Booked the SkyWagon in for Rego re-inspect and wheel alignment for Wednesday...
Reattached the Passengers Rear view mirror after doing the Superglue Repairs to the mounts.
Also Received and installed a Brand New Clutch Fan in SkyWagon. Much Quieter now. :D
Very glad I did this as on Removal of the old fan, I discovered that there are cracks at the base of every single blade.
Just a matter of time before she went kablamo!!! :O
post-78856-0-94911100-1389592995_thumb.jpg post-78856-0-72397800-1389595197_thumb.jpg The worst crack.
Started the stripping down.
Skirts, pods, doortrims, mirrors, doorsills and seal gone.
Got to take off the rear bar and wing, then i can wash everything.
Im going to try black in the doorgaps and under the boot, its already under the bonnet and in the engine bay.
That way i dont have to do so many coats where its going to be a pain, eliminate runs, also i can leave the doors, bonnet and boot on.
Also all the "utility areas" like in the wheel arches and underneath will be black.
"Raceday" bits will also be black: vented bonnet and guards, diffusers (gotta make em first) and a big wing.
Ps: Thats like my old Celica, thanks Hotwheels.
same colour too.
Edited by D.I.Y. Mik
did some brain surgery on my speakers ( Trojan broke them ) they are workingnow, tho cant put them in the parcel shelf, any ideas? maybe fiberglass them in the boot somewhere with the sub?
just made a template for putting the speakers on the battery cover thing, worked well... until I put the speakers in not knowing that the shelf for the battery is a lot higher then I thought.... turned out the speakers wont go there
<br /><br />Your in luck I have a magnetic snapon tool used for removing the collets.I used it when I was changing the stem seals makes it easy.<br /><br />Also with the nitto head drain have you tapped it into the Welsh plug or removed it completely. Are you locating the drain pipe to the exhaust side of the sump or intake side.? Did you also put the restrictor on the block.
The nitto head drain requires you to remove the welsh plug and drill and tap the head. I did do the restrictors as per the oil control thread and opened up the head and block oil drains. Not sure on valve springs yet.
Took my car out for a drive and i got break down on tuggeranong parksway. got it towed home and started working on it
so now the car will be off the road for a while, lucky the rego is expiring next week
Water pump is leaking as the bolts are the otherway around
My power steering oil line was leaking for a while and all the oil were on the air con compressor as its right under the power steering pump, so today it started burning the oil and smoked heaps when drove the car with air con was on max for a while as it was not blowing cold air. Also the air con compressor is making a lot of noise. need to be replaced.
going to do the timing belt as well with the water pump (100k service)
Put my plazmaman intake, throttle body and z32 AFM then get it tuned.
Edited by 5hiv
