Fixed the Front and Rear engine mounts / dampers on the SkyHatch.
The hollows circled were cracked and broken so I filled it all with SIKAFLEX and let it set for about 36 hours.
Put them back in this morning and saved myself over $100.
Solid. :thumbsup:
  • Like 1
Swore at mine as we pushed it off the trailer... lol new radiator will be on order tomorrow!
Such a shame it happened. What's the next event you're gonna go in Kat? SM1000???
I really wanna see.
Nah I'm not even considering 1000m events until I've got a logging dash fitted and a few more safety precautions. So maybe next year for that.
Time to sort shit out and then maybe do a Sunday Street Meet at Eastern Creek in November.
Would be great to watch. :woot: Such a Beasty. "Not Good Just Lucky"
This arvo I Pulled the Fuel Pump out of the SkyHatch and cleaned the Sender for the Gauge. (Very similar to the SkyWagon)
Seems to work better so far and Hopefully will not have a big Dead Spot in the middle anymore. ;)
Bought some radiator hoses for the cressida. Moved the gtr in the yard so its out of the way more and put the battery on charge. Bought a brand new n1 front bar for the racecar. And im broke again :(
    • Generally yes but for some reason I've been ruthless this time around!  I might even need to do another tip run after the way I've finally been able to hit the delete button on shit I've stepped over, stepped around and tripped over for the past 10 years!
    • I just quote the Rolling Stones. Paint it black.
    • It just depends if you're like me with a high level of OCD for doing something like hardlines, and highly critical of the little things, and then bugger all patience to get it how my brain pictures it
    • More than happy with the colour match Talking to the painter he recommended to give the top a few weeks for the paint to 100% cure prior to sealing it with the ceramic stuff Also, because why not..... I have a fancy pants Fluidampr harmonic balancer on order, the 2.5 engine uses the OEM 2.0 balancer off the old motor as the 2.5 balancer is a larger unit and doesn't fit clearance wise, which, because the two engines have different harmonics, isn't optimal, the OEM balancer does the job, but as the gear driven balancer in the bottom end is removed to fit a RWD application there is slightly more vibration, the Fluidampr helps with the harmonics that the gear driven balancer once took care of,  basically makes life easier on the oil pump and bearings when thrashing it around Hopefully the weather gets better soon because I'm keen for some cruising around, and currently, with the winds and storms we are getting, the amount of detritus being blown around from trees on the road isn't something I want to be driving around in
    • Meanwhile you could come down for a coffee tomorrow. Details in the events section
