Some more midnight madness......
These bits get welded once the final tension is found.
What is it? Its for mounting a window net without a rollcage.
And, yes, check the CAMS manual, you can do it.
After seeing the V8 180sx mounts put on with tek screws i decided my way wasnt so bodgey after all.
Some strong upper mounts bolted onto the box section above the drivers window. These will have covers, so they are safe.
And the bottom bracket gets hidden behind the doortrim. Ill have a door and slot for the net to come out of the trim.
post-89755-0-86799700-1386314505_thumb.jpg post-89755-0-84508800-1386314521_thumb.jpg
Put wheels on SkyWagon. Bought them yesterday and got my spare tyres put on today.
No More Lending out my R32 GTS-t rims with Roadworthy tyres. But I can lend the rims. :laugh:
Needs moar low :P
But seriously, she's lookin' tidy :D
Edited by dontyellpl0x
ok. :/
:D
From our discussion it seems to be quite a quick and easy job (putting some T hose thingy in and 12PSI). If this is not the case and it requires more time. then, of course - when it suits you best. No fuss.
Edited by RosieR34
Yeah it should be quickish and yeah I gotta spare turbo.
Yeah yeah yeah. :nyaanyaa:
Not Tomorrow.
That sure was an unfortunate stroke of luck. :/
No worries - give me a holla.
Yeah well depending on what the quote comes back as i might just get a new box. Clutch i do want though... we will see.
if your gonna pay 5-7k might aswell get a GETRAG dogbox, IKEYA FORMULA or OS Giken they come with clutch and a new drive shaft aswell.
Thats 10k plus for just an os gearset in the standard box.
    • Me coming to check the thread to see if my manual boost controller was set up correct......
    • Ah yes but were you responsible? In the time I've had it (just before Christmas) I spun off the track twice and drove into things twice, so four separate incidents.. in two outings. Luckily I have a full OEM GTR front end to put on which is hopefully not a precursor for further, future, more expensive mistakes to come. It is some consolation that anyone who would want to buy my Altia bar would have to paint it anyway, the guards, too. (if they can get over the asymmetry). Hopefully over the weekend I will disassemble and see how badly things are bent. From what it looks like, the headlight has actually just been pushed back and bent the headlight support (which .. somehow... crushed the guard in). I guess the headlight plastic is strong stuff.
    • These things happen And I believe "we, the people, who modify stuff, and actually use it, cannot have nice things" It's just a shame that it happened so soon after paint  I still win the award for quickly destroying newly painted panels I think, as my car came back from the paint shop all nice and shiny, until about 4 hours later when the boot was destroyed by a wayward locker that was blown around by the wind.... What doesn't kill you makes you stronger, and poorer.....dooh
    • This. And also, the rotor thickness is constrained by the calipers. Cannot be much thicker, if at all. Cannot be much thinner, if at all. New rotors are....fairly cheap. Turbo calipers can still be picked up for sensible money. Arguably, the best thing is to get R32 calipers and put them on mount spacers on 324mm discs. That's about the cheapest and easiest way to get quite large brakes that are essentially bolt on. And that's despite maintaining for years that the R32 calipers are not the best choice because they seem to be more flexy and creaky than the others. If you were prepared to put up with nasty little NA sliding calipers, these will still seem like Brembos by comparison.
    • A quick Google said 297mm..
