  • 2 months later...
possibly one of the best engine swaps i've ever seen! absolutely beautiful.. awesome work.
I have a Nissan a32 Cefiro stock with an auto vq30de - and even that goes like hell. I've had countless races against people thining they can beat me yet I haven't lost a single race :P Even against rb20det's, sr20det's.rb25de's,4litre falcons and v6 commys... I could go on. Bottom line is vq's are tough!! And I bet your one will fly.
I'm one day thinking about taking that motor out and putting it in my vl commodore... before people start asking me am I out of my mind just remember these commodores are already rb powered, so why not replace with a better nissan engine?
  • 3 months later...
Thought i'd dust this thing off, still hasn’t seen the dyno so its time to change that…
(chucked together a V8 (1UZFE) Datsun Bluebird over the past few months which has proven to be a major distraction to this project)
So an update.
So have been planning a LS1 coil conversion for a while (because the stock coils are rubbish), finally bit the bullet and started this week…. Have been putting off the conversion for a while as I couldn’t really work out where the coils were going to go, I have bugger all room anywhere.
After a bit of buggering around the passenger side ended up being quite easy, mounting to the valve covers I was able to use a lot of the stock coil-on-plug bolt holes (studded with spacers) which gives good spacings and a neat look with the LS coils…. As a plus I was able to use a set of off the shelf LS factory leads which are cheap and gives me a few spares… The spark plug end fits perfectly into the spark plug hole.
And because everyone loves pics :D
Workbench
All bolted down and connected
And all installed, just looks like stock.
Drivers side, not so easy… had to fabricate a bracket to hold the coils in place…. Still a work in progress.
Hopefully have it all running again by the weekend.
And if anyone is interested this has been my distraction over the past few months.
10295355_293347207502054_337309397344269
1UZFE 4.0L V8 (from Toyota Celsior)
5-speed conversion - W5x gearbox from (from Toyota GX100 Chaser)
R31 Diff conversion
R31 front brakes / R31 rear brakes
R31 front struts (converted to coilover) S13 rear coilovers
R31 Wagon fuel tank conversion
Apexi SAFCII
AEM WB02
Physical build took 11 days over xmas/new year 13/14.... Have spent the past few months on-road sorting and refinement... pretty nice package now.
Edited by psi_999
  • Like 1
Phooey.
Shame about those LS1 coils. they are pretty old school and produce average spark power with fairly long dwell durations. Having said that, Ive used those things in the past and they work ok and neaten up wiring and so-on without the need for additional clobber like coil triggers.
The coils you need to use are the D585 (GM Yukon) coils.
These blighters, again internally triggered,literally generate thunderbolts that you can almost weld with and are not a gret deal pricier than those old LS1 clunkers!!!!
Really good stuff!!
Cheers
E
Edited by tassuperkart
Tass: yep good old tried and proven El cheapo ls1 coils, think the set of 6 set me back ~$130 so a nice cheap upgrade. Truck coils are the plan later down the track if all goes pear shaped.
Scotty: not sure mate, have two friends that have run into issues over 400rwhp on stock vq30 coils so swapping them out now makes sense. LS coils pack a fair bit more punch so hopefully it'll work nicely. I've already finished the install now and feels much cleaner off idle and light cruise... big spark ftw :)
Jon
Im about to order 8 of them for a M8 and myself for the Pullstarts. Wnat me to grab 6 more!!! LOL
Cheers
E
haha thanks for the offer.
Should be OK though, 10secrx7 on performanceforums has made 1250rwhp on stock ls1 coils (and another bloke 906rwhp on 155,000km old coils) so should be right for a bit lol.
There are much better coils out there if you want a big spark, I have seen LS coils fail dismally on the dyno, especially if you don't have good dwell adjustment. The only benefit is their cost.
If I changed parts simply because others had issues I wouldn't have ever finished my build. The amount of times I have been told to run copper plugs and change my coils... They are all wrong, it's a VQ, not an RB.
More than likely your mates had dirty coilpacks from sitting at the wreckers, or copper plugs in an engine specifically designed for platinum/iridium plugs. They would have been told the same thing as tuners told me, just change them before you go on the dyno mate...
