I bought the switch as even if you try to fix the old one it will happen again at some point. The new one will see the Car out. So really not bad for 20+ years at least for the price.
I'm hoping to squeeze 9 more months out of it, money is tight (getting married in Aug '14) and that's $185 I'd like to chuck somewhere else on the car lol
Hard induction pipe going in, but i have to move the washer bottle, to do that i have to move other stuff...... one mod leads to another, leads to another.
Bloody tight engine bay. Batteries gone to the boot and theres still not enough room for everything. :dry:
and this guy doesn't even own a GTR.... Bah.
An extra turbo, abs, etc...
No wonder they cost so much to do up, stuff would have to be custom made just right to fit in there.
but arent they wider?
Edited by D.I.Y. Mik
Well I had a look at my head light, passenger sidw not working. Globe is fine, the bit the globe sits in is fine. Ran the test light to the plug and it has power....
I'm stumped has anyone got any ideas? Pm me if you want so it doesn't get this thread off topic.
I have been googling all arvo lol
Yea swapped globes, I have power coming to the light (green wire) but I assume no earth that's why it's no go, also the high beam doesn't appear to work on that side but has power at the plug (red/yellow I think it is)
So I'm guessing its the earth from the loom before the wires split up with plugs for high/low beam.
I don't have a multimeter :/
Would it be to dodgy to splice the earth from the drivers side and run it across?
Headlight switch on cluster surround :thumbsup:
Soooo I pulled the switch out and apparently its not that old, has a nice chrome just jap sticker on it.
Any other ideas
Any other ideas
Bidge a wire from the drivers headlight assembly to the passengar to test to make sure everything works there. If the passengar light comes on it is the switch.
Try this simple test.
Turn lights on then pull indicator stalk back and both headlights should go into high beam. (a flash basically)
Then flick the indicator stalk forward (highbeam). If the switch is failing you will either get no high beam or only a single light on high beam.
Good luck
Sooo update, Jimmy came round and bam it was the switch, a little tweaking and cleaning and I know have a left hand head light and high beam that work :)
Thanks everyone and a big thanks to Jimmy for coming me around and teaching me how to fix the switch.
Induction pipe done, sounds a little different, bov sounds different.
Found a hose at supercheap that was just perfect for the extension on the bov hose.
Cold airbox trimmed to fit, dunno if i like it now, might make a new one.
Feels the same, but i know its more reliable.
:thumbsup:
I searched for ages in the For Sales and finally found one, (Autobahn88 brand) but it doesn't work with the Stock Airbox. (Pod Only)
So I ended up getting Scotty nm35 to make me a custom one. Works on both Pod and Airbox.
Not Cheap but it is a Work of Art. :wub: P0RN PIPE!!!
    • Oh, that's grim. Something bad has been happening there.
    • Put an endoscope down the hole and saw this. Not quite all around the bore but a good 60% at least. Chin to the chest and towards further disappointments I guess.
    • 2 does "sort of" applies, maybe......but looking at what parts would be needed for the swap to get engineered, registered, and insured, and basically that's everything under the car, the modifications the make it legal would be problematic and horrendously expensive, all for a street car that just cruises around and hits a few twisty roads on the weekends Also, from looking at the NSW rules and Regs, with all modifications that is required just to make the car safe and not twist itself to pieces, and then actually get registered for street use, may still be impossible nowadays As for 1, when you add in a fresh engine, fresh transmission, rear cradle and diff, tailshaft, suspension, brakes, cooling, and all the other fabrication required, your probably looking at up to $100k to do it right, all for a 20 year old MX5 that is over engineered and you would never be able to actually use the power it has on the street, much like your beastie, which I love, but you actually track that thing and can use all of its powers in anger, in a safe environment  Hell, the old Bogan Cruise Ship had more power than I could use on the street, and in hindsight, I went a bit silly on that thing, it didn't really need the 500hp it had for what I actually used the car for, it was fun, but basically unusable on the street if you value your licence  As for cams, yeah, I'll probably book it in for them to get installed and tuned soonish, like next month after MX5 Mania are back at work....... and yes, I've already sent a email to bin the turbo quote and quote instead to install cams and a new Fluidampr balancer that will suit the 2.5 better than the OEM 2.0 balancer that is swapped over for the 2.5 install, as the balancer needs to get pulled to time the cams it's a while your in there sort of thing I did think a bit about flex fuel for a laugh, but being na, and no where really around locally anymore to get E85, I've binned that idea, so no sweet sweet corn smells are set for the car I wish E85 was more of a standard fuel, it's better for the environment, better for tuning, plus that sweet sweet smell we all love As for fitting in the family, that's not needed, as everyone in the family already owns a car that can seat 5 humans comfortably enough, the MX5 is "my toy" As for buying a car that is already built, nah, I would rather pick and choose my parts, I enjoy the process, and in the big picture, the additional cost is well worth the enjoyment, and the occasional frustration, I get out of doing it, albeit with other people spinning the spanners, and me, just paying the invoice 🤣
    • Excuse me, but 2) does apply 1) Would also apply if you consider how much is spent in the alternatives. Also there's the option of 3), buy one pre-built that you can put your family in (it's me, it's my car)   That said, I went on a ~500km drive the other day. I didn't use anything more adventurous than 3rd/4th gear at about ~3000RPM and 50% throttle and I was going as fast as anyone has any sense doing on a public road, with enough grip to the point where I didn't want to go any faster. I was obviously under the limit of the current car etc etc. MX5 with 2.5 N/A to achieve the same speed would be more fun for any road scenario. Maybe consider cams. I wouldn't boost it. The use case is just not there and it won't actually make the car more enjoyable unless you really do plan on wringing gears from 1st to 3rd (at least) at 100% WOT on a public road to 150+kmh.
    • Great if: 1. You had all of the money for everything else that is required  2. Lived in a country where you could actually do this and drive it legally on the road Sadly, neither applies to me As for the turbo, I am having second thoughts, mainly for engineering/registration legality reasons and insurance  Not saying I've finished doing stupid things that I probably should do to the MX5, but boost, and V8 engine swaps isn't on the cards Strange, but true
