Sau A.c.t. - What Did You Do To Your Car Today?
Booked the SkyWagon in for Rego re-inspect and wheel alignment for Wednesday...
Reattached the Passengers Rear view mirror after doing the Superglue Repairs to the mounts.
Also Received and installed a Brand New Clutch Fan in SkyWagon. Much Quieter now. :D
Very glad I did this as on Removal of the old fan, I discovered that there are cracks at the base of every single blade.
Just a matter of time before she went kablamo!!! :O
post-78856-0-94911100-1389592995_thumb.jpg post-78856-0-72397800-1389595197_thumb.jpg The worst crack.
Started the stripping down.
Skirts, pods, doortrims, mirrors, doorsills and seal gone.
Got to take off the rear bar and wing, then i can wash everything.
Im going to try black in the doorgaps and under the boot, its already under the bonnet and in the engine bay.
That way i dont have to do so many coats where its going to be a pain, eliminate runs, also i can leave the doors, bonnet and boot on.
Also all the "utility areas" like in the wheel arches and underneath will be black.
"Raceday" bits will also be black: vented bonnet and guards, diffusers (gotta make em first) and a big wing.
Ps: Thats like my old Celica, thanks Hotwheels.
same colour too.
Edited by D.I.Y. Mik
<br /><br />Your in luck I have a magnetic snapon tool used for removing the collets.I used it when I was changing the stem seals makes it easy.<br /><br />Also with the nitto head drain have you tapped it into the Welsh plug or removed it completely. Are you locating the drain pipe to the exhaust side of the sump or intake side.? Did you also put the restrictor on the block.
The nitto head drain requires you to remove the welsh plug and drill and tap the head. I did do the restrictors as per the oil control thread and opened up the head and block oil drains. Not sure on valve springs yet.
Took my car out for a drive and i got break down on tuggeranong parksway. got it towed home and started working on it
so now the car will be off the road for a while, lucky the rego is expiring next week
Water pump is leaking as the bolts are the otherway around
My power steering oil line was leaking for a while and all the oil were on the air con compressor as its right under the power steering pump, so today it started burning the oil and smoked heaps when drove the car with air con was on max for a while as it was not blowing cold air. Also the air con compressor is making a lot of noise. need to be replaced.
going to do the timing belt as well with the water pump (100k service)
Put my plazmaman intake, throttle body and z32 AFM then get it tuned.
Edited by 5hiv
 Share
    • As someone who has been playing with turbo things for some time now, be prepared for this to not be the first time feeling this way    I'm busy as atm, but if no one else covers the things I'm realising are worth mentioning to you then I will when I have a chance as it seems like I overestimated your knowledge on how turbos and wastegates work.  Otherwise I recommend having a look around how wastegates and boost control work, really anything on understanding the general mechanism of boost control as it will help you find the answers to the questions you're looking for.  Your initial question jumps some fundamentals.
    • I don't understand anything anymore.
    • so this is an anomaly??? I thought it was a voluntary increase
    • we can only guess exactly what happened from our keyboards, but to me it looks like they were targeting 27 but the wastegate was too small or poorly controlled and the boost crept up, that is quite common
    • Good points!  Took those for granted - though I *did* actually give an example of winding boost up more than it had been before where I wasn't actually specifically looking for more peak power.  The Toyota Starlet dyno plot that I shared and mentioned showed an overlay from the previous tune it had and the one I'd redone, I left the boost targetting the same as the old tune but then after peak power I ramped boost up by a good 5psi or so over what the old tune had at the same rpm. The reason I felt comfortable with this (though the owner of the car had a "are you sure?" moment when I suggested it) is that the setup wasn't turbo limited, it was largely head sealing limited and the owner was a bit concerned as for the last few seasons he'd had issues with head lifting - sometimes not completing an event without having some headgasket issue, so he didn't want to run any more boost than it was. The reasons I was ok with raising the boost a good 5+psi MORE than that was that I left it where it was in the middle, and only increased it where VE (and therefore cylinder pressure vs psi) were dropping hard and I didn't stop the torque from dropping, just reduced the drop.  Well, there is that and the fact that the previous tuner had it overtimed by near 7degrees at peak torque - but that's another story haha.    I didn't really go into detail about that "turning it up more" thing but now you've mentioned the "not detuning", sometimes the boost *can* be turned up higher than you'd expect if the setup allows for it and you do it smartly.  I've tuned things to run 30psi on BP98 "safely" that a few years ago (or still?) people would cry that it was a stupid idea - but given they were well intercooled, low EMAP turbos and only doing that kind of boost where VE is dropping etc I was pretty confident it wasn't as cowboy as it sounded at face value and we never ended up with issues as a result of it.
