it was when I first got the car, wasn't running! the radiator was snapped in half
I also had to do the lower control arm in mine when I got it, they are a bitch!!
and rob, my rpm stops every now and again, any ideas? my mates 33 did the same thing
Somewhere between the engine and your eyeballs. :P
I'd try checking for loose wires / dodgy earthing. Could be in behind the cluster etc...
Not hard to pull out.
(once you've done it a few times) lol
  • Like 1
Fibreglassing repairs today, all done.
The instructions say mix a certain amount so you can get it on before it hardens.
DIY Miks painting skills mean i can mix the whole tin and get it on good, well before it starts to harden. job done. :thumbsup:
I was feeling so good until i remembered... the only way to get fibreglass off is a cold shower. :O:blink:
  • Like 1
I found that out when helping dad fiberglass his sub box in the old f6 typhoon... not very nice!
hahahaha!!!! smartass!!
yea I have pulled the cluster out already, couldn't find any loos wires, will look for the earth wires on the weekend :)
Edited by ..::R33GTS-T::..
Strongly recommend not letting your Skylines get so low on fuel that the fuel light comes on.
+1
I don't allow my GTR get below a qtr of a tank.
Listen or learn.
But just don't breeze over good advice, especially if you have modified your car.
got no mods, well no power mods, and I still don't let it go under a quarter
I have never had my fuel light on, and the gauge has been like 3mm under the empty line... and I sure as hell don't want to see if the bulb is broken
Make up your mind
I just made sure the intake is the same height as stock, and while i was there i could see how it gets the last bit of fuel.
Kinda dodgy baffles try to keep it near the pump, but a good corner or steep hill and it would run away and youd get air in the line.
After pulling it out and f-ing around trying to re-seal it, i still smell fuel inside the car sometimes. Have to do it again better this time. DIY LOL :huh:
Make up your mind
haha, it was heaps under when I got the car, didn't drive it, got a jerry can... im talking about I wont let it under while driving :P
but good spotting :/
As I said I've seen my fuel light come on once in 10 months. I normally fill up when it hits E, but my sender is not correct and I can only fit in 40-45 litres
Edited by dontyellpl0x
It's like fuel cut.
It can do engines in if it occurs at the wrong time
Bit dramatic I know, but it happens.
(your better of stopping spark than stopping fuel)
Edited by Sinista32
    • Also, a tip for young players  Check the dates on new tyres before they fit them, I always ask this question at the tyre shop, as they have tried to put "new" tyres on one of my cars a few years ago, but the build date was about 3 years old
    • Yeah - 4 or 5 years is the limit for decent tyres. Pedestrian grade tyres with 400 TW ratings start out hard and don't start to suffer until they are somewhat older again. But the stickier decent stuff? Nup. My current ADO9s are < 2 yrs old, 17000km in, only have about the minimum 2mm of tread depth left, and they are.....not what they used to be. They are clearly much harder now than when new. Whether that is heat cycles (unlikely, for a road tyre), different compound between top and bottom of tread, or actually aging out (in less than 2 years!!!) is not really able to be discerned. But I'd credit actual aging as being at least part of the cause. I've got an old pair of ~50% worn AD08Rs in the shed that I really need to get rid of. They started feeling waaaay too hard to put back on the car after a couple of years sitting there.
    • Personally I wouldn't put tyres over 4 or 5 years old on any of my own cars. Once they go hard the grip characteristics completely change. As per most things it only matters in an accident and that's when you most want them to do their job!
    • I'm replacing the front tyres on the E39 tomorrow because one of them has a few gouges out of it. There is so much tread still on them but they're also 9 years old and the rubber is super hard.  This falls within the guidelines of 10 years old that I've read which surprises me given their condition.  I'm curious about whether you guys care about tyre age or just judge the tyre based on condition? How old would you consider too old?
    • What starts as a scratch, becomes a flesh wound, then quadruple amputation. Jus' sayin'. Crush resistant gloves (The ones with the rubber strips down the back of the hand and fingers) might not be a bad idea after all!