Good ole' LS-1 coils do a reasonable job against their price, makes them an attractive alternative to anything stock without the hassle of multi-channel igniter (trigger) packs, additional messy wiring and so-on.
However, move along to D585's (GM Yukon and several others IIRC LS-2/LS-6....cant remember exactly) coils and spark issues are over for anything short of a welding rod.
Bruce Bowling (Bowling and Grippo developers of Megasquirt) who prolly knows a thing or two about engine management does a nice evaluation of them against a few other like coils. Youtube it.
The spark energy generated V's cost is unbeatable.
E
If it's up and running bring it round to mine this week. Writing the final 1000 words of university papers tonight. No more uni ever.
Once the S15 is sorted you won't want to drive anything else.
Edited by simpletool
Running great with the LS1 coils, i can absolutely tell the difference between LS and stock coils :D
So another job finally ticked off – oil catch can.
$400 in bits so I’m not surprised I left it until later in the build…. LOL not really, I just had no idea where to put it.
Ended up settling on an off the shelf 2L baffled catch can and had a friend modify it slightly for my purpose. Tucks in nicely in about the last mostly unused space in the engine bay…. 2 x -10 inlets & stainless mesh filter.
Previously occupier of said spot:
Installed:
Just need to rehome the boost control solenoid, drop in some new sparkplugs and its dyno time :D
So took a punt i'd be able to sort out a better solution on the very visible oil catch can filter.... defect central.
Result:
Filter sits nicely down inside the front bumper, where the OEM intercooler once was.
Also boost controller has been remounted on the fuse box lid:
And just because, this is pretty much it... wont be any more engine bay changes from here on.
Next, dyno :D
  • Like 2
    • It only looks tidy, as most of the stuff that was on the whole back wall, is now in the trailer to go to the tip, or has been shoved in my 2.2x2.4m "Spare parts room", and now I can't get to anything in there Ha ha ha I could definitely do with a bit more space, but I'd just end up with your problems I'm going to enclose the car port beside the garage, and move a lot of stuff into it I think. OR... It will be setup as a fabrication area, and the main garage will have parts storage in it. I'm not sure yet... Need some pictures of that big shed you've got with the bikes and Skyline in
    • No. I think it's gone. 😭 I think you can get body coloured ones on eBay so I think I'll get one of those... Or just hang a red ribbon from the hole and whack a TOW sticker next to it.
    • Can't say I've had a bad experience with one on my car, then again it only gets washed once or twice a year... The wheels on the other hand, get a good spray often due to my shitty dusty pads.
    • @MBS206 thats pretty neat and tidy to me!  I'll get a photo of mine when I'm out there next. It might require multiple photos to understand the scale of the atrocities though... In total I have 4 sheds of varying sizes and layouts. Main shed is 14x8, second shed is 3x8, third shed is 11x2.5, fourth shed is around 6x4.  All are pretty much full.   The main goal of my cleaning tsunami is to make the main shed predominantly car and motorbikes only. Second shed is my metal fab room (2 x bench grinders, drill press, bench belt sander, metal band saw, scrap metal storage and some of my garden tools.  3rd shed is more bigger garden stuff, storage for engine crane, jack stands, concrete grinder, concrete mixer, air compressor lives there, and it now has two 2mx2m pallet racking shelves with itemised boxes holding building stuff, electrical stuff, plumbing stuff, etc, etc.  The 4th shed is Ryobi electric ride on mower, mini boom sprayer, ancient Kubota tractor, more garden stuff!  I have got a lot of shit....  Then there's the pool house (8mx4m) and the pool pump shed (4mx4m).  I built all of the sheds over the 11 years we've been here.  The main shed was a Ranbuild kit, the rest are all custom made to fit the areas available. Building the main shed taught me a LOT as I had no idea about building anything prior to that!  I've still got one more in me. It will be my man cave which I poured the extra concrete for way back when I poured the concrete for the main shed. The idea is the Skyline will be a centre piece of the main cave once (if...) it's finished.  I told my now 14 year old son yesterday that I will 100% drive him to his year 10 formal in 2 years. Still a long way off but at least I now have a date to work towards! 🤣
    • Modern oils are amazing. Add tyres to that as well.
