Temp fix (cover up) of my shredded steering wheel. Thanks to Mr Steering :)attachicon.gifImageUploadedBySAU Community1421387747.654376.jpg
nengun-4455-06-mines-r34_steering_wheel.
perm fix :P
Edited by RosieR34
Chris, take it to Shaun at Trims in Mitchell (just down the street from Trojan)
$300 and comes back like new :thumbsup:
Yeah will be getting it properly retrimmed later and will see Shaun. For under $20 it will do for the time being and stop the black from peeling off on my hands everywhere.
Yeah as soon as I posted I was waiting for someone to put up the mines one up. Hideously exxy though but can't help but want it :)
I actually thought it was the mines one at a first glance haha. $1,200 for a bracket.... haha
Replaced some vac hoses and went to replace my o2 sensor and noticed it was only half threaded in :/ then noticed the thread is stuffed. Here's to hoping the new one stays in long enough for me to get to the exhaust shop next weekend.
Booked in to get my car inspected for act rego on Monday, thanks to anfanee for telling me where to go. Don't think it will pass though haha
Edited by Stagea97
Over the last couple of afternoons I retrimmed the tops of the Doorcards on the SkyWagon.
post-78856-0-53567100-1422437414_thumb.jpg post-78856-0-41208800-1422437373_thumb.jpg
Not Perfect but alot closer to it than the old, stretched and wrinkled stuff.
(didn't get a before pic of the old but you get the idea)
also the Mailman delivered some Low Springs for the SkyHatch aswell as Rotors and Pads for the SkyWagon.
:woot:
  • Like 1
Ordered some bits and pieces for my various cars lol.
Aiming to have the flex fuel and retune done on the gtr before a trackday towards the end of march. Would love some semis too but im too poor at the moment.
Awesome Stuff Jeremy!!! :woot:
Happy with it? Feels more alive?
R34 GTST? :laugh:
Yes very much so! So much more power i feels! Very responsive top. Loving this cold weather for it as well.
Thanks for bringing me to the dark side :D
  • Like 1
Today I put a 30cm long x 2mm deep gutter rash on one of the LMGT4s
Very dirty on myself :rant: . From mint to shit in a few seconds
Not to mention how that devalues them and looks farked
    • You’re all still going on about track cars, he has said multiple times doesn’t intend to take it to the track,  just stick to what was said at the beginning and do the pump and ecu, it’ll get you enough for 230kw at the wheels and has enough poke to be fun for what you want it for
    • All of that is absolutely true. At any time in the history of these turbos the lottery has always been that it could die at stock boost treated exactly as the factory intended, or it could die when pushed to 10, or 12, or 14, or 16 psi, after a short time, or a longer time, or it could last seemingly forever. You have the combination of all the possible statistical (probably) normal distributions of manufacturing tolerances and quality outcomes, on top of the statistical distributions of failure modes (which might be normal, but are probably biased, like Poisson distributions). You get the lucky turbo and you can beat on it for years. You get the really unlucky turbo and it will crap itself as it rolls out of the factory gate. And every possibility in between. But you can definitely still kill the lucky turbo. It's just that most people didn't try, once they knew they really shouldn't try.
    • Maybe I have Stockholm syndrome but working on an M2 isn't that hard. Getting parts cheaply and quickly is hard, but getting parts same day isn't necessarily hard if you're willing to pay way too much for it at local dealers. There's a lot going on, you need to have a build of ISTA on a laptop and the right cable, if you don't have the mindset of "do it exactly right or not at all" you will probably start seeing cascading failures. Skylines are a little more tolerant in that regard. The car doesn't potentially trash itself if you bought the wrong oil filter like a BMW would. Or trash the entire cylinder head and potentially spin a bearing because someone took the anti-drainback valve out of the plastic oil filter cap. An M2 will also do just fine on track, zero oil starvation concerns, factory brakes are great if you change the pads for a high temp compound + flush with track-ready fluid.
    • The "ideal/formula" that used to be touted was death of the turbo is going to be caused by a combination of 3 things. Heat Speed of turbo (boost level you're pushing) Time   Basically, you can get away with high heat and high boost for short periods. But start doing long hard pulls, or circuit driving etc, and now you've increased time as well which will shred things. From memory when Adrian was drag racing he was running 17psi, on a stock turbo, and running insane speeds. But he also had other additives helping in the setup too. Some people have success at 14psi for a while, while others due to pushing the cars hard for long periods opt down to lower temps. But also, generate a lot of heat (let's say bad tune), for a long time, and you'll be okay, until you try to spin that little guy up slightly. It's the one advantage of dumping a lot of fuel in, you'll be reducing EGT a bit and helping with the heat portion of the above 3 areas.   And these days, stock turbos are that old that there's the possibility of just outright failures due to material age. I'm not shocked that even when used in factory spec that a stock turbo fails when 30 years old. It's a worn out "precision" "balanced" performance item, that's likely no longer precise, or well balanced
    • this... hence I said what I said previously, SMSP nights you see mainly Hondas, Evos, A90s, F80x and the odd VW. The 5 or 6 times I went, I only saw 1x R32 GT-R, and other than that I was the only one in a shit box Skyline.
