sounds like it is permanently earthed
disconnect the small joining plug will obviously turn it off
had any electrical work done recently. Meaning has someone tapped into it to power something else ?
aftermarket alarm, central locking
the 2 wires from the connection to the ring haven't been stripped anywhere and touching metal?
all your doors closed properly? are the sensors in the doors all good?
All the sensors in the doors are working, interior light when its on door and all the doors are close its off, same with the dash board light for door open.
Recently i had the car tuned, after the car was tuned i went to pick it up the indicator started flashing like how if the doors are open it flashes the indicator but started doing when i turn the key on and wont stop so i just disconnected the alarm unit and drove the car home
got told that it started happened after he drove the car with the boot open and also the engine light was coming on as well and was just been told that the car has electrical problem. (everything was working fine when i dropped the car off)
I had the engine light fixed as the tuning was not right and it was detonating so a re-tune fixed that problem by a different tuner
I checked all the alarm wiring and also i put the stock ecu back on just to see if the ecu swapping caused the problem (power fc/stock euc)
Did managed to find that if i remove the black box (smart lock) the keyring light goes off but i can't control the passenger side door for lock and unlock from the driver side and also if i have the alarm connected it just won't stop flashing the indicators
Got a aftermarket alarm system with auto engine start and auto window roll up when the car is locked
Edited by 5hiv
Maybe the guys who put the Auto start/Window roll-up can help out
I use Audiotech in Tuggeranong for the last 12 years and about a dozen cars.
Dave should be able to sort it out
Edited by Sinista32
Hope you get it sorted 5hiv.
I got some woodgrain interior bits about 3 months ago, cut the centre console and put all that in. Just need some black leather to make a shift boot.
Today I finally got around to putting in my electric window and mirror switches. I blew the 25A fuse in hopes that it would work. Changed the facia and it all works.
Yep that ^^^ looks really nice. :thumbsup:
Washed the B17 Pulsar yesterday and fitted the New front weather strips.
They are supposed to be a set of 4 (according to Nissan), they are looking into this as the 2 sets they have gotten for me so far are only the fronts. :/
Washed the N13 Pulsar this morn and put in a cheap set of Red LED Dash lights.
  • Like 1
Haha!!! That's just cool. :laugh:
Drove the B17 Pulsar 1700km return trip to Nambucca and back (over the last week)
Great Car, Didn't miss a beat, A/C on all the way. :thumbsup:
10 hour drive today = Pooped now. :sleep:
Bought and Changed Spark plugs in the SkyHatch and got some coolant for when I change the Thermostat.
Seems Smoother. :yes:
Did a trial fit of some Rims I bought yesterday (Extremely Cheap) for the B17 Pulsar...
post-78856-0-49435500-1420953296_thumb.jpg post-78856-0-42251000-1420953410_thumb.jpg post-78856-0-69839500-1420953539_thumb.jpg <<--- Stockers.
They should be Fully Sick Chrome Starcorp Pro V's.
post-78856-0-86842600-1420953579_thumb.jpg post-78856-0-07027900-1420953816_thumb.jpg
Need the Crappy Black paint removed but will be MUCH Easier than when I did the rims on the 4door as it peels off easy.
Stock is 16x6.5 +40 with 195/60R16 and these are 18x9 +38 with 225/40ZR18. :woot:
Will Need more lows but likely won't get it...
cooz Her Car. :/
oh and F.Y.I... 20 Slim Shiny Alloy wheelnuts with internal Hex and key to suit are $30 from Bob Jane Belco. ;)
Flushed the SkyHatch cooling system and put in New Thermostat and Coolant.
Temp Gauge actually sits near 1/2 now instead of 1/4 and feels a little more zippy??? Less Rich I guess. :D
also put in the New Oil / Air separator crank case breather filter gauze mesh thingo.
HKS air flow less adapters that i bought are on backorder so got a full refund.
but there was a set on Ebay for $200 cheaper second hand! I love it when things go right!
    • You’re all still going on about track cars, he has said multiple times doesn’t intend to take it to the track,  just stick to what was said at the beginning and do the pump and ecu, it’ll get you enough for 230kw at the wheels and has enough poke to be fun for what you want it for
    • All of that is absolutely true. At any time in the history of these turbos the lottery has always been that it could die at stock boost treated exactly as the factory intended, or it could die when pushed to 10, or 12, or 14, or 16 psi, after a short time, or a longer time, or it could last seemingly forever. You have the combination of all the possible statistical (probably) normal distributions of manufacturing tolerances and quality outcomes, on top of the statistical distributions of failure modes (which might be normal, but are probably biased, like Poisson distributions). You get the lucky turbo and you can beat on it for years. You get the really unlucky turbo and it will crap itself as it rolls out of the factory gate. And every possibility in between. But you can definitely still kill the lucky turbo. It's just that most people didn't try, once they knew they really shouldn't try.
    • Maybe I have Stockholm syndrome but working on an M2 isn't that hard. Getting parts cheaply and quickly is hard, but getting parts same day isn't necessarily hard if you're willing to pay way too much for it at local dealers. There's a lot going on, you need to have a build of ISTA on a laptop and the right cable, if you don't have the mindset of "do it exactly right or not at all" you will probably start seeing cascading failures. Skylines are a little more tolerant in that regard. The car doesn't potentially trash itself if you bought the wrong oil filter like a BMW would. Or trash the entire cylinder head and potentially spin a bearing because someone took the anti-drainback valve out of the plastic oil filter cap. An M2 will also do just fine on track, zero oil starvation concerns, factory brakes are great if you change the pads for a high temp compound + flush with track-ready fluid.
    • The "ideal/formula" that used to be touted was death of the turbo is going to be caused by a combination of 3 things. Heat Speed of turbo (boost level you're pushing) Time   Basically, you can get away with high heat and high boost for short periods. But start doing long hard pulls, or circuit driving etc, and now you've increased time as well which will shred things. From memory when Adrian was drag racing he was running 17psi, on a stock turbo, and running insane speeds. But he also had other additives helping in the setup too. Some people have success at 14psi for a while, while others due to pushing the cars hard for long periods opt down to lower temps. But also, generate a lot of heat (let's say bad tune), for a long time, and you'll be okay, until you try to spin that little guy up slightly. It's the one advantage of dumping a lot of fuel in, you'll be reducing EGT a bit and helping with the heat portion of the above 3 areas.   And these days, stock turbos are that old that there's the possibility of just outright failures due to material age. I'm not shocked that even when used in factory spec that a stock turbo fails when 30 years old. It's a worn out "precision" "balanced" performance item, that's likely no longer precise, or well balanced
    • this... hence I said what I said previously, SMSP nights you see mainly Hondas, Evos, A90s, F80x and the odd VW. The 5 or 6 times I went, I only saw 1x R32 GT-R, and other than that I was the only one in a shit box Skyline.
