Thanks for all the replies guys.
I'll check the spare wheel on the weekend and see if that helps.
S!n it has 96,000km on it but I think a full service was done in Japan because all the belts look new.
I didn't know capital did free quotes but thats pretty good.
Yeah I don't think bushes like being in a stock height position for years and then getting their angle changed through lowering.
A bit like how an old man can't sit with his legs crossed anymore. :(
  • Like 1
Wiggle, wobble and jiggle EVERYTHING!
Capital sounds awesome and to think for $14 Pedders will give you a full list of unnecessary and expensive repairs.
Welded up the road scraper today.
It had a split weld, and i added a plate on the bottom to make it stronger, and add some more meat to scrape off.
This is where it goes: post-89755-0-51611000-1413015774_thumb.jpg
The crack and, the plate: post-89755-0-55137200-1413015593_thumb.jpg post-89755-0-90437500-1413015615_thumb.jpg
Best mod i ever did, it protects the front bar from scrapes and such.
With the heavy duty reo above, it makes the front very solid. Stealth bull bars.
Edited by D.I.Y. Mik
Wow! So many ups and downs.
Action Galore.
NISSAN Number 2!!! :woot: Not f**kin Bad!
Awesome effort after throwing the car into the tyres at griffins twice haha. Can't believe they actually got it home.
Haha was going for redbull :( Shame it came to an empty tank :( Major badluck on Van and Frosty :O
Yeah feel so sorry for gis :(
I thought this was his year.
Scotty in the Volvo too, had great pace all day.
On the other hand I was cheerin' when whincup had to go full fuel saving haha!
Bad weekend for my team - hrt :(
  • Like 1
Oooooo corn syrup is going to be the best!
I'm going to check my current rims/tyres tonight and suss out if they will be enough to pass rego.
If they look doable then I will just book it in for an inspection at Dickson this week.
From what I gather it has to go to Dickson yeah?
Yeah all imports do
And yes Corn Syrup will be the best. I can't wait!
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
    • Yes. Imagine you have the car on the ground, and you mine away all the ground under and around it, except for the area directly under each individual wheel. That's exactly how it'd look, except the ground will be what ever you make the bit under each wheel from
    • Yes, if you set the "height" right so that it's basically where it would be when sitting on the wheel. It's actually exactly how I tighten bolts that need to be done that way. However....urethane bushes do NOT need to be done that way. The bush slides on both the inner and outer. It's only rubber bushes that are bonded to the outer that need to be clamped to the crush tube in the "home" position. And my car is so full of sphericals now that I have very few that I need to do properly and I sometimes forget and have to go back and fix it afterwards!
