Got my Car Back! :wub:
No Dyno run today as there were other more important things doing.
192.4kw is the result. :woot:
That'll do.
Thanks Heaps to Sinista32 and Pattey21. You guys know what you did. :thumbsup:
And John at Trojan Motorsport! Top Bloke, Top Service and Top of my list for Skyline Work.
:bunny: VERY HAPPY! :banana:
Maybe oneday I'll get a Real ECU...maybe.
  • Like 1
What speed were you running the holesaws at (and for what size) whst brand was it and did you use coolant?
Dunno what speed, no coolant, only 20mm diameter.
What im getting at is that i was using it for a job that it wasnt designed to do, in a way that would normally destroy it, and it coped ok.
i had a go with the large diameter ( 72mm ) and they dont handle it. Its just Aldi stuff, hit and miss tools. Metal cutting discs last about 40 seconds, but the grinding disc goes forever.
Finished cutting and grinding these things to reinforce where the intercooler pipes go through: post-89755-0-79648500-1380177367_thumb.jpg
They go under here: post-89755-0-90995800-1380177381_thumb.jpg
And on here: post-89755-0-90906000-1380177395_thumb.jpg
One has an extra hole for oil lines and stuff. Like for this cooler i found at the wreckers. Its replacing the bit of pipe they use as a cooler for the power steering.
gotta get a real skyline first.
im sorry i didnt mean it <3
great result dude! how is the response feeling?
ARSE!!! :laugh:
Feels better again than before + Bung is out of the Zaust... So Loud!
181.8kw to 192.4kw does actually feel different but the low throttle response and midrange is amazing compared to the doughy richness without the SAFC.
Worth every cent.
Oh yeah... There's definately noise.
I wonder how much? It was at 92db with bung in, Stock dump and frontpipe and cat when I got it registered nearly 3 years ago = Fail.
Now with bung out, JJR Bellmouth and Catco 3" cat... :rofl:
Defect waiting to happen. :(
yeah i use 1 heat range colder plug (7). My boost tapers off to 9psi too oil intake can cause pinging. Do you have dyno sheets. I asume the pinging result is off knock phones not the safc output which is heresay at best.
Plugs are now BCPR7ES (unsure of gap) and apparently they use 2 pair of Human Ears, there's to much electrical interference to use their Knock Ears.
I will clean all oil from intake pipes including SMIC soon.
Anyone know of a good Free Flowing, quietish Twin Tip Muffler?
Need one.
Thanks for shoutout
Oh yeah, and thanks to Jeremy for helping me acquire more knowledge and experience by having me fix his cars while he stands by scratching his arse with a big WTF? look on his face.
Thankyou Jeremy. :P
  • Like 2
    • So it's a ginormous undertaking that will be a massive headache but will be sorta cool if pulled off right. And also expensive. I'm sure it'll be as expensive as buying the car itself. I don't think you could just do this build without upgrading other things to take the extra power. Probably lots of custom stuff as well. All this assuming the person has mechanical knowledge. I'm stupid enough to try it but smart enough to realize there's gonna be mistakes even with an experienced mechanic. I'm a young bloke on minimum wage that gets dopamine from air being moved around and got his knowledge from a Donut video on how engines work.]   Thanks for the response though super informative!
    • Yes, it is entirely possible to twincharge a Skyline. It is not....without problems though. There was a guy did it to an SOHC RB30 (and I think maybe it became or already was a 25/30) in a VL Commode. It was a monster. The idea is that you can run both compressors at relatively low pressure ratios, yet still end up with a quite large total pressure ratio because they multiply, not add, boost levels. So, if the blower is spun to give a 1.4:1 PR (ie, it would make ~40 kPa of boost on its own) and the turbo is set up to give a 1.4:1 PR also, then you don't get 40+40 = 80 kPa of boost, you get 1.4*1.4, which is pretty close to 100 kPa of boost. It's free real estate! This only gets better as the PRs increase. If both are set up to yield about 1.7 PR, which is only about 70 kPa or 10ish psi of boost each, you actually end up with about 1.9 bar of boost! So, inevitably it was a bit of a monster. The blower is set up as the 2nd compressor, closest to the motor, because it is a positive displacement unit, so to get the benefit of putting it in series with another compressor, it has to go second. If you put it first, it has to be bigger, because it will be breathing air at atmospheric pressure. The turbo's compressor ends up needing to be a lot larger than you'd expect, and optimised to be efficient at large mass flows and low PRs. The turbo's exhaust side needs to be quite relaxed, because it's not trying to provide the power to produce all the boost, and it has to handle ALL the exhaust flow. I think you need a much bigger wastegate than you might expect. Certainly bigger than for an engine just making the same power level turbo only. The blower effectively multiplies the base engine size. So if you put a 1.7 PR blower on a 2.5L Skyline, it's like turboing a 4.2L engine. Easy to make massive power. Plus, because the engine is blown, the blower makes boost before the turbo can even think about making boost, so it's like having that 4.2L engine all the way from idle. Fattens the torque delivery up massively. But, there are downsides. The first is trying to work out how to size the turbo according to the above. The second is that you pretty much have to give up on aircon. There's not enough space to mount everything you need. You might be able to go elec power steering pump, hidden away somewhere. but it would still be a struggle to get both the AC and the blower on the same side of the engine. Then, you have to ponder whether you want to truly intercool the thing. Ideally you would put a cooler between the turbo and the blower, so as to drop the heat out of it and gain even more benefit from the blower's positive displacement nature. But that would really need to be a water to air core, because you're never going to find enough room to run 2 sets of boost pipes out to air to air cores in the front of the car. But you still need to aftercool after the blower, because both these compressors will add a lot of heat, and you wil have the same temperature (more or less) as if you produced all that boost with a single stage, and no one in their right mind would try to run a petrol engine on high boost without a cooler (unless not using petrol, which we shall ignore for the moment). I'm of the opinnion that 2x water to air cores in the bay and 2x HXs out the front is probably the only sensible way to avoid wasting a lot of room trying to fit in long runs of boost pipe. But the struggle to locate everything in the limited space available would still be a pretty bad optimisation problem. If it was an OEM, they'd throw 20 engineers at it for a year and let them test out 30 ideas before deciding on the best layout. And they'd have the freedom to develop bespoke castings and the like, for manifolds, housings, connecting pipes to/from compressors and cores. A single person in a garage can either have one shot at it and live with the result, or spend 5 years trying to get it right.
    • Good to know, thank you!
    • It's a place for non car talk. There's whoretown which is general shit talking. But also other threads coving all sorts of stuff(a lot still semi car related)
    • Looked it up. It sounds so expensive lmao I'd rather not. Awwwww but I just love that sound
