Over the weekend, for Skywagon I made an exhaust shield for the Extractors. (Doubles as a BBQ.)
I also tinted the indicators. (way too dark)
and installed some New Bonnet stops as per Ebay again ---> http://www.ebay.com.au/itm/330892988661?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
Today on the 33 I replaced my Pedders Shocks & Stock Springs with other Pedders Shocks and NISMO Springs. :woot:
Harder Ride and 10mm lower.
(feels so Boy Racer Driving round with no back seat and lots of extra fuel pump and exhaust noise.) :woot:
  • Like 1
After messing round with castor arms on the Wags and finding 2 different size bush spacer dealies in there, I put 2 same size ones in.
Got a Re alignment this arvo and suddenly my steering wheel is straight and much less Tramlining. :woot: Much Better.
Received in the mail today (All from 1 Ebay seller)...
2 RB30 AFMs, 1 Coil, Brand New Eagle Sparkplug Leads and a 12 pack of New KLG Sparkplugs.
Installed LED Rear brake lights, Indicators and number plate lights... The color in the brakes and indicators is so much more vibrant. Looks better than new!
So finally i got my car running now time to get it tuned and also does anyone knows how much will it cost to get all my exhaust studs replaced.
Just waiting on some hoses and then i will tidy all the hoses
you can go to speciality fasteners they have good stuff. You can probably do it yourself if you do it slow. If you snap any buy a reverse drillbit about half the size the diameter for the bolt. soak it in release agent a few days before you remove it but you cant drive coz it'll heat it up again.
Installed a blitz return flow today. Great kit, real easy to install. Only cutting required was some trimming of the front bar
Oooh.. Nice Work. :D
How's it feel to drive? More power? Response slower or not?
I felt a big difference in power / airflow when I put in the R34 GTT smic after the stocker...
Changing from the GTT to the ARC smic was not so noticeable.
Year I think maybe I've lost a bit down low, gained a little mid range but it's definitely freed up top end.
Another supporting mod done. Been talking to dvs Jez lately, hopefully POWER :woot: isn't too far away :D
  • Like 1
Nice work Chris
Will give that a try maybe next in line and if not then just give it to a exhaust shop to do it.
Today i tidy the engine bay a little and got rego :banana:
    • Ah right. Maybe my rb just loves chewing through batteries lol.
    • On the R34 can't you just unplug the IACV? This is the way I've always done it on the R33. Disconnect IACV, get it idling around 650rpm, and then do a power reset on the ECU to get it to relearn idle (factory ECU).   The big reason no one has touched on as to why you'd want to get the base idle right, is that it means the computer needs to make smaller adjustments to get a good idle at 700-750rpm.   Also, cleaning the IACV won't normally make the car suddenly idle lower or higher. The main issue with the IACV gumming up is that the valve sticks. This means the inputs the ECU gives, aren't translating to changes in air flow. This can cause idle choppy ness as the ECU is now needing to give a lot of input to get movement, but then it moves too far, and then has to do the same in reverse, and it can mean the ECU can't catch stalls quickly either.
    • 12.8 for a great condition, fully charged battery. If the battery will only ever properly charge to about 12.2V, the battery is well worn, and will be dead soon. When I say properly charge, I mean disconnect it from the car, charge it to its max, and then put your multimeter on it, and see what it reads about an hour later. Dieing batteries will hold a higher "surface charge", but the minutest load, even from just a multimeter (which in the scheme of things is considered totally irrelevant, especially at this level) will be enough over an hour to make the surface charge disappear.   I spend wayyy too much time analysing battery voltages for customers when they whinge that our equipment (telematics device) is causing their battery to drain all the time. Nearly every case I can call it within about 2 months of when the battery will be completely dead. Our bigger customers don't even debate it with me any more ha ha ha. A battery at 12.4 to 12.6 I'd still be happy enough with. However, there's a lot of things that can cause a parasitic draw in a car, first of which is alarms and immobilisers. To start checking, put your multimeter into amps, (and then connect it properly) and measure your power draw with everything off. Typical car battery is about 40aH. Realistically, you'll get about half this before the car won't start. So a 100mA power drain will see you pretty much near unstartable in 8 days.
    • Car should sit at 12.2 or more, maybe 12.6 or 12.7 when fully charged and happy. If there is a decent enough parasitic load then it will certainly go lower than 12.2 with time. You can't beat physics.
    • Ok guess I can rule out the battery, probably even the starter and alternator (maybe) as well. I'm gonna clean those leads and see what happens if it's still shit I might take it to an auto electrician. Unless the immobiliser is that f**king heavy, but it shouldn't be.  If I start the car every day, starts up perfectly never an issue. Isn't 12v low, shouldn't it be around 12.5v?
