So I took my car over to everyone's favourite inspection pit. The reaming wasn't that bad. All that failed was rolling diameter and tyre load (easy fix, borrow stockies will good tread and correct load rating). Insufficient ground clearance for the exhaust, yet surprisingly the Db was right on the limit, so I'll just borrow a stock exhaust from Trojan. Left hand CV boot on driveshaft was split. I just need to put child restraints in, the centre rear seat belt was missing, but it was just hiding behind the seat. Finally the engine tune up sticker.
I hope that this isn't the start of their little games they seem to play with everyone. But time will tell I suppose.
So, key has been filed, taken back to cutter to tidy up/file down some more..
now works well in drivers door and ignition, but not at all in boot or passengers door.
Thinking (suggested by key cutter) that locks are worn as well as key, making it near impossible to cut a new key to work properly....
Will now be contacting auto locksmith to see about getting a key cut from the barrel or seeing if they can be fixed to suit a new key..
On the upside, got instructions on how to get my 2nd alarm fob re-synced to the alarm so both will work =)
Maybe if you smile and wink nicely at them they will take a liking to you.. :wub:
My fun for the next couple of days.
If anyone gets bored there will be beers and swearing when i break things.
My can of rost off plus came in time so fingers crossed i wont be snapping any bolts or studs.
Edited by azathoth
NEW TYRES!
What did you get? I'll need some too for rego, I have 245/40s ATM but thinking of going wider, I was looking at federal ss 595's but not real sure either Edited by gtr judd
Cleaned the Engine bay a bit more too...
New stickers on the wheels looks great! ive ordered another 8 as i think they will come off. Am getting the wheels re done soon so ill get them stuck on under the clear coat.
After failing to install cusco front upper control arms (http://www.skylinesaustralia.com/forums/topic/435067-cusco-arms-install/) I popped over to Andys and picked up some 34 gtt seats I bought off him. Bloody legend. Passenger seat was in great condition so I swapped those cushions over to the drivers rails and set on trying to make it fit the 33. Couple of hours later we had 3 of the mounting points firmly mounted and will get a mate to weld a bracket onto the fouth mount so that it lines up with the hole. Will grab some pictures later :)
  • Like 1
Got the wheels on and the cooler sitting up and forward so it's perfect. Soaked the manifold turbo and dump botls multipe times with rost off.
Went to quickly put the bonnet struts on with a mate before pulling the turbo off so i had all tomorrow to put it all back together and my mate was loosening off a nut on the accident side on the bonnet and "POP" sheered off...Thought i could just pull the stud out and put a new one in...no such luck. It's captice inside the skin of the bonnet....just feel exhausted and defeated. Left my beers over there too.
Oh well, back into it tomorrow. I'll work out a fix to get it to the panel shop...might have to pay for a tow or something.
  • Like 1
Best thing I did to my car so far today was chuck it from 4th into 3rd at 80kms/hour and flog it up to 120 on the Hwy.
Made me smile after visiting my Dad.
Love my Car. oh and that guy ^^^ too.
  • Like 1
255/40R17 all round.
Put new steering wheel on yesterday. Awesome!
Wasn't quite straight so pulled it off to move it a bit left and broke a wire in a connector plug. :(
Can't fix so replaced with a better quality wiring job. Took a while.
Then had another shot at fitting bonnet struts after mik did some grinding of the brackets for me (Quality work MiK).
Bonnet still doesn't fit quite right, raise by almost .5cm half way down tried a fair few things, so removed the struts and will work on it later.
Then went to secure wiper cowling correctly with clips to find it had snapped on one end
will need to get another one :(
Gave up and cooked while watching TV.
  • Like 1
not ss range, not good. Slippery as
595 RSR's :thumbsup:
Thank you sir :) I'm always up for advice
Yea I was thinking 255s or 265s, not sure if the 265 would fit, have to check the offset.
Also mine are 18s :)
265's will scrub with Federals ( the rules that govern tyre size variation allow a 10% difference - Federals are close to the max allowance for this type/brand)
255's are Ideal :D
Even rolling the front guard will not help. It scrubs on the inner plastic guards.
(18x9.5 +12) I had new 265's for a few weeks then bought 255's and onsold the 265's
Perhaps if your offset is +20 or +30 it may be different, I can't say - your choice.
Just sharing my experience. (and some pics)+((coz like showing the girl off))
I spent yesterday pulling the supercharger off and putting a standard intake back on thw silvia. Somewhere between driving it home and starting it again I've lost tail lights...
Will be interesting to see how it goes N/A with 8.5:1 compression, 1000cc injectors and eflex :P
    • Hi soviet_merlin, We appreciate your concern regarding this possibly being some sort of PR/Political hype, I assure you that is not the case, I wish we could claim something like that, but in this case, we merely reached out for comment on the basis of the outrage we too felt, as those heavily in the automotive industry. Ps. the original source in the social media post is CarExpert not CarExplore.    Best, CE.
    • Made a bit of a discovery, but while I was cruising, I randomly decided to test to see if it worked and it showed up on my IC7. The entire time I tested it before, I never thought to turn the ignition on. I only tested it with head lights turned on but with the ignition off. Huge oversight on my end. I’m a dummy. I know.
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
