Hmmm, i'm looking into getting one once my car is on the road.I am just going to box in my Pod filter.
In other news my o2 sensor, radiator hoses, thermostat and radiator cap arrived from kudos today so i'll throw them on tomorrow and do my timing and use your compression tester just to see how my motor is going.
An extra turbo, abs, etc...
No wonder they cost so much to do up, stuff would have to be custom made just right to fit in there.
but arent they wider?
engine bays are identical once stripped.
I wonder if its the same od as any copper pipe.
Then a plumber can silver solder in a new one.
Even put that lip on it.
Even if you get close, you can expand the pipe a little.
TBH what i might do is just leave it for the moment. When i did the water pump not long ago there was no corrosion in the block and now looking inside the block where the thermostat goes it's super clean, same with the new radiator. I'm sure it must be built in to be sacrificial. I need to running to get it to the panel shop probably next week to get it fixed up. Once it's back on the road I think I will just take it to a good radiator place and get the to do a professional fix on it. I flushed everything out anyway to be sure and pretty much all the bit of the pipe were in the hose. *sigh* nissans... fix one thing find another, at least i found it now and not when it exploded in the middle of summer.
Ring Andrew @ Kudos. The whole unit will either be $50 or $80.
Depending if inlet or outlet.
This be common across the entire Skyline range.
Has to do with silly Japs and the coolant they use (or don't use) and composition of the part.
Kasko had the same issue. Hammered in a piece of pipe.
John (Trojan) found the same with mine. Cleaned it up and reckoned it will be fine with proper coolant/distilled water.
Hmm - not like Andrew.
Tell him to pick his game up :P
haha yeah he was like "I have sent you GTR hoses by mistake, they are not going to fit at all"
He also said Nissan don't have that inlet piece as a serviceable part but said he would look around for me and get back to me with an answer for that as well as when he can get me new hoses. I might get my self one of those anodes as well. My drain plug comes from the side though, not the bottom so i would probably have to shorten the zinc rod.
Yep already spoke to Andy about it.
I ended up going to Nat Rad and they cut me up a bit of pipe that a bashed in.
Mine was super super rusted so it was easy to get out.
Andy explained me that he couldn't even remove his with vice grips.
So a little different to mine.
I have cleaned it up best I can, it's not super corroded so i will chuck the new thermostat in and get it running just so i can get it to the panel shop then as soon as it's out i'll take it to a shop who can get it out, replace it and do a proper job, i don't really want to cut corners on my cooling system.
remove the blade from your hack saw. Then cut the inside of the pipe till you reach the outside housing that holds the pipe. If you tap it the pipe should buckle inwards then it should be easy to pull it out.
So thats gearbox oil, diff oil and exhaust polish done today :D
Whoever did the gearbox oil last time definitely made sure the plugs were tight... They were a real pita even with a breaker bar... :angry:
At least gearbox feels a lot nicer now, will be interested to see how it feels cold mornings now.
    • All I can say Duncan is good luck and I hope that Neil did not run any E85 in Cheryl. I have recently experienced the full spectrum of fuel tank issues in my R33's that had been caused by E85 and contaminated fuel. When you take the cover off the top of the tank and have a look inside you will get an understanding of how easy it will be. Best case situation is clean fuel with minimal contamination. My GTR was like this and it was a very simple operation to just grab the fuel pump carrier bracket and slide it up and out of the tank. My three GTS_T's had different levels of fuel contamination that was probably caused by E85 in the fuel.  In the worst case all of the metal components in the tank had rusted to the point where there were pieces of rusted metal swirling around in the tank. This required the removal of the exhaust, the tailshaft, the complete rear cradle and the fuel tank. The components in the tank were that rusted that it took days to get the fuel pump carrier and the mounting brackets out of the tank. When the tank was finally cleaned, everything inside the tank had to be replaced. With the tank all back together I could then reinstall it in the car along with everything else that had to come out. Good luck and I hope that you find a clean tank.
    • It is a two door. It is black and also still has the OEM wheels and stereo. Exact model would be KR_R32RGFEL_SS According to GTR-Registry.com is a 2 Door Coupe; RB20DE; 2WD no HICAS; MT.F5; (11L) Projector Headlamps and Fog Lights; (12_) Electronic Active Full Auto Air Con (Climate Control); (13-14SS) V Selection -- Which seems to be accurate description of my variant. Will try to upload a few pictures soon. The OEM wheels look like the below image. Image is taken from the goo-net-exchange website.
    • Time: Saturday 18th January - 9am -10:30am Where:  Cafe By Lamanna 10 English St, Essendon Fields VIC 3041  - https://g.co/kgs/mhVKvAB Registration: So we can give the cafe a heads up on rough booking numbers please rsvp below Registration Link: https://forms.gle/wPtfj9Gp8bvCiouo8
    • Welcome Gabriel. At least your car has a glorious RB and not the shitty CA18. As MBS206 mentioned all the good bits can be added later. Two doors or four?
    • And half of them have been converted to turbos.
