$150
and I'm divided
I bet I could go around every ones skyline and spot mods with no benefits other than visual .........
Edit: This one https://www.justjap.com/store/product.php?productid=17670&cat=272&page=3
Sent you a PM
Approval Application:
(1)What is it? Air Pod cover -http://justjap.com/store/product.php?productid=17671&cat=&page=3
(2)Why do you want it? Because CF is not allowed and red is matching the base colour - also to have a bit more "Fill" effect in the bay
(3)How much? $150 + postage
(4)Scale of want/need from 1 - 10 (1 being want and 10 being need): 4
(5)What is product made of? Metal?
(6)did you seek approval previously (if not skip question 7)
(7)What was the result and reasoning? Wanted a CF one but apparently it's to wank factor.
(8)Any risk to damage of car/reputation/ other: No damage - however reputation may drop due to having matching colours
(9)Other: N/A
If you guys could please sign off on this?
Edited by RosieR34
lol... Forget the haters Jeremy!
If you want the box put it in. I'm looking to put one in soon too, car came with pod filter so thinking about this box to make it less appealing to defect police.. Thought about making one, but after spending cash on tools needed and perspex, etc. might just try find a used one. They are on ebay for about $100 also. Not like it has to be high quality =)
  • Like 1
dude i told you dont worry about the pod filter it actully gives 0kw gains if not it just gives you more heat soak. The stock intakes are actually a nailed design. Ive been trying to convince him just to go without the certificate. Its not November yet the worst thing that would happen is that yo have to go again im not sure if you have a number of times that you can try to get cleared. Id be guessing three times.
I believe 0kw is true but is throttle response a little crisp/responsive?
Also is heat soak much of issue......doesn't the air run through the intercooler before the the TB? I know at idle or low speed it will make a difference but not enough to affect a daily driver, surely?
I am a noob at the RBs but I have come from modding a supercharged v6 where a w2a is mainly used and the blower sitting on the intake manifold has a lot of heat soak and it is comonly discussed.
Not trying to be a smart ass just trying to learn a little.
I was also looking at one Jeremy.
Edited by gtr judd
Stock airbox sucks cold air, but has a small intake.
With exrta holes cut its less restrictive.
0$ upgrade that works.
Unboxed pods suck hot air.
No good.
A box can be as cheap as $10-$20.
No good.
Yea I can see how warm air is sucked in with out this box thing mentioned above, but with the pods enclosed surely it isn't that bad?
When at speed, there wouldn't be that much hot air, but standing still etc there would be more soak.
It's interesting 10 minutes after a drive to remove the shield and feel the Pod. Definately cooler than with no shield.
I need to trim my NAP Custom Shield a little after pulling my cooler out for cleaning, everything went back together just a little differently and it currently doesn't fit. :(
  • Like 1
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
    • Come on guys, they're just trying to sell their project car to scrape together a house deposit in the Western Suburbs of Sydney...
