I will upload video of Sandown tomorrow. ;)
And that's just the little brother! Imagine what this 3.0 beast will be doing!
Op, vids of dyno and track work please when you get round to it :)
  • 1 month later...
I have wanted to do this for years to my s14
But the gearbox scared me off.. either z32 with custom adapter plate $$$
or
z33 like you but tailshaft issue and cost of a z33 box mad that even more $$$
Love it though and the fact you managed to make the motor look nice too ;)
  • 3 weeks later...
  • 3 months later...
Oii....how's the writing going? Why are you always fiddling with wiring when I'm on uni break?
I'll leave it up to PSI999 to explain what happened to Nistune. From memory there was too much work left to do within Nistune to do with assigning variables for cranking and idle (lots of tables did nothing and some variables such as crank pulse-width seemed completely absent - not good for over double the injector size). Tried to do some work-arounds but looked like it wasn't going to be resolved satisfactorily.
Edited by simpletool
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
