Hi all
new to the forums and owning a skyline(first one)
i had an issue the second day of ownership :angry: was very unhappy jan,
but it turned out to be that the previous owner had decided to use carby fuel hose from the pump to the top of the fuel tank instead of using proper efi hose
and it burst in the tank, had that fixed and now when i am at WOT i feel a bit of surging (the car is manual(converted)) and is running 12-13 psi of boost (bought like this)
std intercooler car came with a exhaust haven't had time to measure or check brand
i am going to try turning down boost before exhaust wheel shits its self but wondering if any one had any other ideas as to what could be causing this
regards
aphex
https://www.sau.com.au/forums/topic/415612-r33-gtst-surging-under-heavy-boost/
describe your surging? I think you're mistaking it with R&R.. the car just hits a brick wall and comes back to life and hits another brick wall...
Too much boost buddy for the stock ECU, it just falls into the wrong cells and bam massive timing pull. I even get that at 0.8bar on cold nights, I just run 0.7bar all day
Hi all
regards
aphex
are you sure it is a stock turbo? could it be something else eg a 2876?
stock turbo would be snapped in half before it could reach its surging limit. might've been afm dirty or miss firing.
The type of surging ive heard is not mistakable, has a distinct sound, take the intake pipe off to see if the compressor wheel has left a grove in the cover, my brothers skyline turned out to have a gt2876, it has a line carve out of the compressor cover.
Maybe inspect the fuel tank for debris and change fuel filter a few times.
cheers all for the reply's
i have dialled it back to 10 psi and it has improved but is still there.
When hot the vehicle hesitates/surges i have tried 98 and 100 ron fuel
i thought it might be a battery problem so i replaced to no avail
will pick some contact cleaner for the maf and a fuel filter as well as some sparks tonight
mods: sh*$y drift boost controller, stock BOV, stock intercooler, pod filter
PS: the vehicle smells very rich after snapping the throttle open
regards
aphex
cheers all,
i have cleaned maf sensor with ecc it improved the issue a little but it is still there.
any 1 have any ideas on how to free the stuck rubber hose on the fuel filter (tried bottle nose pliers but don't want to munch the fuel hose) it looks as if it has been on there a while
i also have injector cleaner but dont want to use it till i have a fresh fuel filter in there.
have found the issue is evident in low gears under accel (any) once in 4th-5th at 80km/h-100km/h it will pull fine
ps. what does RnR stand for?
regards
andreas
Edited by aphexcloud
i wasn't looking for an explanation.
i was wondering what does the Acronym mean... so i could do some research on it
http://lmgtfy.com/?q...esaustralia.com
5th hit, and that's using the less common RnR version rather than R&R.
Edited by GTSBoy
cheers all,
Cut it off and replace it.
Yeah, my point was given that you had been told it was R&R, you could have googled it for yourself in less time than it took to ask. I'm just trying to discourage the spoonfeeding mentality on forums.
why isnt that what we are here for? to offer help, support and advice to people that dont know very much.
god knows what you did before google my friend.
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
    • Hmmm interesting. Mine is the exact same and clearly the right one.  The mystery of the engine oil being full after 3.5-4L continues
    • Yes I as well would like to find out where I could get some of the seat material with the red or blue small squares in it
