  • Replies 106
I work for WA Turf Club (no they dont grow grass) ..... basically we own both of the major racecoarse in WA and administer horse racing in WA.
Im just an admin asst but hopefully will be getting trained up in marketing ...... one day over the rainbow.
u paki?
paki? eh as in pakistani ...ummm look in the gallery mate im as white as they come .... 1/4 irish, 1/4 french .... rest true blue aussie that can be traced back to Kelly. Im also blonde so that may be why i dont get the relevance :confused:
Thanks Zoix :)
Slip .... i used to be work in car dealerships for four years ..... my ex was a salesrep ..... all i can say is "get out now before its too late" LOL
I've been a salesman for 1/3 of my life.
What I need is a degree/qualification that i can do over 3-4 years, which gives me good wage on completion, monday to friday work, and the ability to earn more and more and more as I go on. Want to be on at least 100k after 5yrs of work.
Any suggestions?
Play the lotto and see if u get lucky: (once a week x 52 weeks) x 3 to 4 years = alota chances.
which equals very broke... Don't think thats really gonna get you anywhere...
on the otherhand eating tim tams all day isnt too shabby eh...*nudges Michae;*
:werd:
Been there, done that, successfully
huh....u won the lotto?
um..
i have 3 jobs at the moment...maybe 4
One i work at computer sales/support i guess at umart 3 days a week
Another i work 2 days a week as pretty much permanent contractor doing web design work for a small web design company. This is my main training, and expertise and where i did my degree (a degree that gets you $100k? ahhh young slip ;))
The other i am doing more web development (e.g. also the coding side) also as a subcontractor for a company. Building a site for a horse racing syndicate at the moment actually. This is "afterhours", e.g. whenever i am not at the above 2 i should be doing this :) Doing my head in at the moment.
The final.. which i guess is a "job" is co-managing/developing a pretty popular games site www.gamebiz.com.au which i been doing for a couple of years. The goal is to one day to make that into a successful money making business. Gaming is hugggee bucks, and if i ever have the time, i know i can make it massive. But its all time, and hundreds of hours of work for a possible/maybe payoff. Currently stalled pretty much due too much of the above :D
Aviation Maintenance Technician, or that's what we seem to be called these days...
I was training to be an "Aircraft Engineer" all through my apprenticeship but now they have changed the name on me...
Currently employed by Boeing Australia and work on the tired old 707 tankers for the RAAF.
Systems operator at power station SLIP? on second thought that's what i am aiming for. go away, it's mine all mine.
Qualified car Mechanic.
Work as Fitter at Power station. earn twice as much a mechanic for doing half the work, which does get boring often. ohh well gotta support my passion somehow
    • Gday, Due to not finding much up to date info on this topic I thought I'd make a thread to get peoples latest opinions/recommendations. Background info -  I've got a S1.5 R33 GTST as a fun project car, mainly for street use and occasional drag strip, apart from all the cosmetic things I'll be doing a full rebuild of the engine with forged internals. Since it'll be getting new cams (kelford) and springs to match I thought I might as well get new lifters and valves while I'm at it, the dash says 160k KMs but the engine seems pretty tired, compression measures about 130psi across all cylinders so I'd like to freshen everything up. This is where I'm tempted to just fork out the extra and go solid lifters while it's all apart, aiming for 400-450kw atw with a flex tune. Assuming all supporting mods (oiling, fuel and all bolt ons) with a lightly ported head and turbo to match (yet to make a decision possibly gtx3582r or similar from Hypergear) I've seen the Tomei kits with just the buckets getting around, Supertech sells most things - Supertech High Performance Cam Followers | Trusted Racing Cam Followers Questions -  Has anyone found the Hydraulic lifters to limit them at this power level? Is it usually found that you can just clean the stock lifters and find they work fine?  Does going solid lifters save any headaches/issues with hydraulic lifters in the future? Any recommendations on other things that will need to be replaced, I know I'll need to get the solid profile cams but can you use the same type of valves and springs/retainers and is it recommended to change the guides and stem seals?    Summary -  Basically looking for pros/cons and wanna know if I'll actually need the extra RPMs from solid lifters or it'll just be bragging rights to say it ReVs OvEr 8000 Cheers
    • Ha ha ha, this stuff they had was installing Toshiba PLCs that were made some time in the 1990s, and they were replacing GEM80 PLCs. To let those two talk (staged upgrade along a ~1.2km long building that was split into 4 sections), was a bunch of WinXP machines running Java gateways... There was no way to put something like ProfiSafe in... Most of the HMI machines were WinXP, with Java program, with a custom button board emulating a keyboard... About the only buttons in the operator stations that went direct to the PLCs was the eStop. There was some interesting design stuff in that place...
    • Stock bypass valves are good for plenty of boost.
    • Check for fuel flow out of the outlet end of the rail. Check for spark. Try to start with aerostart (or pressure can brake cleaner or similar solvent in a car) prayed in through TB. If you have fuel and you have spark and it will fire on substitute fuel, then seriously suspect that E85 sitting for ages in your fuel system has destroyed something and put it in your injectors.
    • Nissan stock oil pressure is typically about 1 bar at 1000 rpm plus about 1 bar per thousand revs on top.
