Went to drive it the other day. No spark... Dead battery after sitting untouched for 2 weeks whilst on holiday.
So got the new one in today. Changing a battery should not be so bloody annoying!!!
Trying to get the amp out which is mounted on backboard behind carpet wall, then trying to line up the holes again to put it all back in.. sheesh
5 minute job is now an hour!! Glad I won't have to do that again..
strut brace wasn't so much an issue, as i replaced it with another skinny one, so slipped straight under.
A little fiddly getting to the terminal bolts though. Worst of it was just the mounting for the amp. It's mounted to the frame the battery sits on =S
Bought some steel for front reo, when i was in mitchell i dropped into trojan.
He has 18" gold Volk GTC rims. They fit. I like. I like price.
Are they good wheels?
I mean have people had probs with them?
GREAT RIMS - I have :yes: on my 34 GTT.
Check they are 18's.
I know he has a set of 17"'s
No problems. One of the best
Rays Engineering - cant get better
Edited by Sinista32
Thanks, will check.
They look in real good nik too.
9" for the back and 8"for the front.
No...
17"x 9" all 4
Hmmmm.... maybe i should keep looking.
Edited by D.I.Y. Mik
Today i rebuilt the often intermittent R32 headlight switch. I Basically just pulled it all apart and sanded all the contact points, tested it out and it still did not work. :verymad:
So i pulled it apart and had a closer look at how the switch worked, everything seemed to be fine. However i thought it was worth trying to put more pressure on the contact points by stretching the spring mechanism about 1.5mm and it did the trick and now both headlights work.
The 3 black points have little springs under them that can be stretched to make the contact strong and also gives the switch a much better feel.
3e15f193-3a74-4f3f-9bea-fbf4ce78fbe9_zps
Also took the car out to check tire pressures
e540a509-3597-4f65-b94a-4f7148741bf4_zps
Confirmed my Central Locking is not working properly, could be from recent rain??? or the other night when the alarm went off cause of keys in my pocket.
Pretty sure yesterday the drivers door was the only one that would lock / unlock. (which is wrong)
Today the Drivers door is the only one that doesn't work. :(
Edit* Also, while looking through the paperwork I got with the car, mostly looking at the Alarm instructions etc, I flipped through the import papers. (guy I bought it from imported it.)
I can see that it says something about Auto to Manual conversion but I can't read Japanese (can anyone Help?) unsure of odometer reading at time of conversion...
In the pic of the car I can see it had Series 2 tailights on it but it landed in Aust with Series 1s. (confirmed by previous owner)
but also it looks like it had R33 GTR rims in Japan too but landed with 16" ASSO rims. :( No Fair!!!
r32 batteries are easy to change ;)
Time to re-arrange the front bit. Its too crappy.
Now i have a welder and some steel its time to make it nice.
And shorten those pipes, with an intercooler flip.
No butchery this time, its cut and weld it good time.
This should be part of my "final solution"
    • Last year I got a set of MCA street coilovers for my turbo Forester after my son hitting a concrete gutter/wall on a small bridge causing the whole drivers side suspension to get bent because the rain just made the car slide out I love them, I think they were $2400. even had a hiccup of have the wrong hub configuration (my fault) so got onto MCA and they sent the correct shock ends overnight parts from QLD, for free!  I was very impressed with their customer service and quality of the product
    • They've had some weird failures on their brake actuators. One of them was because they added some kind of lubricant to the factory fill brake fluid that aftermarket brake fluid didn't have so it would affect the seals. Another was just mysterious, probably internal corrosion or something eating away at Prius brake actuators. Parts alone for those are a few thousand USD so not a cheap fix.
    • Selling a genuine Nissan Skyline R33 Coupe 8-Pin Power Window Master Switch Part No. 25401-26U10 Price $300   IMPUL Gear Knob – Rare JDM Upgrade Upgrade your interior with this genuine IMPUL gear knob – a rare and stylish addition to any JDM build. Premium quality, perfect fit, and an authentic Japanese touch for your ride.  Price:$300 Nissan Skyline R33 (Series 2) Sedan Tail Lights Immaculate Condition OEM JDM S2 a pair of OEM Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state. Price:$900   Located in Melbourne (Western Suburbs) – Shipping available Australia wide at buyer’s expense. DM if you need anymore details.
    • KYBs are typically twin tube, putting them in the lower tier of desireability. Do you just want to replace worn out ones for the lowest cost? I mean, you wouldn't just replace one end of a car, if the rears are a similar age to the fronts, then they are probably nowhere near what they should be, and likely won't be great against brand new fronts. So, to spend ~$800 on 2nd tier dampers, when you could get a decent set of MCA coilovers for <$4k.....? As to the strut tops. 1st up, the Sparesbox site specifically tells you that they are not correct for an R33. Beyond that, why do you think you need them?
