Clean aac valve as it is far easier, however if that fails the actual cold start valve under the plenum may need cleaning. It is painful to get too hence trying aac first. What's your idle rpm?
Ah ok cheers. PFC says 850
Haha mine has been idling at like 1400 for the past 2 years. Tried to adjust and just gave up
have you adjusted the aac valve the recessed srew on the left side of the plenum, or just the tb screw?
SkyWagon's New O2 sensor arrived today so I Installed it and reset the ECU.
Also gave her a new Phat earth wire from the block to Chassis. (original from exhaust manifold was removed when the extractors went on)
Got the High Beams working properly too. (2 out of the 4 bulbs weren't lighting up which I didn't realise)
Both and also played with the TPS.
I think it's caused by a faulty TPS but I could never be bothered trying to work it out.
Ah k fair enough. Yeah I'm pretty sure if I disconnect one of the plugs to the top its will idle about 1400
Old is New Again. (well at least for me) :D
Looking at getting a Reco'd Dizzy second hand as mine has a nice grinding going on at a certain RPM.
So Cap, Rotor Button, CAS and Bearing should be fresh-ish.
Just drove to the shops and back, seems alot smoother and more powaaah!
Might do the KLG plugs and new leads real soon.
Yeah traffic was pretty quiet too, which was expected with it being a week day.
Spotted a 33 4door doing laps as we pulled in :D
We will just check out the motor racing museum tomorrow then head back home
Edited by dontyellpl0x
ohhh 5hiv just be careful where the tolerances may change due to heat or the thickness of the paint specially on the injector seals. It would suck to see them pissing through that part.
Yea i got another stock rail as well :)
    • Hah, I have no issues with what you are doing whatsoever! You clearly know what you are getting yourself into. It's just funny reading things like this. "What's that noise?" "Oh, that's normal. That's just the engine not getting any oil. Nothing to worry about. It'll go away in a moment"
    • Yeah I'm keeping an eye on it and might take it out as a once off if this doesn't fully charge. I did some research that said it's normal in equalisation charging. Voltage I thought was 20+ (faulty battery in multimeter) but now its on 15.9v, the max it should go to is 16.2v as per the manual. I'll provide an update once hopefully it's actually fully charged and in float mode. Waiting for it to go to 16.2v and not higher and see what happens. What I suspect has happened is that even though it's not an old battery, I did leave the car turned off for almost 4 weeks at one point then left it off for another 2 weeks which might have erroded the battery and is taking a long time to do this equlisation charge.
    • I wouldn't be using the seats a lot since it's on Historic rego and will not be driven a lot, however I also don't want to fork out 3k for something that won't last. Havent looked at BRZ seats, aiming for something of the same era I did speak to him on the phone once, and I do see your point haha. How many kms do you think you drove before they started wearing out? Just had a look at yours, certainly looking for a reclinable version. The Brides don't look too bad! I would still like to sit in one just to make sure it's what I'm after.    Thanks for the replies fellas.
    • I bought my Bride reps from Crank Motorsport. He is, um, a trifle disorganised. I would have to look back at the e-mails to make sure I got it right, but I think he sent me normal fabric ones when I ordered the "Alcantara" ones. So he had to pay for shipping 3x and I'm sure that f**ked him off big time. And asking technical questions where nuanced English is required is a no go. It's simple English only. And....should I have bought the Alcantara ones? Well, as it turns out, they are great, feel great, etc, but the fabris wore through on the point of the waist bolster in <2 years. Must have caught a rip from a rivet on jeans or shorts, or something like that. So now I have to patch it somehow. A bit shit. My fault, ultimately, because it is Chinesium Faux Alcantara, not the real thing, and it turns ot that it has the tear resistance of a soggy tissue. But the seats and the reails are great. I probably should have gotten the R34 style ones, and now that they price is up in that ridiculous sort of number, I could have sold them for a profit!
    • Another recco is to just let it rest for a while and go back and reconnect later.
