hell yea!!! first try?
Nah 4th time lucky. Well I went there 3 times in one day, the kept winging about the exhaust height. I couldn't do it properly on Monday, so got a big ol' hammer and bashed it flat. They really didn't like that, so yeah don't do that.
Ended up having to re weld the back half of the pipe, they were happy after that. One dude there seemed to think that I had put restricter plates in the exhaust, because having a 3" pipe go into a tiny pee shooter muffler does nothing to make it quiet (Idiots, goes to show how much they actually know). Another guy asked me if it did have the plate, I went full retard and gave him a blank look and said I don't know what a restricter plate is. So that seemed to work, they stamped the paperwork and I was on my way!
Edited by dirtywan
Order More Braided lines. I've got sooo many parts on the way now. Though i think the size i ordered for the catch can will be too small. We will find out.
Finally got my car past the pits this afternoon.
Now to put adjustable arms back on and get an alignment (where is capable of aligning fairly low cars?)
Good stuff! Try the guys are capital steering, they are great. Also I'll have to drop your owners manual past at some point.
What did i do to my car today.............
Gutter rash on the Volks. >_<
NOOoooo!!! That sux. :(
Well I just drove mine (33) to the Servo, Filled up and checked tyre pressure.
First time I've driven it since the weekend. Wow!
Jeremy, if you think you need 250kw to Enjoy, try driving something lesser for a week. It's all Relative.
Manual is weird. :D Suspension Feels like it's worth Thousands, Brakes are Awesome and Power is :woot:
Still... I love Both the lines as they have VERY different Characters.
  • Like 1
Finally gave the 33 the Vac it has been needing for Oh So Long...
Can't have Mum 'n' Dad covered from head to toe in MDF dust now can we? :laugh:
hmmmm... I wonder if they've ever been from 0 to 100 in 6 seconds?
Looking forward to the Drive to Orange and back. :D
Must check fluids etc... Consider it done also.
  • Like 1
fitted a high flow, injectors, ecu and tapped a thread for the MAP sensor and IAT sensor and took it for a tune. Hopefully all goes well over there. Hate the feeling that something wont go as planned.
  • Like 1
f**k!! I thought it was bad getting gutter rash on mine... id kill someone if it happened to my volks (if I could afford them :( )
With all those stock parts in I was running like 150kw haha got my power back and was like YEAHHHHHHH. But no job - no 250kw
I have some volks from 97 or 98 that came with my car, looks like ray Charles tried to parallel park it. Now I have the lmgt4's I think ill fix them up and paint them a stupid colour.
Looked at my door because it is very loose even when closed. Found it keeps the interior light on so I got out some sticky tape and made sure the door light thing is kept pushed in haha
Not sure how to fix the door, it seems to be sagging from the hinge :(
    • Yes, but it's not as easy as pulling a fuse on anything other than an R32. There's a routine you have to do, involving disconnecting a loom plug and bleeding down the preload.
    • A question for tuning awd, is it possible to disable the AWD? The stagea is an EA/T AWD, Toshi had said on a GTR, he was able to disable it and make it 2wd. Just wanted to double check if this was possible
    • Whoa, that's a name I've not see for a long time! Sorry to hear about the engine / turbo damage.  Fwiw with any engine problems it often really a case of just seeing what happens when it's apart, ymmv - I wouldn't rule out the possibility that the damage isn't even from the turbo failure, or possibly from a combination.  The airflow between cylinders isn't dead even, injectors can go off over time as well, with the turbos overboosting if you didn't have upgraded fuel system there could have possibly been a bit of leaning out - stock triggering is often a bit unreliable by this age too.  Basically its an old engine and a few things could have been going on, and you won't know how much work is needed until the engine is apart.
    • I'm just shocked there's a euro driver on our roads who is thinking of other road users and not attempting to blind everyone. I wonder if Prank uses his indicator too...
    • Its hard to tell really. The Q50 owner's forum talks about it a lot and has quite a few people directly affected, but no idea what % of cars sold actually had the block replaced. Also, there seem to be 2 distinct issues which both get diagnosed by Infiniti as requiring a block replacement (no wonder they are going broke) 1. "Porous block" where coolant mixes with oil through thin or poorly cast parts of the block 2. Head coolant gallery plugs not sealing. If I was noticing engine coolant loss I'd start with cooling system pressure test (as always) and then I'd pull the cam covers and reseal the coolant gallery plugs on both side before worrying about a potentially porous block.  If neither of those did the trick it would be put in a second hand engine out of japan; I haven't checked pricing but I'm sure there are plenty around by now as they've been in production 10+ years
