Hey guys.
I thought this might be a cool thread for us Canberrarians to have.
There's one of these in the NSW section that I keep hitting up but meh... you know...
Canberra aint NSW!!! sooooooooooo... HAVE AT IT !!!
What Did You Do To Your Car Today ???
I'll start us off with...
Pulled my New Bosch 044 fuel pump out (that I only put in last weekend) and re adjusted the mount to try to stop some of the stoopid noises it makes.
Wish I could say I had a GTR to drive to work !
But yeah, still is the best thing to put a smile on your face when doing the work commute.
The RB Growl FTW !!! :woot:
New N1 water pump, 100,000km service,
N1 water pump? i was gunna get one but the bloke at kudos said they dont cavitate at high rpm, but they dont flow much at low rpm
I hope you have a good temp gauge
Did you do it yourself? if so was it difficult?
Or where did you get it done? how much did they charge?
Over the last week
Fixed the boot so it's now flush with the rear qtr panels.
Changed the black bonnet back over for the blue one.
Cleaned up the engine bay a little. Painted some stuff black that looked out of place.
and I polished up the RB26 timing cover I bought off another member.
oh and cleaned it. Wash, Clay bar, wash and waxed it 3 times. OCD or what !!
Yes Kudos are correct N1 water pumps are only useful for cars that don't see a lot of traffic or have a very good cooling system. Luckily Canberra doesn't have lots of traffic and I have a very nice radiator plus the car rarely goes slow enougth for this to be an issue. On the other hand the car does sit at high RPM a lot of it's working life.
The standard temp guage works fine. Like any guage you need to look at it.
The installation requires the taking out of the radiator etc so a bit of work, cost me about 450 but I had a bit of other stuff done at the same time at Trojan.
The same thing I do to my car every day.
Nothing. Except maybe swear at it as I walk past it on the way to my van.
lol. Though I do have replacement headlights I need to polish up and fit, I have replacement driver's door window switches with plastic surround on the way that I'll need to paint when it arrives and then fit them, AAAAAAAAAAAAAAAAAAAND I need to start troubleshooting my misfire that's finally sticking around for good - starting with swapping the ignitor with another unit Richard has given me for troubleshooting purposes (hopefully it fits lol).
So you got it done! how bad was the old one?
whens the next outing?
well... I bought a Power FC, waiting for Ult tunes to call to say i can have it back. And looking for a decent boost controller.
Fingers crossed! I want a ride/drive!
Yeah id like to drive my own car as well. It's been what? 8 months?
I like the profec B. But only if you can find someone who knows how to install one :P
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
