BMW E30 side indicators roughly fitted to the SkyWagon. Still need to cut n polish around where the original ones were.
Rear 30mm Lower King Springs received also... Might get them on soon. :D
Oh you Customiser dude you !! cant you make 59 cadillac tail lights fit as well? ..... but .. looks cool,
King Springs .. :D .. I'm a big fan, I have them on and are great gear . . :yes:
Come on ,..... I'm sure you can make it work!
Edited by THE34T
Rear King Springs ON!
attachicon.gifR31 Rear Springs Hard vs Stock vs Lows.JPG attachicon.gifR31 Rear Low Kings.JPG attachicon.gifSkyWagon Rear Kings.JPG
Hard ^ Stock ^ Low Kings
Front and rear is much more even now. Rear is 30mm lower than the stockies.
Nice :thumbsup:
That's why I like your BBS rims Bill. That Snake Tongue Spoke design has alway been my Favourite.
Rims on the 33.
Rims on the Skywagon.
See the pattern?
Rims on the Micra.
Drove out to Theodore and back. The King Springs feel great! :D
(I might have to adjust the headlights to point more down at the ground now) :yes:
Ive been slack and done nothing, waiting for the good paint stripper to be in stock.
I have to strip it to bare metal, because the clear is peeling and you never know what exactly makes it peel.. so it has to be all removed or it will happen again.
I would like to sodablast but it will cost a few hundred for sure, and my aim is to keep the cost as low as possible but still do a proper job.
Shes all pulled apart, vynil gone, even got the doorhandles out.
Must fit brake air deflectors and radius rod braces tonight.
In the meantime im learning some tricks and techniques to make it quick, easy, cheap and good quality.
What i did to the interior bugs me, so i try not to think about it. ill take care of that later.
Drove her to work and back today as she had not moved in two weeks due to the extreme heat. Will take it again tomorrow i think. It was loving the cold weather.
Well in the mail today I received 3 packages, 36mm socket, CV boot and my adjustable control arm bushes.
So today I finally got out the 2nd tie rod end (after 2 broken tie rod end splitter tools, hammering, ball joint forking and heating) and burnt out the old control arm bushes.
Hopefully tomorrow my new tie rod ends turn up and I have time to buy a tap and die set so I can get the control arms back in.
    • Ah right. Maybe my rb just loves chewing through batteries lol.
    • On the R34 can't you just unplug the IACV? This is the way I've always done it on the R33. Disconnect IACV, get it idling around 650rpm, and then do a power reset on the ECU to get it to relearn idle (factory ECU).   The big reason no one has touched on as to why you'd want to get the base idle right, is that it means the computer needs to make smaller adjustments to get a good idle at 700-750rpm.   Also, cleaning the IACV won't normally make the car suddenly idle lower or higher. The main issue with the IACV gumming up is that the valve sticks. This means the inputs the ECU gives, aren't translating to changes in air flow. This can cause idle choppy ness as the ECU is now needing to give a lot of input to get movement, but then it moves too far, and then has to do the same in reverse, and it can mean the ECU can't catch stalls quickly either.
    • 12.8 for a great condition, fully charged battery. If the battery will only ever properly charge to about 12.2V, the battery is well worn, and will be dead soon. When I say properly charge, I mean disconnect it from the car, charge it to its max, and then put your multimeter on it, and see what it reads about an hour later. Dieing batteries will hold a higher "surface charge", but the minutest load, even from just a multimeter (which in the scheme of things is considered totally irrelevant, especially at this level) will be enough over an hour to make the surface charge disappear.   I spend wayyy too much time analysing battery voltages for customers when they whinge that our equipment (telematics device) is causing their battery to drain all the time. Nearly every case I can call it within about 2 months of when the battery will be completely dead. Our bigger customers don't even debate it with me any more ha ha ha. A battery at 12.4 to 12.6 I'd still be happy enough with. However, there's a lot of things that can cause a parasitic draw in a car, first of which is alarms and immobilisers. To start checking, put your multimeter into amps, (and then connect it properly) and measure your power draw with everything off. Typical car battery is about 40aH. Realistically, you'll get about half this before the car won't start. So a 100mA power drain will see you pretty much near unstartable in 8 days.
    • Car should sit at 12.2 or more, maybe 12.6 or 12.7 when fully charged and happy. If there is a decent enough parasitic load then it will certainly go lower than 12.2 with time. You can't beat physics.
    • Ok guess I can rule out the battery, probably even the starter and alternator (maybe) as well. I'm gonna clean those leads and see what happens if it's still shit I might take it to an auto electrician. Unless the immobiliser is that f**king heavy, but it shouldn't be.  If I start the car every day, starts up perfectly never an issue. Isn't 12v low, shouldn't it be around 12.5v?
