Went over Dickson today.......
FAILED lol which I knew I would. Got kncocked back on minor things
*horn wasn't working (which it did on the way there)
*upper inner control arm bushes
*radius rod bushes
*1xCV boot in front was split
*both rack boots were split
*tyres
And an advisory on noise and height. They are both right on the legal limit
So not too bad at all
Looks Tasty Anfanee. :)
Today I received in the mail...
An Old School Metal Datsun badge that may or may not end up on the SkyWagon and a Spare R31 Auto ECU which may or may not fix the intermittent Fuel Pump Priming issue... Both off Ebay, both very cheap.
I cut up, painted and fitted a piece of PVC pipe to straighten out my air intake.
Played multimeter games with the TPS to try to fix an acceleration flatspot.
Disassembled and cleaned my spare AAC valve and installed it, had to bleed the air out of the cooling system, fiddled with the TPS some more and checked timing again. (still needs more TPS fiddling) :/
Nice straight intake (removed the weirdass bends)
Now with ^^^ GT badge in grill.
Clean vs Dirty AAC valve.
dirty vs clean where the AAC bolts on.
post-78856-0-75338900-1389860946_thumb.jpg post-78856-0-42800400-1389860970_thumb.jpg
something very interesting just happened
Dad comes home from work saw me working on my car asked me whats wrong and did i found out what was the problem with the car, i told him off that its not his business and its my car i will fix it whenever it breaks down and i dont need his help. Next minutes he packs all his tools and locks them :(
Lucky i did managed to get a few things off the car. But now i need to find a new job and buy some tools and finish my car.
Here are some pic i took of what i did today
im yet to use dads tools, im sure he would do the same... I don't get why he spend so much on his tool and tool box, he owns a brand new fiestia ST and doesn't work on it, tho he did mention something about restoring a 1955 f100.
post-127489-0-84733600-1389865310_thumb.jpg this but chopped and matt black...
Edited by ..::R33GTS-T::..
I must admit. If my son talked to me like that I wouldn't just lock my tools up. I'd be packing his bags for him and kicking him to the curb :P haha
I feel your pain about a new job. Hard to find decent work with a decent team. Goodluck with the car - hopefully it can come to the next cruise.
Agree with you RoseBud. :yes:
Hmmmm... Make peace with the Old man mate, He has the mechanical Knowledge, the Tools, the ability to make life hard for you and Your Balls in a Vice. :P
as my Dad said many times over... You live under my roof, you live under my Rules.
  • Like 3
So the next question....
Do i order new seat covers with the money from the bike? :woot:
these ones...
nengun-4323-06-nismo-skyline_gtr_r32_sea
Are they leather seat covers? Or an actual leather seat? They look nice regardless.
    • S2/3 GT-R is the same as S2 GTS-t The SRS airbags module in under the centre console. The S1/S1.5 GTS-t and S1 GT-R had the module built into the steering wheel. FWIW, I have a S3 GT-R wheel in my S2 GTS-t shit box. Same airbag plug, airbag light goes on then off, meaning all systems are go. S3 GT-R has red stitching, that's about it.
    • Dumb question, but why would it matter if the wheel came off a car with hicas or not?
    • Hey to anyone that reads this, long time lurker first time posting, sorry if it’s been answered before but I’ve been looking for nearly a year now for answers. ive got a 25det neo in an r32 that works awesome when it works (made 500whp on 21psi) but works 45% of the time, 1st issue there’s a harness that runs under the passengers side front fender that my tire keeps rubbing through and one wire seems to power the fuel pump even though I’ve done the relay “mod” some people like to call it, and when it does rub through it kills the car, yes next time I’m with the car I want to take the fender off and try tuck the harness well out of the way but I’d also like to try and by pass this mysterious wire as well lol, also wouldn’t mind getting power from the alternator as I’ve read it supplies the pump with 13v ? But no idea where to run the power wire too. 2nd issue, when replacing my fuel pump and fuel hanger I managed to break the factory fuel level sender leaving me with no fuel gauge, I’d like to buy the fpg fuel level sender for r32/s13 but the plug it comes with confuses me, I’ve got a detschwerks x1 fuel hanger which has light + pump - level + pump + and a ground, I’m no auto sparky but I’m wondering if I can cut the plug off the fuel level sender and wire the negative to the pump negative and wire the positive to the level positive to get a fuel gauge back ?🥴 3rd and final issue, the reason I want a fuel gauge is because whenever it’s below half a tank, it fuel starves like crazy and runs like a bag of shit even without doing a pull or sloshing the fuel round in the tank, I’d also like to fix this but have no idea what’s causing it, I’ve got a dw420 and a dead head fuel setup meaning the fuel is regulated before it gets to the engine, my only theory is that the return line is to close to the pickup on the pump and when it’s at half a tank the return line is causing the pump to cavitate enough to cause fuel pressure issues, that or the pump isn’t low enough in the tank which I would find strange considering I can’t find a single thing online about it, also if ya wondering how I figured out it happens at half a tank without a fuel gauge, I waited until it started happening and went and filled up and the car took exactly 30 litres every time I tested it, if ya managed to read through this mess I appreciate that and any recommendations , cheers
    • ChatGPT is trash and lies about things I would not expect it to lie about considering many things it's wrong about are very easily verified with google. The S3 R33 GTR shares its steering wheel with R33 GTSTs of the same production year. Part number is 48430-26U17. I'm guessing you have to get it from a car that came with HICAS though, the ER33 is 48430-26U18, but the HR33 diagrams note that part number is still leather vs 48430-26U13 which is not leather-wrapped. They all use the same airbags, so if you need another one you can get it off basically any same year R33 or Stagea.
    • I'm going to run hard lines front to back in the future. That should help dissipate a bit more heat. If not, a fuel cooler might be next
