This morning I took my sons wheel to Bob Jane (coz its close) to get a puncture repaired. And i'm going to need tyres when my wheels get here in a few weeks so I thought I might as well get a few prices. My wheels will be 18 X 9.5 so this is what he told me.
Pirelli $570 per tyre
Hankook $370
Falken Under $300
My question is what are your thoughts on all or one of these types of tyres or maybe even another brand. Start typing.
Thanks guys
Alan
https://www.sau.com.au/forums/topic/41556-which-tyres/
Falkens for under 300 are probably the 326s i have on mine ... not very good for a GTR... probably ok for a low powered gtst or a falcadore...
i have 18x9s... i got quoted 650 a tyre for michelon sport pros or bridgestone S03s.. or about 500 a tyre for Yoko ES100 (i think thats the model)...
Leaning towards the yoko, because i can't justify 2.5k on tyres...
https://www.sau.com.au/forums/topic/41556-which-tyres/#findComment-852066
I have got the Yokohama ES100s on my 18x9.5" rims. They fit real nice and so far have been a good tyre. As ferni sad the Falkens you were quoted on would be the 326s and I haven't heard anyone say good things about them. For an extra $100 a corner you could get the Falken ST 115, They are supposed to be pretty good. Alot of good things have been said about the Bridgestone SO3s and the Michelins also. It all depends on what you expect from the tyre, the size of your wallet and if you have a brand preference. I have always liked Yokohamas so it was either ES100 or V102 for me, and since the hole burning in my wallet was getting quite large I chose the ES100, and so far they have easily performed to my expectations.
https://www.sau.com.au/forums/topic/41556-which-tyres/#findComment-852232
no idea mate, i have not bought them in Australia b4. I used to run P-Zeros overseas in Malaysia. But looking at the Pirelli website, for that size, u'll be needing the P-Zero Asimmetrico tyres. Melb dealer is Bob Jane (03) 9329 6311 according to the page.
The P Zero system concept
- P Zero Direzionale front, P Zero
Asimmetrico rear
- P Zero Asimmetrico all round
PZERO DIREZIONALE™Size range
35
255/35 ZR20TL 97Y(J)
40
225/40 ZR18TL 88Y
235/40 ZR18TL 91Y
45
215/45 ZR18TL 89Y(F)
225/45 ZR17TL 90N2
245/45 ZR18TL 96Y
PZERO ASIMMETRICO™Size range
30
285/30 ZR20TL 99Y(J)
295/30 ZR18TL 94N3
35
265/35 ZR18TL 93Y(1)
335/35 ZR17TL 106Y
345/35 ZR15TL 95Y
40
245/40 ZR18TL 97Y
255/40 ZR18TL 95Y
255/40 ZR19TL 96Y
265/40 ZR17TL 96Y
285/40 ZR17TL 100Y
45
205/45 ZR17TL 88W
225/45 ZR17TL 91Y
245/45 ZR16TL 94Y
255/45 ZR17TL 98Y
255/45 ZR17TL 98Y(F)
255/45 ZR18TL 99Y
255/45 ZR19TL 104Y
285/45 ZR18TL 103Y
50
205/50 ZR16TL 87Y(A)
215/50 ZR17TL 91Y
235/50 ZR17TL 96W
245/50 ZR17TL 99Y
255/50 ZR18TL 102Y(1)
https://www.sau.com.au/forums/topic/41556-which-tyres/#findComment-852957
How about, if money is tight, Falken 451's. Theyre about the cheapest I would go and say 245/35/R18 all round shouldn't be more than $270 per tyre.
Theyre pretty decent for a cheap tyre and it will give you time to save up for your next set of better tyres.
https://www.sau.com.au/forums/topic/41556-which-tyres/#findComment-855970
I just bought Yokohama ES100s today, the guys are putting them on as we speak!. They are $255 per tyre, but I have stock rims so i had to get 225/50Z R16 92W.
I wanted to get 255s but they don't come that wide for a 16" rim. I wanted the 45 ratio tyre wall, but apparently for my type vehicle it is too small and illegal, due to the weight. Which i wound strange as it was 225/45Z R16 92W. But 50Z is ok.
The V102 was on an extra $50. I was considering these, but the difference is minimal and the ES100 is such a good performer that i could justify the extra $200.
https://www.sau.com.au/forums/topic/41556-which-tyres/#findComment-857831
I think the Toyo Proxies T1-S are a bloody good tyre for the price you are paying for them.
Great in theory but they dont come in 18's.
Big fella - it depends on funds but if it was me I'd get firstly the Yokohama AVS Sport (V102's) or else the Falken ST115's.
https://www.sau.com.au/forums/topic/41556-which-tyres/#findComment-857911
I have the top model hankook's on my R33 gts-t in 265/35-18. I think they are good, but not for a hy-po car. Maybe if I had about 180-190rwkw they would be ok, but with 210rwkw I find that I can't get any traction when I put the foot down. Will start another thread about my problem as I'm looking for a solution.
https://www.sau.com.au/forums/topic/41556-which-tyres/#findComment-864549
OK... time to tell my story.. my old man been in tyre business for 26 year nows, so therfore i have personaly try all kind of tyre which you can name it. For me my personal tyre is bridgestone which is value for money, but i have also try Pirelli before which is very good, even on the low end version (Pirelli), however because of the $$$ that y i choose bridgestone for my personal preference tyre. Yokohama well i have try the AVS which turn out "SUCK' as comparison to other brand for the same value.
https://www.sau.com.au/forums/topic/41556-which-tyres/#findComment-884536
Value and performance, IMHO the Toyo trapio TPG (GU:WN) is pretty hard to go past. Quite sticky wet and dry.
See if you can get 245s fitted, 'but I have 9.5 inch rims, 245s wont fit' think again. I have seen them on a 10" rim. If you go slightly undersized on the tyre, it will give more rigidity to the sidewall, giving a better feed back and more stability on the road.
Yet another opinion, have fun making the selection. :D
https://www.sau.com.au/forums/topic/41556-which-tyres/#findComment-885690
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
