copy cat, dirty rat sitting on the .....
(you just beat me to it - tis all)
Great Minds think Alike.
Hey Richard those clips you gave me, thoughts on Painting either BB or black?
Black mate - BB will be too "pretty"
and did you paint the mesh first ?
you have more chips than Smiths :P
Edit: Nice job on the number plate Edward scissor hands ....
Edited by Sinista32
  • Like 2
Nah ill pull it off to paint it when i do the rest of the things i need to paint.
I like to think those chips make it look metallic. :whistling:
Previous owner did that. Im getting new plates soon anyway so ill put some spacers in so it fits.
Grab a cusco offset number plate holder maybe.
I have to order one as my home made brackets have seen better days. Ripped them off yesterday.
Front bars take the brunt of the stones hey. You should see mine :/
Edited by Sinista32
Yup =( and unfortunately as you saw matching my paint is almost impossible. On the front i might be able to get away with it. Maybe ill take it into prestige and see how well they can have a go.....
I have to order one
Maybe we can organize a group buy depending on price cos I need one too Edited by gtr judd
Ill prob just make a rubber spacer for the original spot. I think ill buy the paint next weekend and start painting stuff. I really need to paint my throttle body.
Ouch $90 :/
I saw RHD have them for 3500¥, so about $37 bucks + postage obviously, not sure how that is calculated but.
Spacers seem to be the best quick fix
Edited by gtr judd
R33 Sedan...
# KH0800 = Full Set
# KH0812 = RH Front
# KH0813 = LH Front
# KH2812 = RH Rear
# KH2813 = LH Rear
# KH0B15 = Clips
I think.
can I grab the jap vin too?
Hmm.....
Im going to the metal shop tomorrow for alloy.
If i see an appropriate sized z section i can make brackets that will offset out and up a little, can even weld nuts on the back if i use steel.
I think i have some already for the deep one on the rear.
Ill make one for each and see if yous like em
    • I mean this in no disrespect to u mate; Are there clear tagged examples/explanations in our SAU forum for example, in my interest, this is how to do R34 Gtt suspension the right way? U guys did so much taking risks with experimentation that deserves recognition and those results helps us morons take the RIGHT path to buy quality / buy once. 🍻
    • Pretty much what you'd expect at that power level. Hypergear turbo, long list of supporting mods, full Haltech catalogue, etc.  I'd say this goes for most drivers, suspension is still a dark art for most people. And it's really hard to convince someone how much better their setup could be...
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
