Sau A.c.t. - What Did You Do To Your Car Today?
Had a bit of a crappy spray last coats of primer i put on.
Finally worked out ( I hope) the spray gun, had to watch a couple of long tutorials on spraying to work it out. Its a big difference in the amount of paint coming out, i can go a lot faster now.
And now the weather is going to be cold and wet for a week at least.
Today is a great day to spray, but lining up free time and good weather is tricky.
If i was an expert spray painter i could just do it and cope with problems using skill. Im not a good spray painter so i have to set it up for minimum hassle or i wont be able to do a good job.
It shows how good i am when every second time i touch the car i make a problem to fix. But im getting better and working out how to do it properly.
Ordered some braided line and fittings
Where from? When I get an oil cooler for the 33 I want to get some Good Hoses.
John at Trojan claims Cheapo Coolers are OK but cheapo Lines can collapse and that is a bad thing. :/
Are you doing them?
They are quite tough to fit.
In hindsight i should have bought the fitting spanners and vice sleeve too.
Your workbench needs to be heavy or youll lift it off the floor trying to do up the fittings.
Also think about an appropriate cutting tool/technique for the hose. Wayward steel strands are the devil when doing them up.
I have Speedflow and Chinaflow fittings, they are different in how they work but both just as hard to do up.
And wd40 helps.
Ps: When i set mine up i found the Earls thermostat shipped from the US was the cheapest.
Edited by D.I.Y. Mik
Wow that's cool! :thumbsup: Helps keep moisture out of the spray yeah?
Put my CNC cut woodgrain panels in the Wagon, still need a few clips to fasten them better.
Made a couple of matching boxes for tools etc also.
post-78856-0-40506100-1398849731_thumb.jpg post-78856-0-93959700-1398849733_thumb.jpg post-78856-0-10050800-1398849737_thumb.jpg post-78856-0-75730300-1398849727_thumb.jpg
I'm going to do a new Boot Floor for both the Wagon and the 33 aswell.
If anyone wants a fresh boot floor panel cut (3mm to 16mm thick) to replace the old cracked / warped / broken Masonite one,
I can do out of MDF on the CNC at work. (would have to measure up first etc...)
Yeah cool. I can either do a small one that barely covers the wheel well (like Stock) or larger to actually cover more of the floor.
Raw MDF, Woodgrain, White or whatever... Basically depends on what Scrap we have at work. ;)
and not a dodge, shakey, freehand jigsaw cut either.
Highly likely. Just need to measure up and try to find out the curve radius etc... Praps a little trial and error too.
The panel on the Wags tailgate is similar to a parcel shelf I guess what with speaker holes and curves etc... Could be fun! ;)
I was considering trying door trims too. :yes:
 Share
    • I know there's been no posts for 3 years, but figured it wasn't worth starting a new thread for my question. The nice Japanese lady in my V36 occasionally/randomly speaks to me whilst I'm driving.  Of course my Japanese is very rusty, I'm guessing it's to do with the Nav system? Anyone have knowledge on this?
    • there are probably many ways to do it for my bosch motorsport abs we used a r33 gtst abs front knuckle and modified the rear knuckle to allow sensor to sit and read understand time, effort and $$ but reading from anywhere else  you get diff chatter etc where you lose 30% ish in signal clarity compared to the above
    • Little more work!  Did some body work on the rear wheel arches and since the paint was a cheap spray job before figured I’d do something to tide me over until I wrap the car.    Colour might not be everyone’s choice but I like it and it’s only temporary, just hate having primer from the wheel arches standing out.    Keeping an eye out for a decent set of wheels to throw on now. Wheels and tires on the car are junk
    • Its likely to be 70% road 30% track usage, track usage will increase if anything. Decided not to fit it as I cant be arsed changing the bushes on my LCAs again 🤣 I did get the below back from GKTech though so they should work together     The anti-squat kit and roll center adjusters work independently since they change the rear lower control arm's angle in different ways. The anti-squat kit adjusts the angle from front to back, which impacts anti-squat values. Roll center adjusters change the angle side to side, mainly to correct geometry on cars that are significantly lowered. They might affect each other a tiny bit, but overall, you can think of them as separate.
    • What are you doing with the car? street car or race car? People get hung up on the squat of the s/r chassis rears. There is positives to the squat if a car is setup and driven correctly for it (correct ride height, spring rate, alignment, damper valving). Generally just lengthen the rear traction arm by 5-10mm and that will help the squat and bump steer too. You are also correct with the roll centre too. This too also needs to be adjustable if you start messing with suspension geometry.   Having done quiet a bit of testing on race cars this year in regards to rear squat, I've seen some big positives from it in regards to drive off corners and traction.
