You don't shit where you eat from 5hiv. So is it the AC compessor gone?
haha
Yes the AC compressor is dead. I knew that was the problem could have just cut the belt off and drove around with no AC
  • Like 1
Today...
Swapped my Spare ECU into the Wags. (didn't fix the Intermittent Fuel Pump Priming) :(
Replaced a Green Relay in Behind the ECU which apparently pretty much controls everything. (May have fixed the priming issue) :)
Chucked in 2 spare Old Coolant Temp Sensors. (bled the air out)
Cleaned the AFM. (again)
Pulled out and cleaned the O2 sensor.
Tightened a couple of Rocker Cover Screws. (near Exhaust Manifold)
Removed the Exhaust Manifold Heat Shield and found the main Exhaust leak. (Pretty sure there should be bolts in these holes) :/
More jobs for the thread repair guy
Just make a list, get them all fixed at the same time, so its only one callout fee.
Did nothing to mine today.... too hot, later tonight when the little terror is asleep, ill take off the rear bar, tailights, do the last of the vynil stripping and the door rubbers have to be carefully removed.
Then its ready for final clean and de-waxing, especially the edges and where the rubbers were.
The list of sht to do, to prep it for paint is very long. Lets see how far i get before the missus realizes what im doing. :w00t:
Edited by D.I.Y. Mik
Tried to reduce scrubbing.. Tend to get a little bit on crappy roads... :( Moulded the front splash guards with a heat gun. Raised the rear of the car about 5mm.. Was going to wash it but I think its going to rain at some stage over the next 24 hours.. Fingers crossed anyway :yes:
Detailing the Swift - Typical bloody thunderstorm then hail ! (x2)
Had GTR up the top with the 34.
Started to rain, then hail. First put a doona over the GTR bonnet then Kicked swift out of garage and moved the GTR just as the 2nd hail storm hit.
Was over quick. Shuffling cars what a pain.
Also had Shawty's magna here trying to fix the rear drivers side window. Wont go up. Had to tape garbo bags over it.
Did this a couple of days ago
1560574_10151910800431699_673939638_n.jp
1544335_10151909913986699_1494250941_n.j
good work man! looks nice :)
today I changed the plugs and cleaned the vallycover/rockercovers :)
plugs 1 through to 6, kind of glad I changed them!
they look a ton worse in person :|
Thanks man,
Today.....
Pumped front and rear guards.
Changed front pads
Raised front suspension up 10mm
Bled brakes
Discovered 265 tyres on 10" rims fit inside pumped front guards
Still have soft brake pedal :(
Time to have fluid changed and pressure bled.
Agree with above. Soarer looks Tough! What are those wheels + sizes etc...?
Today SkyWagStag got her much needed new thermostat and Coolant after a good hose flushin'. :D But now my temp gauge in the cluster doesn't work. :(
Also played more AAC, TPS, Throttle stop adjust games and may have hit the sweetspot. No more chugga lugga when floored from a standing start.
Woot! I tells ya.
While out in the 33 I had some Dude in an Audi SUV thing rip past me in Fury as my relatively cheap old Skyline formed one lane before him. :nyaanyaa: Sucker.
Woot! I tells ya.
18x10 +22 on the back, same size to go on the front soon, tyres are 265/35
Fronts in that pic are 17x9 +40s
I got overtaken down the near Uriarra by a silver one like 40 mins ago, I was doing about 105kph, Id hate to know how quick he was going.. never saw him come up behind me
and got some photos of the car :)
Hey guys. Just in Philip. Walking into the walk on center I locked my car and noticed that my indicator light is blown... is the bolb the same a s the headlight? If not dies anyone know what product code it is? Cheers
    • I'm firmly on the "zero compliance is good compliance" for FUCAs. I'd be looking to solid metal joints even if the primary reason for having them is because they facilitate the twist in the arm. I have never been more happy with the way the front suspension behaves than I have since I got rid of the FUCA bushes. Even the thin little (short lived) poly bushes in the Whiteline adjustables have too much compliance for my liking. It probably won't be long before I have sphericals nearly everywhere, probably including both top and bottom arms in the rear, and I'll start complaining about the increased costs for dental work. But I will be enjoying the driving more, I'm sure.
    • Plus, you'll get great experience in bedding in pads!
    • I have offset Nismo brackets so the fact the gktechs can pivot is less important to me. I have 170mm JIC arms with bushings - but they provide no adjustment and I'm not sure whiteline eccentric bushings will fit them (I don't want to ruin the bushings currently in them to find out). Ideally I want something with bushings + adjustment; hence why I'd like to find a pair of these. Unfortunately they aren't easy to find.
    • @Vee37 How much do you really care about finding these pads again? If your pads are quiet, work well and produce minimal dust, really isn't that enough? If you are set on finding the exact pads again, I suppose I'd do something like this -  Visit your local Jax, find out what brand of pads they carry. If the Jax workshop you previously went to had the pads on the shelf, then you can almost guarantee it will be of said brand.   I'm guessing you don't have the receipt for the previous work and pads. Can you visit a Jax workshop and see if they can look up your previous job to see what pads were fitted?  Still no luck? Put your stalker hat on, find the staff that used to work at the Jax store and ask them. Talk to local workshops, try to find out where the mechanics went to. Talk to Jax workshops, maybe they relocated to another workshop. When it comes to mechanics, its a small world. You'd be surprised how easy it is to track someone down. If these ideas don't work, shit will start getting crazy very quickly.... You could find out every brand and model of pad that fits that car... and try them individually ticking each off the list if it wasn't the one you were looking for.... If you go down this path your going to want to learn how to swap pads yourself, it is very easy, takes minimal tools and space. If you have room to park the car you have room to swap the pads. Plus you have the advantage of making sure all the brake hardware goes back in so they won't squeal!
    • You miss spelled bearings...
