Sau A.c.t. - What Did You Do To Your Car Today?
Had a bit of a crappy spray last coats of primer i put on.
Finally worked out ( I hope) the spray gun, had to watch a couple of long tutorials on spraying to work it out. Its a big difference in the amount of paint coming out, i can go a lot faster now.
And now the weather is going to be cold and wet for a week at least.
Today is a great day to spray, but lining up free time and good weather is tricky.
If i was an expert spray painter i could just do it and cope with problems using skill. Im not a good spray painter so i have to set it up for minimum hassle or i wont be able to do a good job.
It shows how good i am when every second time i touch the car i make a problem to fix. But im getting better and working out how to do it properly.
Ordered some braided line and fittings
Where from? When I get an oil cooler for the 33 I want to get some Good Hoses.
John at Trojan claims Cheapo Coolers are OK but cheapo Lines can collapse and that is a bad thing. :/
Are you doing them?
They are quite tough to fit.
In hindsight i should have bought the fitting spanners and vice sleeve too.
Your workbench needs to be heavy or youll lift it off the floor trying to do up the fittings.
Also think about an appropriate cutting tool/technique for the hose. Wayward steel strands are the devil when doing them up.
I have Speedflow and Chinaflow fittings, they are different in how they work but both just as hard to do up.
And wd40 helps.
Ps: When i set mine up i found the Earls thermostat shipped from the US was the cheapest.
Edited by D.I.Y. Mik
Wow that's cool! :thumbsup: Helps keep moisture out of the spray yeah?
Put my CNC cut woodgrain panels in the Wagon, still need a few clips to fasten them better.
Made a couple of matching boxes for tools etc also.
post-78856-0-40506100-1398849731_thumb.jpg post-78856-0-93959700-1398849733_thumb.jpg post-78856-0-10050800-1398849737_thumb.jpg post-78856-0-75730300-1398849727_thumb.jpg
I'm going to do a new Boot Floor for both the Wagon and the 33 aswell.
If anyone wants a fresh boot floor panel cut (3mm to 16mm thick) to replace the old cracked / warped / broken Masonite one,
I can do out of MDF on the CNC at work. (would have to measure up first etc...)
Yeah cool. I can either do a small one that barely covers the wheel well (like Stock) or larger to actually cover more of the floor.
Raw MDF, Woodgrain, White or whatever... Basically depends on what Scrap we have at work. ;)
and not a dodge, shakey, freehand jigsaw cut either.
Highly likely. Just need to measure up and try to find out the curve radius etc... Praps a little trial and error too.
The panel on the Wags tailgate is similar to a parcel shelf I guess what with speaker holes and curves etc... Could be fun! ;)
I was considering trying door trims too. :yes:
 Share
    • As someone who has been playing with turbo things for some time now, be prepared for this to not be the first time feeling this way    I'm busy as atm, but if no one else covers the things I'm realising are worth mentioning to you then I will when I have a chance as it seems like I overestimated your knowledge on how turbos and wastegates work.  Otherwise I recommend having a look around how wastegates and boost control work, really anything on understanding the general mechanism of boost control as it will help you find the answers to the questions you're looking for.  Your initial question jumps some fundamentals.
    • I don't understand anything anymore.
    • so this is an anomaly??? I thought it was a voluntary increase
    • we can only guess exactly what happened from our keyboards, but to me it looks like they were targeting 27 but the wastegate was too small or poorly controlled and the boost crept up, that is quite common
    • Good points!  Took those for granted - though I *did* actually give an example of winding boost up more than it had been before where I wasn't actually specifically looking for more peak power.  The Toyota Starlet dyno plot that I shared and mentioned showed an overlay from the previous tune it had and the one I'd redone, I left the boost targetting the same as the old tune but then after peak power I ramped boost up by a good 5psi or so over what the old tune had at the same rpm. The reason I felt comfortable with this (though the owner of the car had a "are you sure?" moment when I suggested it) is that the setup wasn't turbo limited, it was largely head sealing limited and the owner was a bit concerned as for the last few seasons he'd had issues with head lifting - sometimes not completing an event without having some headgasket issue, so he didn't want to run any more boost than it was. The reasons I was ok with raising the boost a good 5+psi MORE than that was that I left it where it was in the middle, and only increased it where VE (and therefore cylinder pressure vs psi) were dropping hard and I didn't stop the torque from dropping, just reduced the drop.  Well, there is that and the fact that the previous tuner had it overtimed by near 7degrees at peak torque - but that's another story haha.    I didn't really go into detail about that "turning it up more" thing but now you've mentioned the "not detuning", sometimes the boost *can* be turned up higher than you'd expect if the setup allows for it and you do it smartly.  I've tuned things to run 30psi on BP98 "safely" that a few years ago (or still?) people would cry that it was a stupid idea - but given they were well intercooled, low EMAP turbos and only doing that kind of boost where VE is dropping etc I was pretty confident it wasn't as cowboy as it sounded at face value and we never ended up with issues as a result of it.
