Til they're tight and then a little bit more... Don't Cross Thread them and Don't Over Tighten ! They can break.
Can give you a hand if you need it. :thumbsup:
Can vouch for my local mechanic. He knows what he's doing.
Until it comes to heat shields ! :P
Just Keeping my cool my man... :D
and how bout you? You figure out how to take the Handbreak off yet? hahahaha...
Haha yeah man - handbreak all the way up because of your A/C running :P
Thanks for the offers of help, I'm going to give it a shot on Saturday solo, just stay tuned for desperate cry's for help, although by then its probably too late :P
What side of town are you at?
Handy Hints:
Tape over or stuff a CLEAN rag in the pipes you just pulled off to get to the head.
If your coil harness is as old as mine, be careful the plugs can be brittle and break.
I find it easier to undo the bits the coils are bolted to, and take it all off in one go. Two bits actually.
With those gone you can get to any nuts or bolts you drop down there, and you can clean spilled oil and stuff easy.
Plugs are pre gapped, this is the easy way to get it right. get the right plugs.
Before removing the plugs, give it a good blow with compressed air and get any bits of crap out.
Those bits of crap can fall into the cylinder or foul the thread for the sparkplug.
The correct way to tighten the plug is explained clearly on the box.
Dont overtighen the coil brakets, its into alloy, so its soft, blue locktight is good.
Dont forget to remove the rags from your pipes (ive done that before haha)
easy peasy japanesy
Rosie in today at Craig Hall in Phillip. Getting suspesion down - legal height and wheel alignment :)
Update: dodgy seller didn't have a "bush" (?) in the front coil overs so that's not getting done today. Break pads instead. Does that mean I need to purchase new front coil overs? He was saying it would be hard to find a bush for the front coil over? :S
Edited by RosieR34
do you know the brand of coilover? find out exactly what bush was missing, inline may be able to help you out if you can't source one from a local parts store. - repco can sometimes be handy for things like that.
  • Like 1
G4's - one of the front bushes are missing.
assuming you are talking about one of the bushes in the G4 coilover (must be noisy as hell!), you should be able to get what you need from a retailer (just jap) as they can be fully rebuilt.
Yep G4 coilovers - one of the bushes in the front coilovers is missing (Uninstalled). Just Jap sells bushes for G4's? :D brbrbrbrb
Hmm Just Jap doesn't seem to have G4 coilovers / bushes / whatever I was meant to be looking for.
Edited by RosieR34
Its funny I've got the same issue with my Tiens, for some reason the front rubber ring that sits at the top of the spring is gone, make it noisy as hell
did you give them a call and explain what you were looking for?
Nah - they have a very specefic range with suspesion it seems on their website. I'm going to assume they don't stock G4s.
Welcome to my boat - it's a sucky ride.
Edited by RosieR34
    • hey OP can you remind me what the actual question was, I got sidetracked at V12. Do you have an turbo oil return leak and an unidentified coolant leak? The factory oil returns are terrible design; short, rubber and expensive to replace. They are very common to fail and a pain to replace because they are so short. Still, they are available new if you want to replace both last time I checked. For the coolant leak, any competent mechanic should be able to do a pressure test; that should show up where the leak is. It is almost certainly one of the billion 30 year old rubber lines which are now brittle as hell, you engine will be fine.
    • From the OP's description, sounds to me like the TCU is in 'limp home' mode --- that is, no actuation power to shift solenoids, and the EPC valve is shut (full line pressure). This effectively sticks the box in 3rd gear, with as much line pressure as possible, to try hold the high clutch clamped shut....and so you get woeful acceleration and don't feel any shifts (because they're not happening). If you don't have Consult or some other scanner to interrogate the TCU itself, you can test with a multimeter to see if it's in limp home mode....ie; stick it in D with engine at idle (hold vehicle with hand/foot brake), and measure the voltage at the TCU feeding shift solenoids A & B -- both should be ON (battery voltage). If they are energized at the TCU, you can unplug the harness from the TCU, and check resistance down through the wiring to the solenoids themselves -- you should see about 20ohms on each coil --- if you do, you can presume the wiring to shift solenoids is OK -- if both measure open circuit, you have to check intermediate connectors in the loom down to the gearbox (and the gearbox connector itself), and check the shift solenoid resistance at the gearbox connector itself --- if the shift solenoids test open circuit here, problem is in the box (ether the solenoids or wiring to them is bad). If you get no voltage at TCU connector for the shift solenoids (and the solenoids/wiring test OK), check powers/grounds to the TCU itself --- if they're ok, it suggests the TCU is the culprit (and you'd need to interrogate it if possible, to find out why it's behaving badly)...
    • Hey mate give Autotechnica a go, I recently got some Comfort PUs and rails from them, they're comfy and look great highly recommended! https://www.autotecnica.com.au/part-finder/nissan/skyline/r32/
    • Honestly, for a daily I would gladly rock a Camry. The more disposable the better. People drive horribly out here and road conditions are awful.
    • Verify it's going into each of the 4 gears in normal acceleration, make sure the torque converter locks up over ~65-70 kph or so at low throttle opening. If you ease into the throttle at those speeds eventually you should get a "gear" between 3rd unlocked and 4th locked. It should downshift eventually if you floor it at 65 kph too. Get some Matic D ATF and drain the pan, check for signs of sadness in fluid and drain plug magnet. Top off to the correct level afterwards. If the transmission is worth saving you can drop the pan on a second drain and change the filter while you're at it. These are not complicated transmissions, at least compared to modern stuff.
