Today I took the dashboard out because it looked really dirty and scuffed in a bad condition from previous owner, I've also taken the centre armrest piece out and replaced it with a better condition one
The job took me 3 hours, could've taken me less but I had to find something to open these bolts, has to go to super cheap and buy a full kit just to open two of those bolts which were located under the passenger airbag
This is some progress pics I remembered to take,
Everything is back and the new dashboard looks great [emoji108][emoji106] il take pics of it when it is daytime and post it
By the way the old parts are up for grabs if anyone wants anything let me know, airbag works I just don't need it because the new dash came with one
  • Like 2
Bought a HKS cam from a guy and the dowel pin on the cam was broken
Shop wanted $150 to drill it out and replace it
Pulled the broken one out and replace it from another camshaft dowel pin then bryce cam over and we practise how to remove the valve springs and seals on my spare engine RB25
Broken dowel pin on the HKS camshaft
the weekend/ rest of the week.
installed new oil cooler and filter relocation kit
wrinkle coated cam covers
new high octane catch can install
full fluid and plugs change
fuel filter changed
defi zd gauge install
full detail
install new door seals
fixed front speakers...still wired wrong but wont blow up now
then off for a new tune and ready for powercruise
also had the ignitor come loose while driving, causing the car to stop half way and need a tow before i could sort it out. john wilson drove past and helped me which was awesome
post-63013-0-98617100-1425304939_thumb.jpgpost-63013-0-35186500-1425305031_thumb.jpgpost-63013-0-47998900-1425305085_thumb.jpgpost-63013-0-88009900-1425305115_thumb.jpgpost-63013-0-62164100-1425305143_thumb.jpg
  • Like 1
Not a 'today' post, but swapped front springs back to stock on Rob's former ride last weekend.
Was getting some jyp with driveway angles being too unforgiving so it was that or pull the front skirt off... not hapy jan.
When done with springs, dropped in some 6' 2ways into the front doors, required very minor alteration of mounts, about an hours work all up discovered one speaker was blown hadnt noticed, pretty sure i'm half deaf anyway ;) Weekend before was oilchange o'clock, managed to only dump the contents of the filter on the ground... next change will be putting in a filter relocation.
  • Like 1
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
