Fits up nice, no probs.
Wastegate is nice and free now, car goes fine, seems like no damage. Battery still good.
Sweet.
Ooh... is that a Mild Steel Bellmouth?
When you've put it on, you wanna put my Stainless Bellmouth on for me? :D
Mild steel.. just as good, maybe better as anyone can weld it if theres any probs or mods.
Depends..... if its from the same factory as my stainless split, you can chuck it in the bin now and save yourself a huge hassle.
Or its a breeze when it fits like the new one, Just jap said the mild steel bellmouth is made here, and the stainless split was China.
Stainless Bellmouth courtesy of JJR !!! Figured for an extra $20 I'd get the Stainless to match the rest of my Zaust.
Does your car go any better or sound any different?
nope, same
if you think about it, the split doesnt make more power or anything cos the gate is shut with throttle on anyway...
Just thought it might flow a bit better and maybe sound a bit deeper / louder etc.
Wouldn't the gate be open at wide open throttle?
No, its shut making boost (mostly anyway) and as the pressure climbs, it pushes on the wastegate actuator, opening the gate and dropping the pressure.
The wastegate allows hot gasses to pass by the exhaust turbine without pushing it around.
When the gate is shut all the exhaust energy is pushing through the turbo, and spins the compressor making boost.
I didnt know any of this 2 years ago, SAU educates.
Yeah that's sorta what I mean, as in...
say if you have a 10psi actuator on your turbo and you floor it, the actuator is holding the gate shut until you reach 10psi (which takes no time at all) but then at that 10psi air pressure the actuator opens the gate to bypass the exhaust wheel and stop overboosting, giving you a constant 10psi of boost. Meaning that from say 3000 rpm to gearchange, the gate is open and both outputs of the turbo are releasing the exhaust gases into the dump.
whether it's a stock dump, split dump or bellmouth, but being that both outputs are pumping into the larger chamber of the bellmouth, I thought it might sound a bit fatter.
When I get my Bellmouth on, it will be an upgrade from the stock dump with a 3" frontpipe, where as you have gone from an aftermarket split dump to the Bellmouth which may not be as drastic a change power wise.
and yes SAU does educate but can also be quite misleading at times...
4WD/2WD button installed.
Lights up BLUE off (4WD) and RED on (2WD)
been meaning to do this for a number of years. Procrastination at its best.
Originally had a HKS Torque/Drag controller in her but that was put to better use in a 9.3 second GTR.
Niiiiice. This is a massive advantage of the R32's ATTESSA system in my opinion. lol. The ability to electronically switch to RWD mode without having to drop the front driveshaft.
Used it to jump start my Fozza. Took Fozza for a spin around the block.
Some white smoke coming out of engine bay. I am hoping it is just from dust etc. from sitting still for so long.
Going to hit the engine with some degreaser and hose it out tomorrow. See if that clears it up.
Ta Troy - it is fairly awesome
Anthony - Well you haven't smoked up the rear tyres then - lol -> (hoonish)
quick pix
note also the 4WD light comes up on the dash
Nope. Car is still to new im scared ill break it!!!!
Edit: spent 4 hours the other day trouble shooting my HICAS. Previous owner butchered it pretty hardcore. Turns out it has an electronic bypass using a switch. However the wiring was done so badly it can't be recovered. On top of that my rims are too big and will rub if i turn it back on. So im just going to remove the bulb of the warning light. And WHEN i find a job ill look into options...
Edited by Anfanee
Overboost again...
So ill wait for it to cool down and change the actuator back to the old one and the bov too.
Brown sludge in the radiator? wtf? i just cleaned it all out. maybe the head bolts needs a re-torque after all the overboosting. maybe the turbo seals are going.
Brown sludge is pretty common in skyline cooling systems, try flushing the motor and rad 1st, its easier than headstuds :)
WHen i replaced my manifold coolant hoses the other day they were 1/2 solid due to the crud build-up in them as it clearly hadnt been flushed ever lol.
Washed and Vac'd my car today. Also did a few little things in the engine bay, still pretty messy though :/
    • I like it when the counter chick leads you out the back into the racks and says "have a grub around in here and see if you can find what you need. I'll be back in a few minutes. Just left me in front of a massive motorised shelving system and 2-3 million fasteners, so I could find a peculiar SS shoulder bolt with cap head. Gotta love country towns.
    • I used this https://osgiken.com.au/product/os-giken-os-250r-lsd-gear-oil-80w250-1-litre/   shut my nismo 1.5 pro up by heaps…. Not silent though. Gives the car character and personality. It ain’t a carolla. If you want silent, put a quaife in it.
    • It's about the same time for me from Bunnings, or the Fasteners. My big push away from takeaway food, and gluten in general keeps me away from the Bunnings Snags too! Weather up here, I've been out for two walks today in the beautiful sunshine. Had a few little drizzles, and some wind, that honestly, a tin of beans and I could compete on how harsh she blows Thankfully, being this bit inland, we're not getting anything much really. Will probably pick up a bit more when/if Cyclone Alfie decides to come ashore. A few areas in the GC though, and south into NSW are really getting smashed though! Right now, I'm just annoyed Alfie hasn't hit, as I'm not allowed to crack into the BBQ foods like the bacon and eggs until the Cyclone hits "In case we lose power"...
    • I love fastener joints, the price difference between them and joints like Bunnings or Super Cheap is amazing, and they either have exactly what you want, or they can get it to quick They have even given me some for free when I only needed a couple of specific size In saying this, I have paid premium for fasteners from Bunnings if they have the sizes I need, but only for convenience really, as my local is only 10 minutes away, the Sushi joint near them is also a consideration  How's the weather Matt? Stay safe mate
    • Wideband is worth setting up if only for tuning purposes. I would not mess with the ignition system unless there's a misfire. HKS crank trigger is popular out here for the relatively easily sourced Denso crank sensor, not a bad idea to install as well regardless of power level on a standalone. Boost leak test is worth thinking about. Oil pressure sensor tied to a fuel cut isn't a bad idea either. Getting the tune figured out is a good idea. Without putting eyes on it and getting under it there's no way for us to tell you exactly what it needs but most likely you're down to the last 10% that will make a big, big difference in how happy you are with the car.
