5hiv Posted January 16, 2014 Share Posted January 16, 2014 You don't shit where you eat from 5hiv. So is it the AC compessor gone? haha Yes the AC compressor is dead. I knew that was the problem could have just cut the belt off and drove around with no AC 1 Link to comment https://www.sau.com.au/forums/topic/415573-sau-act-what-did-you-do-to-your-car-today/page/165/#findComment-7171939 Share on other sites More sharing options...
Got a Pulsar Posted January 17, 2014 Author Share Posted January 17, 2014 Today... Swapped my Spare ECU into the Wags. (didn't fix the Intermittent Fuel Pump Priming) Replaced a Green Relay in Behind the ECU which apparently pretty much controls everything. (May have fixed the priming issue) Chucked in 2 spare Old Coolant Temp Sensors. (bled the air out) Cleaned the AFM. (again) Pulled out and cleaned the O2 sensor. Tightened a couple of Rocker Cover Screws. (near Exhaust Manifold) Removed the Exhaust Manifold Heat Shield and found the main Exhaust leak. (Pretty sure there should be bolts in these holes) Link to comment https://www.sau.com.au/forums/topic/415573-sau-act-what-did-you-do-to-your-car-today/page/165/#findComment-7172874 Share on other sites More sharing options...
Sinista32 Posted January 17, 2014 Share Posted January 17, 2014 Replacing gasket and studs? Link to comment https://www.sau.com.au/forums/topic/415573-sau-act-what-did-you-do-to-your-car-today/page/165/#findComment-7172886 Share on other sites More sharing options...
Got a Pulsar Posted January 17, 2014 Author Share Posted January 17, 2014 When the Extractors go on. Link to comment https://www.sau.com.au/forums/topic/415573-sau-act-what-did-you-do-to-your-car-today/page/165/#findComment-7172895 Share on other sites More sharing options...
Sinista32 Posted January 17, 2014 Share Posted January 17, 2014 awesome Link to comment https://www.sau.com.au/forums/topic/415573-sau-act-what-did-you-do-to-your-car-today/page/165/#findComment-7172910 Share on other sites More sharing options...
D.I.Y. Mik Posted January 17, 2014 Share Posted January 17, 2014 (edited) More jobs for the thread repair guy Just make a list, get them all fixed at the same time, so its only one callout fee. Did nothing to mine today.... too hot, later tonight when the little terror is asleep, ill take off the rear bar, tailights, do the last of the vynil stripping and the door rubbers have to be carefully removed. Then its ready for final clean and de-waxing, especially the edges and where the rubbers were. The list of sht to do, to prep it for paint is very long. Lets see how far i get before the missus realizes what im doing. Edited January 17, 2014 by D.I.Y. Mik Link to comment https://www.sau.com.au/forums/topic/415573-sau-act-what-did-you-do-to-your-car-today/page/165/#findComment-7172922 Share on other sites More sharing options...
Got a Pulsar Posted January 17, 2014 Author Share Posted January 17, 2014 Hahaha... you're a brave man Mik. Go for it. Link to comment https://www.sau.com.au/forums/topic/415573-sau-act-what-did-you-do-to-your-car-today/page/165/#findComment-7172938 Share on other sites More sharing options...
dontyellpl0x Posted January 18, 2014 Share Posted January 18, 2014 Tried to reduce scrubbing.. Tend to get a little bit on crappy roads... Moulded the front splash guards with a heat gun. Raised the rear of the car about 5mm.. Was going to wash it but I think its going to rain at some stage over the next 24 hours.. Fingers crossed anyway Link to comment https://www.sau.com.au/forums/topic/415573-sau-act-what-did-you-do-to-your-car-today/page/165/#findComment-7173352 Share on other sites More sharing options...
Sinista32 Posted January 18, 2014 Share Posted January 18, 2014 Detailing the Swift - Typical bloody thunderstorm then hail ! (x2) Had GTR up the top with the 34. Started to rain, then hail. First put a doona over the GTR bonnet then Kicked swift out of garage and moved the GTR just as the 2nd hail storm hit. Was over quick. Shuffling cars what a pain. Also had Shawty's magna here trying to fix the rear drivers side window. Wont go up. Had to tape garbo bags over it. Link to comment https://www.sau.com.au/forums/topic/415573-sau-act-what-did-you-do-to-your-car-today/page/165/#findComment-7173499 Share on other sites More sharing options...
zebra Posted January 18, 2014 Share Posted January 18, 2014 Did this a couple of days ago 2 Link to comment https://www.sau.com.au/forums/topic/415573-sau-act-what-did-you-do-to-your-car-today/page/165/#findComment-7173502 Share on other sites More sharing options...
