety legislator says "oh, look at all the wonderful surveillance and tracking gadgets we can cram in here now that we have this wonderous technology" and some dipshit young engineer who has grown up thinking that an extra 500000 lines of code is not a problem because storage is cheap these days says "oh look at all this wonderful shit I can do to one up those dipshit arsholes over at VW" and the Karens of the world all go "oh look at all these fancy things I can do on my screen (so long as I am not driving on a bumpy road wherein touch screens immediately become the single most stupid shit idea ever shoveled into a car) and my 19 zone airconditioning keeps my sweaty fat folds a bit less damp and the windows close themselves because I'm too fat and lazy to wind them up for myself and these reversing sensors would have been great if I'd paid attention to them instead of smashing them on the bollard while I was reversing and staring fixedly forward that day I went to pick up little Charlize from ballet" and the sweaty mongoloids who say "oh this wonderful collision avoidance technology with these 45 excellent radar antennae scattered across the front of my car mean I can tailgate like a methed up tradie at full speed with no fear because the car and the 35 airbags will protect me if it all goes wrong" ...... </shallistopranting?>
    • There's a post from a member (can't recall who), went down the path of a twin scroll G30-660 and it's doing over 300kW+ AND comes on about the same as a high flow RB25DET turbo. Have your cake and eat it too in this case. TBH, if I had a 2nd chance of building my car again (i.e. someone gave me what I wanted for my shit box, but the deal was I had to re-build another R33 and keep the change) I would just pop in a stock NEO motor (with new seals, rod bearings, ARP studs, head gasket, sump, Nitto pump), get a smaller twin scroll turbo, modify the stock low mount (keep the divider in place), and make a solid 300kW on 98RON and call it a day.
    • It's all the sound deadening, and extra shit piled into them, plus all the extra (even though it's thinner) material for crumple zones. I can't fathom in modern cars why they need canbus to the headlights, and why the headlights must be vin coded on some cars to the ECU, BCM, and security module! Especially when they claim it's for security, yet, the canbus at the headlights let's thieves steal the car in minutes, so even more cars are being stolen! The Mercedes Sprinter 907 vans. They're a huge van, but a "basic" van. Yet they have that many canbus networks, plus two Lin networks, AND an Ethernet network. Logging a single network alone of 8 byte data frames, and they will generate a 20mb log file in 5 minutes. That's one network, and I can't remember the exact amount, but there's over 10 full CAN2.0B networks in them. I'm not a fan of modern cars, oddly, more and more I hate DBW, and all the bullshittery the cars try and interfere with. But all that bullshittery adds weight, plus crazy regulations on crumple zones, plus, ever picked a modern seat up, half of them have like 4 electric motors in them and will weigh 30+kg each. Then all the motors for things like adjustable steering columns blah blah blah. And did I mention the sound deadening so you can even hear an ambulance right behind you even if you 7.2surround sound is off?
    • Ah ok, yeah it should be flat, I believe the r34 battery tray has these 3 bumps in them they makes it line up and everything is flat, don't see how it would tilt if everything is secured.
    • Agreed it actively wants to kill you which I love driving fast cars slow is my stick
