Assume if you like butt it's tight (_*_)
(nohomo)
Today replace L/R wing mirrors with New mirror glass and shiney nismo fuel cap on
:thanks: to the new and spare parts section at SAU meet up last night :thumbsup:
Thanks for kind words Eric. Bring it back nxt weekend, leave it for the day, and wallah - NEW Fozzie :)
Here's what I did today (besides dropping half a carton of burbs and a pack of darbs into my physic -lmao)
Put the new side mirror glass in but not worth a pic. Thanks KYLE :D
EDIT: New drink holder works a treat :cheers: . Tested and it prooved 100% as per advertisement.! Would recommend :D LoL
More stock arriving shortly - lol
Seriously though if I could afford too I would run a JDM shop in Canberra.
My passion is definately there but not the capital and the market can be so finicky. Everyone wants the very best for very little.
Pulled out some front suspension bits, got the bearing numbers, monday ill see if i can get em.
It makes that creaking noise
So i pulled it out
Bearings are in this bit, so i can just take it to someone with a press.
top is 6204V bottom is 6907L8, the top is common ill find out about the bottom.
Easy peasy, wont even need a wheel alignment.
Edited by D.I.Y. Mik
Went for a run at the Drags =)
30deg day.
Mostly stock. only FMIC and 3" exhaust.
15.2 sec, 91mph. .5 reaction
I'm pretty happy with that
next month hopefully mid/low 14 with a bit of extra boost and a bigger radiator.
Also just found out a mate has the clutch from my old car which is the purple exedy or Greddy (not sure) one. so might be swapping that in =)
  • Like 1
Yeah Richard's quite the man when it comes to detailing, really knows how to make stuff come up nicely! (now if only he could give himself the once over....:ninja:) hahaha kidding R! But no seriously Richard does some amazing work with simple DIY car detailing. Very impressive. If there were more money in it, he'd make a killing starting his own shop I reckon
    • If you are keeping the current calipers you need to keep the current disc as the spacing of the caliper determines the disc diameter. Have you trial fitted the GTS brakes fit on a GTSt hub or is this forward planning? There could be differences in caliper mount spacing, backing plate and even hub shape that could cause an issue.
    • Hi there I have a r33 gts with 4 stud small brakes, I'm going to convert to 5 stud but keep the small brakes, what size rotor would I need?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
