Clues dear watson, and google images.
Headlight? thats 34 for sure.
He said gtr front guards and lipped rears.
The photo angle shows the rear guards arent pumped like a GTR
Elementary. :happy:
Yeah damn.. should have done my research before commenting. Sorry boiz
Swapped out engine mounts today.
It was easier than i thought it would be, the nut i thought would be hard to get to, wasnt. I could fit a ratchet handle in there.
Most of the time was spent fiddling with fitting lifting hooks and messing around with the chain. It lifted just high enough before hitting stuff.
Dropping it down without stripping the thread off was a little tricky as the mounts dont line up till its down, because its mounted in a v.
One mount was starting to peel off the rubber, still fairly solid, but not for long.
Seat and mounts come next week.
Ps thanks for the lend of the crane :thumbsup:
Luke, is your thermo running from a temp switch kit?
Or off the original harness?
I cant get mine to work properly.
got it all sorted.
I was pulling positive straight from the battery.
had to grab it from wires that came on at ignition.
so, now all good.
dont fret.
the black peeling is only paint.
they paint the entire thing, then the paint peels from the rubber when flexed.
dont fret.
No i mean the old one. One plate was starting to peel/split off the rubber.
I noticed as the weight came down onto the new ones, the paint cracked and flaked on the rubber part.
Edited by D.I.Y. Mik
Found that a standard power steering belt doesnt fit anymore due to my balancer :/tried a few different sizes yesterday, still no luck. back to autobarn today i guess :(
what balancer and car?
BNR32 ATI 1000hp.
You wouldn't know which one to help K_D out ?
thats why I asked.
someone sold me an ati for a 32.
ended up being a 33 pulley.
think the main difference is the ac.
will grab ps size in a minute.
still have to get out of bed.
    • You know, that is exactly the thing that I was thinking a coupe of hours ago. I even had a plan for a meme, involving one big one, another big one, and the Old El Paso girl saying "¿por que no los dos?"
    • NoS, 2 of the big ones.
    • Oh, that's grim. Something bad has been happening there.
    • Put an endoscope down the hole and saw this. Not quite all around the bore but a good 60% at least. Chin to the chest and towards further disappointments I guess.
    • 2 does "sort of" applies, maybe......but looking at what parts would be needed for the swap to get engineered, registered, and insured, and basically that's everything under the car, the modifications the make it legal would be problematic and horrendously expensive, all for a street car that just cruises around and hits a few twisty roads on the weekends Also, from looking at the NSW rules and Regs, with all modifications that is required just to make the car safe and not twist itself to pieces, and then actually get registered for street use, may still be impossible nowadays As for 1, when you add in a fresh engine, fresh transmission, rear cradle and diff, tailshaft, suspension, brakes, cooling, and all the other fabrication required, your probably looking at up to $100k to do it right, all for a 20 year old MX5 that is over engineered and you would never be able to actually use the power it has on the street, much like your beastie, which I love, but you actually track that thing and can use all of its powers in anger, in a safe environment  Hell, the old Bogan Cruise Ship had more power than I could use on the street, and in hindsight, I went a bit silly on that thing, it didn't really need the 500hp it had for what I actually used the car for, it was fun, but basically unusable on the street if you value your licence  As for cams, yeah, I'll probably book it in for them to get installed and tuned soonish, like next month after MX5 Mania are back at work....... and yes, I've already sent a email to bin the turbo quote and quote instead to install cams and a new Fluidampr balancer that will suit the 2.5 better than the OEM 2.0 balancer that is swapped over for the 2.5 install, as the balancer needs to get pulled to time the cams it's a while your in there sort of thing I did think a bit about flex fuel for a laugh, but being na, and no where really around locally anymore to get E85, I've binned that idea, so no sweet sweet corn smells are set for the car I wish E85 was more of a standard fuel, it's better for the environment, better for tuning, plus that sweet sweet smell we all love As for fitting in the family, that's not needed, as everyone in the family already owns a car that can seat 5 humans comfortably enough, the MX5 is "my toy" As for buying a car that is already built, nah, I would rather pick and choose my parts, I enjoy the process, and in the big picture, the additional cost is well worth the enjoyment, and the occasional frustration, I get out of doing it, albeit with other people spinning the spanners, and me, just paying the invoice 🤣
