Sau A.c.t. - What Did You Do To Your Car Today?
You don't shit where you eat from 5hiv. So is it the AC compessor gone?
haha
Yes the AC compressor is dead. I knew that was the problem could have just cut the belt off and drove around with no AC
  • Like 1
Today...
Swapped my Spare ECU into the Wags. (didn't fix the Intermittent Fuel Pump Priming) :(
Replaced a Green Relay in Behind the ECU which apparently pretty much controls everything. (May have fixed the priming issue) :)
Chucked in 2 spare Old Coolant Temp Sensors. (bled the air out)
Cleaned the AFM. (again)
Pulled out and cleaned the O2 sensor.
Tightened a couple of Rocker Cover Screws. (near Exhaust Manifold)
Removed the Exhaust Manifold Heat Shield and found the main Exhaust leak. (Pretty sure there should be bolts in these holes) :/
More jobs for the thread repair guy
Just make a list, get them all fixed at the same time, so its only one callout fee.
Did nothing to mine today.... too hot, later tonight when the little terror is asleep, ill take off the rear bar, tailights, do the last of the vynil stripping and the door rubbers have to be carefully removed.
Then its ready for final clean and de-waxing, especially the edges and where the rubbers were.
The list of sht to do, to prep it for paint is very long. Lets see how far i get before the missus realizes what im doing. :w00t:
Edited by D.I.Y. Mik
Tried to reduce scrubbing.. Tend to get a little bit on crappy roads... :( Moulded the front splash guards with a heat gun. Raised the rear of the car about 5mm.. Was going to wash it but I think its going to rain at some stage over the next 24 hours.. Fingers crossed anyway :yes:
Detailing the Swift - Typical bloody thunderstorm then hail ! (x2)
Had GTR up the top with the 34.
Started to rain, then hail. First put a doona over the GTR bonnet then Kicked swift out of garage and moved the GTR just as the 2nd hail storm hit.
Was over quick. Shuffling cars what a pain.
Also had Shawty's magna here trying to fix the rear drivers side window. Wont go up. Had to tape garbo bags over it.
Thanks man,
Today.....
Pumped front and rear guards.
Changed front pads
Raised front suspension up 10mm
Bled brakes
Discovered 265 tyres on 10" rims fit inside pumped front guards
Still have soft brake pedal :(
Time to have fluid changed and pressure bled.
Agree with above. Soarer looks Tough! What are those wheels + sizes etc...?
Today SkyWagStag got her much needed new thermostat and Coolant after a good hose flushin'. :D But now my temp gauge in the cluster doesn't work. :(
Also played more AAC, TPS, Throttle stop adjust games and may have hit the sweetspot. No more chugga lugga when floored from a standing start.
Woot! I tells ya.
While out in the 33 I had some Dude in an Audi SUV thing rip past me in Fury as my relatively cheap old Skyline formed one lane before him. :nyaanyaa: Sucker.
Woot! I tells ya.
18x10 +22 on the back, same size to go on the front soon, tyres are 265/35
Fronts in that pic are 17x9 +40s
 Share