..::R33GTS-T::.. Posted January 19, 2014 Share Posted January 19, 2014 Did this a couple of days ago good work man! looks nice today I changed the plugs and cleaned the vallycover/rockercovers plugs 1 through to 6, kind of glad I changed them! they look a ton worse in person :| Link to comment https://www.sau.com.au/forums/topic/415573-sau-act-what-did-you-do-to-your-car-today/page/165/#findComment-7173882 Share on other sites More sharing options...
zebra Posted January 19, 2014 Share Posted January 19, 2014 Thanks man, Today..... Pumped front and rear guards. Changed front pads Raised front suspension up 10mm Bled brakes Discovered 265 tyres on 10" rims fit inside pumped front guards Still have soft brake pedal Time to have fluid changed and pressure bled. Link to comment https://www.sau.com.au/forums/topic/415573-sau-act-what-did-you-do-to-your-car-today/page/165/#findComment-7173893 Share on other sites More sharing options...
Got a Pulsar Posted January 19, 2014 Author Share Posted January 19, 2014 Agree with above. Soarer looks Tough! What are those wheels + sizes etc...? Today SkyWagStag got her much needed new thermostat and Coolant after a good hose flushin'. But now my temp gauge in the cluster doesn't work. Also played more AAC, TPS, Throttle stop adjust games and may have hit the sweetspot. No more chugga lugga when floored from a standing start. Woot! I tells ya. While out in the 33 I had some Dude in an Audi SUV thing rip past me in Fury as my relatively cheap old Skyline formed one lane before him. Sucker. Link to comment https://www.sau.com.au/forums/topic/415573-sau-act-what-did-you-do-to-your-car-today/page/165/#findComment-7173941 Share on other sites More sharing options...
THE34T Posted January 19, 2014 Share Posted January 19, 2014 Link to comment https://www.sau.com.au/forums/topic/415573-sau-act-what-did-you-do-to-your-car-today/page/165/#findComment-7173946 Share on other sites More sharing options...
Got a Pulsar Posted January 19, 2014 Author Share Posted January 19, 2014 Precisely. Link to comment https://www.sau.com.au/forums/topic/415573-sau-act-what-did-you-do-to-your-car-today/page/165/#findComment-7173952 Share on other sites More sharing options...
B-rice Posted January 19, 2014 Share Posted January 19, 2014 Q7's are beasts same as an X6. Insanely quick for SUVS Link to comment https://www.sau.com.au/forums/topic/415573-sau-act-what-did-you-do-to-your-car-today/page/165/#findComment-7173960 Share on other sites More sharing options...
Got a Pulsar Posted January 19, 2014 Author Share Posted January 19, 2014 Not sure, but whatever it was, it wasn't quick enough. Link to comment https://www.sau.com.au/forums/topic/415573-sau-act-what-did-you-do-to-your-car-today/page/165/#findComment-7173972 Share on other sites More sharing options...
zebra Posted January 19, 2014 Share Posted January 19, 2014 Agree with above. Soarer looks Tough! What are those wheels + sizes etc...? Today SkyWagStag got her much needed new thermostat and Coolant after a good hose flushin'. But now my temp gauge in the cluster doesn't work. Also played more AAC, TPS, Throttle stop adjust games and may have hit the sweetspot. No more chugga lugga when floored from a standing start. Woot! I tells ya. While out in the 33 I had some Dude in an Audi SUV thing rip past me in Fury as my relatively cheap old Skyline formed one lane before him. Sucker. 18x10 +22 on the back, same size to go on the front soon, tyres are 265/35 Fronts in that pic are 17x9 +40s Link to comment https://www.sau.com.au/forums/topic/415573-sau-act-what-did-you-do-to-your-car-today/page/165/#findComment-7173976 Share on other sites More sharing options...
..::R33GTS-T::.. Posted January 19, 2014 Share Posted January 19, 2014 I got overtaken down the near Uriarra by a silver one like 40 mins ago, I was doing about 105kph, Id hate to know how quick he was going.. never saw him come up behind me and got some photos of the car Link to comment https://www.sau.com.au/forums/topic/415573-sau-act-what-did-you-do-to-your-car-today/page/165/#findComment-7174074 Share on other sites More sharing options...
..::R33GTS-T::.. Posted January 19, 2014 Share Posted January 19, 2014 Hey guys. Just in Philip. Walking into the walk on center I locked my car and noticed that my indicator light is blown... is the bolb the same a s the headlight? If not dies anyone know what product code it is? Cheers Link to comment https://www.sau.com.au/forums/topic/415573-sau-act-what-did-you-do-to-your-car-today/page/165/#findComment-7174101 Share on other sites More sharing options...
