Changed SkyWagz' Diff Oil. The old was OLD! and definately a little low.
Nulon SAE 90 took it's place. (glad I bought a 4L bottle when I did the 33) :)
I wonder if the diff will whine a little less now? I'll let you know. ;)
Spent alot of time (Fiddly F**ker!!!) replacing upper and lower trailing arm bushes on the Wagz today.
Old ones were fairly goosed so Nolathane went in.
Was going to do the Panhard rod bushes too but meh... I'm over it. Another day.
Feels alot more solid and steady in the rear and yes the Diff Whine is still there but definitely better since the oil change yesterday.
Guess the new bushes may not help with the whine though. :rolleyes:
post-78856-0-70311300-1399723931_thumb.jpg post-78856-0-73560600-1399723929_thumb.jpg post-78856-0-54626100-1399723927_thumb.jpg
Rob,
Squirt in 60-80 mls of Pro-ma. Must be someone in CBR sells it.
magic stuff (unless it's a LSD then not a good idea)
This stuff? --->> http://www.fueloiltreatments.com.au/technical/MBL8_oil_additive.html
Sounds pretty good. Thanks Scott. :thumbsup:
I may try some Nulon G70 --->> http://www.nulon.com.au/products/Specialty_Products/Manual_Gearbox_and_Diff_Treatment/#.U28voIGSyuk
but The Nulon oil I've put in is definitely an improvement. It actually sounded a little bit better again today.
I put nulon g70 in my transmission a little while ago and it definitely reduced some of the cold 2nd gear crunch.
Realised after putting it in that I'd only put in half the amount I was supposed too as well. I presume it would only be better with the correct ratio
I got that result ^^^ in the 33 just by putting in Nulon Gbox oil.
Haven't tried the G70 in the 33 Gbox or Diff yet.
Today I resoldered a dodge connection on the Drivers Front Speaker in the Wagz and put the charger on the 33's battery for some love.
Pulled the Whole Steering column out of the Wagz today and replaced the old Bushing with a Fresh SuperPro Bush.
post-78856-0-12031700-1399870038_thumb.jpg post-78856-0-43480600-1399870041_thumb.jpg post-78856-0-11314400-1399870036_thumb.jpg
Steering is much more direct. :thumbsup:
Found where the Immobiliser unit is hidden, tightened up the accelerator pedal bracket as it was quite loose and took some Slack out of the cable with a couple of Zip Ties. :)
Also hit the Grey Interior Rearview mirror with some Black as I did on the 33.
Much Nicer.
    • It only looks tidy, as most of the stuff that was on the whole back wall, is now in the trailer to go to the tip, or has been shoved in my 2.2x2.4m "Spare parts room", and now I can't get to anything in there Ha ha ha I could definitely do with a bit more space, but I'd just end up with your problems I'm going to enclose the car port beside the garage, and move a lot of stuff into it I think. OR... It will be setup as a fabrication area, and the main garage will have parts storage in it. I'm not sure yet... Need some pictures of that big shed you've got with the bikes and Skyline in
    • No. I think it's gone. 😭 I think you can get body coloured ones on eBay so I think I'll get one of those... Or just hang a red ribbon from the hole and whack a TOW sticker next to it.
    • Can't say I've had a bad experience with one on my car, then again it only gets washed once or twice a year... The wheels on the other hand, get a good spray often due to my shitty dusty pads.
    • @MBS206 thats pretty neat and tidy to me!  I'll get a photo of mine when I'm out there next. It might require multiple photos to understand the scale of the atrocities though... In total I have 4 sheds of varying sizes and layouts. Main shed is 14x8, second shed is 3x8, third shed is 11x2.5, fourth shed is around 6x4.  All are pretty much full.   The main goal of my cleaning tsunami is to make the main shed predominantly car and motorbikes only. Second shed is my metal fab room (2 x bench grinders, drill press, bench belt sander, metal band saw, scrap metal storage and some of my garden tools.  3rd shed is more bigger garden stuff, storage for engine crane, jack stands, concrete grinder, concrete mixer, air compressor lives there, and it now has two 2mx2m pallet racking shelves with itemised boxes holding building stuff, electrical stuff, plumbing stuff, etc, etc.  The 4th shed is Ryobi electric ride on mower, mini boom sprayer, ancient Kubota tractor, more garden stuff!  I have got a lot of shit....  Then there's the pool house (8mx4m) and the pool pump shed (4mx4m).  I built all of the sheds over the 11 years we've been here.  The main shed was a Ranbuild kit, the rest are all custom made to fit the areas available. Building the main shed taught me a LOT as I had no idea about building anything prior to that!  I've still got one more in me. It will be my man cave which I poured the extra concrete for way back when I poured the concrete for the main shed. The idea is the Skyline will be a centre piece of the main cave once (if...) it's finished.  I told my now 14 year old son yesterday that I will 100% drive him to his year 10 formal in 2 years. Still a long way off but at least I now have a date to work towards! 🤣
    • Modern oils are amazing. Add tyres to that as well.
