Sau A.c.t. - What Did You Do To Your Car Today?
Could be gutted. Mine made some cool "Fwoop" noises when I gutted it. Better than being Blocked and rattly but HIGHLY ILLEGAL!
Imagine a Learner in a Turbs Skyline, blowing flames with Double demerits. :rofl:
OH SHITT! ahaha im not going to NSW this weekend !
could be bashed out or a "test pipe"
Wouldn't think a stocker could shoot flames
A pop sound is ignited fuel tho, so who knows ....
(or IC piping blowing orf - lol)
its has a 3.5 inch pipe into a 3" tip, not a stock exhaust... but ill have a quick look it should be behind the dump pipe?
If it's gutted it will look like a cat but will have no honeycomb inside.
GTR bov shouldn't do that. Probably the weird GTR BOV Fart noise that actually comes from the BOV not the exhaust. :/
Some do, some don't.
oh okay cheers! will put it back in soon and see on had boost if it still does it, loving the Zutututu at the moment...
Imagine a Learner in a Turbs Skyline, blowing flames and zutututu with Double demerits. :rofl:
im asking to get booked :(
Edited by ..::R33GTS-T::..
I've always thought that it's a pretty cool thing and yet cruel that the Series 2 4doors don't have the same setup. It's a badge stuck onto a thinnish panel, not hollow.
I think there was a factory option on sedans but not sure if Series 1 or 2. Slightly different garnishes.
S2 is like this.
I will try to do it oneday though. (I have a spare series 2 Garnish) :D
Today SkyWagon got her Fresh front Brake pads. Nothing special but they're New.
I'm formulating a plan for making some Bracketage for a StageA Cargo net to stop the Groceries floating around in the back.
I met a new R33 Skyline owner (Currently non SAU but is now aware ;)) and fixed his Boost cut / Limp home mode problem.
Assisted young Kasko San with an Upper Engine Cleansing and Felt the throbbing power of his Beast. :laugh:
Met and chatted with a Fellow SkyWagon owner at Charnie Shops. (they looked so cute parked side by side) no pic. :(
Apparently he is just about to take ownership of "Jap Parts" in Fyshwick.
Twas a good day.
It was good to catchup thanks for the assistance Rob.
Took it for a spin up to Yass after leaving your place and I loved every minute of the drive.
It could just be placebo effect but the car feels a lot different.
Get out the f**ken metho and go to town on those ants mate
Rob loves his ants. They love my feet :(
Pull out your Cluster and check the bulb?
Today I disassembled the SkyWags Dash and Cluster in an effort to try fix the temp gauge... Didn't work.
I think the problem could be the loom or the gauge is goosed. It was sorta working before I changed the Thermo and Coolant but now only works in the mornings.
I'm pretty sure It's not the sensor.
Also pulled out the Speed Sensor from the gearbox and fiddled with it. It was a little bit loose.
Hopefully I've fixed the intermittent speedo. (really sux when you're the only car on the road and there's a speed camera + Cruise control won't work when there's Zero km/h on the dash.
Mucked around with bracketage for the cargo net. Might have a better attempt at it tomoz
OZf**kinSTRAYA.
Jacked it up and removed both upper control arms and removed the bushes.
My Goodness where those control arm bushes tight...
Also found out last night that I have a mate that works for justjap WIN :)
 Share
    • there are probably many ways to do it for my bosch motorsport abs we used a r33 gtst abs front knuckle and modified the rear knuckle to allow sensor to sit and read understand time, effort and $$ but reading from anywhere else  you get diff chatter etc where you lose 30% ish in signal clarity compared to the above
    • Little more work!  Did some body work on the rear wheel arches and since the paint was a cheap spray job before figured I’d do something to tide me over until I wrap the car.    Colour might not be everyone’s choice but I like it and it’s only temporary, just hate having primer from the wheel arches standing out.    Keeping an eye out for a decent set of wheels to throw on now. Wheels and tires on the car are junk
    • Its likely to be 70% road 30% track usage, track usage will increase if anything. Decided not to fit it as I cant be arsed changing the bushes on my LCAs again 🤣 I did get the below back from GKTech though so they should work together     The anti-squat kit and roll center adjusters work independently since they change the rear lower control arm's angle in different ways. The anti-squat kit adjusts the angle from front to back, which impacts anti-squat values. Roll center adjusters change the angle side to side, mainly to correct geometry on cars that are significantly lowered. They might affect each other a tiny bit, but overall, you can think of them as separate.
    • What are you doing with the car? street car or race car? People get hung up on the squat of the s/r chassis rears. There is positives to the squat if a car is setup and driven correctly for it (correct ride height, spring rate, alignment, damper valving). Generally just lengthen the rear traction arm by 5-10mm and that will help the squat and bump steer too. You are also correct with the roll centre too. This too also needs to be adjustable if you start messing with suspension geometry.   Having done quiet a bit of testing on race cars this year in regards to rear squat, I've seen some big positives from it in regards to drive off corners and traction.
    • I find I am using the MX5 for everything except long overnight cruises with Jackie, or, if picking up the kids to go somewhere, the SS has so much more room inside, and is much more comfortable if your going to be doing Hwy driving for 6-8 hours And the MX5 isn't bad in stop go traffic for a manual transmission car, whilst the clutch kit has been upgraded from stock, it is still light, and also not having a stupidly light flywheel in it helps as well, I've spent alot of time sitting on the M5, M4 and M7 stuck in traffic when plodding around the Greater Sydney Region in it Another benefit is MX5's are not really a car that gets stolen, you can pretty much park it anywhere, and it will still be there when you return
