Today I put a 30cm long x 2mm deep gutter rash on one of the LMGT4s
Very dirty on myself :rant: . From mint to shit in a few seconds
Not to mention how that devalues them and looks farked
What a nightmare! :(
Edited by dontyellpl0x
Ill take them off you if you ever decide :)
  • Like 1
I scratched my LMgt4s doing a Macccaz run was so posses that day.Powdercoated them and was happy again.
Rebuilt my calipers and powdercoated them wth Shiv.They looked great didn't want to put them back on.Whilst rebuilding bought braided lines and slotted rotors and pads. Now I need to find out how to bleed the master cylinder before I give up and take it to a shop
  • Like 3
MObile fabrications in Quenbeyan and Shiv for the calipers. Just some warning powder coat is a thicker layer, some areas with fine tolerances will have to be covered up or your wheels will not fit on the hub
Thanks Bryce - If I need powder coating I know where to go now.
I went and saw Craig at Wicked Wheels. I am going to give him a go for the rim - will post feedback.
seems like a good guy, so I'll see how it turns out before reporting back.
(March 2nd - is a busy workshop)
Anf - let me know if your interested in my R32/4 RB20DET (Auto)
Will likely be putting it up FS very shortly and looking for $10k in my pocket
Or any ACT SAU peeps
Drives beautifully, goes great guns.
1989 M Spec with ABS and Auto Spoiler. 117k kms
Paints very good but does have some stone chips on the bonnet.
Privately Imported into the ACT as a 4b in 2004. I'm 2nd owner in Aus
Full service records since import at 37k kms.
99.99% OEM (head unit and sub)
Things I've done
Major Service, rotors and pads
Aftermarket head unit, 4xspeakers and small 10" sub in boot
Remote keyless entry
Front/Rear bars resprayed
New windscreen
2 full sets of GTSt rims and running on mint 32GTR rims
HD rear sway bar
Newly recovered 32 steering wheel
No dash bubble
Ïnterior & seats etc awesome.
GTR car mats front and rear in really good cond
Small crack on drivers arm rest :(
For those who haven't seen her it is very naice :thumbsup:
Reason for selling. Got my eye on something else more sedate
Edited by Sinista32
Beautiful car and Drives amazingly for a 26yr old. :yes:
    • Ah right. Maybe my rb just loves chewing through batteries lol.
    • On the R34 can't you just unplug the IACV? This is the way I've always done it on the R33. Disconnect IACV, get it idling around 650rpm, and then do a power reset on the ECU to get it to relearn idle (factory ECU).   The big reason no one has touched on as to why you'd want to get the base idle right, is that it means the computer needs to make smaller adjustments to get a good idle at 700-750rpm.   Also, cleaning the IACV won't normally make the car suddenly idle lower or higher. The main issue with the IACV gumming up is that the valve sticks. This means the inputs the ECU gives, aren't translating to changes in air flow. This can cause idle choppy ness as the ECU is now needing to give a lot of input to get movement, but then it moves too far, and then has to do the same in reverse, and it can mean the ECU can't catch stalls quickly either.
    • 12.8 for a great condition, fully charged battery. If the battery will only ever properly charge to about 12.2V, the battery is well worn, and will be dead soon. When I say properly charge, I mean disconnect it from the car, charge it to its max, and then put your multimeter on it, and see what it reads about an hour later. Dieing batteries will hold a higher "surface charge", but the minutest load, even from just a multimeter (which in the scheme of things is considered totally irrelevant, especially at this level) will be enough over an hour to make the surface charge disappear.   I spend wayyy too much time analysing battery voltages for customers when they whinge that our equipment (telematics device) is causing their battery to drain all the time. Nearly every case I can call it within about 2 months of when the battery will be completely dead. Our bigger customers don't even debate it with me any more ha ha ha. A battery at 12.4 to 12.6 I'd still be happy enough with. However, there's a lot of things that can cause a parasitic draw in a car, first of which is alarms and immobilisers. To start checking, put your multimeter into amps, (and then connect it properly) and measure your power draw with everything off. Typical car battery is about 40aH. Realistically, you'll get about half this before the car won't start. So a 100mA power drain will see you pretty much near unstartable in 8 days.
    • Car should sit at 12.2 or more, maybe 12.6 or 12.7 when fully charged and happy. If there is a decent enough parasitic load then it will certainly go lower than 12.2 with time. You can't beat physics.
    • Ok guess I can rule out the battery, probably even the starter and alternator (maybe) as well. I'm gonna clean those leads and see what happens if it's still shit I might take it to an auto electrician. Unless the immobiliser is that f**king heavy, but it shouldn't be.  If I start the car every day, starts up perfectly never an issue. Isn't 12v low, shouldn't it be around 12.5v?
