Sau A.c.t. - What Did You Do To Your Car Today?
Cheap ass brake bleeding kit arrived today, also found out my pressure washer wont fit any attatchments.
The bastards changed the fittings and dont have adaptors.
Bosch used to be German, now its Chinese.
:down:
:down:
same with my pressure sprayer, tho with it being a karcher (how ever you spell it) fitting are heaps pricy :( think ill just use the big diesel powered one at work
Don't use my pressure washer on the car. Gentle is the way to go :thumbsup:
I was going to use it on the the gearbox near the rear main seal, rocker covers were leaking a while ago and its really built up! id never touch the car with one, don't want my paint to chip any more :)
I washed my bike and car yesterday as it was just a nice sunny day and now its all dirty again as you can see all the dust on a black paint easily :(
Took my car out for a drive today went and saw john, he thought me how to use a button clutch and also found out that left engine mount is broken so now i got my next weekend job lined up
i use it on the soft spray
However....
I would like it to be strong enough to just strip all my shtty paint away.
the big diesel washer at your work will do that....... :laugh:
Found a solution to the washer problem, need to make a small fitting with a very fat thread on one end.
Edited by D.I.Y. Mik
Hmmm... that would be nice. Unfortunately my paint is....... um, it would be like polishing a turd.
So its time to change that.
This will help make painting easier:
All made from junk behind the shed. Just need a double sink connector from Bunnings and its hooked up.
Its not hoarding if you eventually use it.
  • Like 2
However....
I am almost sure it you put it on the sharp stream it will get it back to bear metal ! its insane
the sink looks awesome :)
Bill, I think I've said this before but...I WANT YOUR WHEELS! Very Tasty.
Played Front Suspension games on the Wagon again today, (replaced Strut bearings) just needs a little more tweakage and then she should be good to go for an alignment.
Rear Pads should be arriving soon... then rego retest.
Also a good chance She will soon have a GTR Clutch Fan. (RB30 fans are NOISEY and not so efficient.) ;)
Ummmm ... yeah you have, and so have a few people :unsure: ...
... .. :ph34r: (Bill checks his nuts with greater regularity from here on)
  • Like 1
 Share
    • Sadly, it won't happen. The AC controls in our cars are essentially on-off. Whereas the AC in new stuff is more a case of variable displacement compressors giving infinitely variable output.
    • I don't think anyone did. But it still made me consider. For me personally it wasn't clear whether the AC experience in my car was shit because it is an old system, or because it wasn't maintained. Looks like it may have just been the latter. I see some more modern setup being sold as an upgrade and I wonder whether it would make it drive like AC in a modern car. Where you don't really hear it or notice it. But maybe that's asking for too much as well.   Haha, stick it in a Nissan Cube and you end up with a driveable fridge I'm not doubting your experience. Just thought it was interesting to hear the AC technician's thoughts on it.
    • Guess I should be hunting down one of these big ol ford units then for max flow ....  I've had fresh gas in mine and it was never as cold as it is now . The compressor could have been trash though, like I said I am one example with a bunch of unknowns.
    • I don't know if anyone was seriously suggesting a retrofit of an Echo compressor in place of a more-or-less working original comp. You'd have to change the hoses at the bare minimum to do so, and that will definitely add significant cost. I had to get my hoses modded when I did the engine transplant and chose to use the Neo's AC over the even older R32 comp. That was startlingly more expensive than expected for what looks like a simple welding job, and a massive pain in the arse when it turned to have a pinhole leak in the weld too. The Frenchie's kit is for people who have next to nothing of the original system or have more than that but some of it is a bit shit and better off thrown away than salvaged. If you've got 90% of the system, you just patch it up. Mine is currently degassed because it apparently has a big leak somewhere. If I find it is the compressor, I will be looking to take my spare comp to a shop to assess and/or recondition, rather than contemplating a retrofit to anything off-brand.
    • I went and got the aircon regassed in the Stagea today and asked the guy about the upgrade to the Toyota Echo compressor. He was saying it is likely not going to be as good. It is newer but smaller and not going to pump as strongly. And it would be better to try and get a new OEM compressor. He was saying that the improvements people are seeing may be more likely due to regassing the system. I thought it was interesting to hear. Going by the sticker the system in my car was last checked in 2015. Gas was at 50% which is apparently beyond terrible. Under 80% is where efficiency already falls apart. Anyways, with fresh gas the AC is now bloody freezing. I think it may be working a bit less hard as well. I need to drive it a bit more to try it properly. Previously on hill starts it would utterly bog down the car. I'm hoping this is a bit better now. The frenchies kit looks great, but $1400 for the compressor upgrade alone makes it a bit of commitment. Very much so compared to a $150 regas.
