Today I put a 30cm long x 2mm deep gutter rash on one of the LMGT4s
Very dirty on myself :rant: . From mint to shit in a few seconds
Not to mention how that devalues them and looks farked
What a nightmare! :(
Edited by dontyellpl0x
Ill take them off you if you ever decide :)
  • Like 1
I scratched my LMgt4s doing a Macccaz run was so posses that day.Powdercoated them and was happy again.
Rebuilt my calipers and powdercoated them wth Shiv.They looked great didn't want to put them back on.Whilst rebuilding bought braided lines and slotted rotors and pads. Now I need to find out how to bleed the master cylinder before I give up and take it to a shop
  • Like 3
MObile fabrications in Quenbeyan and Shiv for the calipers. Just some warning powder coat is a thicker layer, some areas with fine tolerances will have to be covered up or your wheels will not fit on the hub
Thanks Bryce - If I need powder coating I know where to go now.
I went and saw Craig at Wicked Wheels. I am going to give him a go for the rim - will post feedback.
seems like a good guy, so I'll see how it turns out before reporting back.
(March 2nd - is a busy workshop)
Anf - let me know if your interested in my R32/4 RB20DET (Auto)
Will likely be putting it up FS very shortly and looking for $10k in my pocket
Or any ACT SAU peeps
Drives beautifully, goes great guns.
1989 M Spec with ABS and Auto Spoiler. 117k kms
Paints very good but does have some stone chips on the bonnet.
Privately Imported into the ACT as a 4b in 2004. I'm 2nd owner in Aus
Full service records since import at 37k kms.
99.99% OEM (head unit and sub)
Things I've done
Major Service, rotors and pads
Aftermarket head unit, 4xspeakers and small 10" sub in boot
Remote keyless entry
Front/Rear bars resprayed
New windscreen
2 full sets of GTSt rims and running on mint 32GTR rims
HD rear sway bar
Newly recovered 32 steering wheel
No dash bubble
Ïnterior & seats etc awesome.
GTR car mats front and rear in really good cond
Small crack on drivers arm rest :(
For those who haven't seen her it is very naice :thumbsup:
Reason for selling. Got my eye on something else more sedate
Edited by Sinista32
Beautiful car and Drives amazingly for a 26yr old. :yes:
    • Oh yeah forgot to also mention need to also unplug the IACV as well. Thanks for the reminder @MBS206 Unplugging the TPS takes it out of closed loop so you're able to screw down the IACV without the ECU trying to add/subtract timing to maintain the idle (not sure PowerFC can even do this, but Nistune and the OEM definitely does)
    • For sale is my 1999 Nissan Skyline R34 GT-T, tuned to 234 kW / 313 hp. I've had the car for a few years as my daily driver. The car is original (as far as Skylines go), with only a few minor upgrades to enhance performance and driving experience, as typical for such a car of its age. Overall, it is in great condition with no body rust, thanks to its earlier import date. It features a top-notch security system (not literally, but it's great!) with remote start and still functional 4-wheel steering via HICAS. It comes with several performance and handling upgrades, including:     Hypergear 450HP Turbocharger running 17 PSI boost, installed mid-2021 by Jaustech     550cc injectors     Nistune ECU     Front-Mount Return-Flow Intercooler     X-Force Stainless Steel Exhaust     Upgraded engine mounts     Bottom end bearings replaced     BC Coilovers     Lenso DR1 rims     Bridgestone Potenza Adrenalin RE003 TL 245/40R18 97W tires, fitted early 2023 The interior is mostly stock, with a few additions:     Viper Satellite Tracking System with remote start     Bluetooth Double-Din Touchscreen Head Unit     Steering wheel cover Cons:     A few paint imperfections here and there     Driver’s seat shows more wear than the others. It's not torn at all, but I've added a seat cover to protect its condition. I also have a CarVX Vehicle History report available for serious buyers, so you don’t need to purchase it yourself. Price: $26,000 ONO.
    • I've had two suzukis in the past have an extremely hard time turning over and not starting after sitting for a few weeks. Ended up the alternator would seize up causing the starter to force. Same issue both times.  Maybe they're sourcing their alternators from the same place...
    • Ah right. Maybe my rb just loves chewing through batteries lol.
    • On the R34 can't you just unplug the IACV? This is the way I've always done it on the R33. Disconnect IACV, get it idling around 650rpm, and then do a power reset on the ECU to get it to relearn idle (factory ECU).   The big reason no one has touched on as to why you'd want to get the base idle right, is that it means the computer needs to make smaller adjustments to get a good idle at 700-750rpm.   Also, cleaning the IACV won't normally make the car suddenly idle lower or higher. The main issue with the IACV gumming up is that the valve sticks. This means the inputs the ECU gives, aren't translating to changes in air flow. This can cause idle choppy ness as the ECU is now needing to give a lot of input to get movement, but then it moves too far, and then has to do the same in reverse, and it can mean the ECU can't catch stalls quickly either.
